Question about Gateway FPD2275W LCD Monitor
Syncmaster 226bw goes black
Hi, sorry to bother you, but I am having a very similar problem with my monitor, it just goes black, although if I look very very close I can see that the image is there, its just to dark to see it, every time I press the source button and it gets to digital the image comes bright and normal, but a second later its dark again. I have the same problem!! my Samsung SyncMaster 932GW only works for a second when you turn it on Then it fades to Black..
I got a new Dell and it works fine on the same tower. I really would like to knw how to fix this issue
  • Kenny1134 Aug 17, 2008
    I know I have a problem with the display. I need to know how to fix it. thanks for trying. any one else?
  • Kgummy May 24, 2009
    The only solution I have for the problem, although I don't consider it a real solution, so I won't add it as such...
    But I just keep pressing the source button plus any key until it stays lit... usually before it finally works it starts to flicker for a few seconds.
  • 185 Answers
I think u have a problem with ur display,please contact ur service centre immediately to fix it.
Posted on Aug 16, 2008
  • Abdur Rahim S
    Abdur Rahim S Sep 04, 2008
    Sir,
    U may have a problem with the ICs inside the monitor or problem with your monitor cable,so u should contact the sevice engineer to fix this problem.
    Thank You
Samsung 226bw goes black after startup
Maybe the screen is just a faulty one. If you have a warranty for it, GET IT REPLACED. problem solved in my opinion. if you tried it on another computer it will be a problem with the monitor. take it in and get it checked out.
Tech Support ' Hotmail Support
Sep 13, 2012 | Samsung 226BW Monitor
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
My samsung 226bw (analog) monitor will not shut off. It goes black when the power button is pushed but then the analog square comes up and the screen is brought back up to where it was when I hit the...
it is probably the power button itself, or there is something wrong with the power board inside the monitor, the capacitors are probably on their way out, in these monitors cheap capacitors are used and they seem to fail within 2-3 years, these can be replaced by a professional and would probably be cheaper than buying a new one. either way, if the picture on the monitor is OK, you could just switch it off at the socket or wait for it to go into power saving mode.
Apr 27, 2011 | Samsung SyncMaster 226CW 22" Monitor
Samsung syncmaster 172v Screen goes black after about one second. Comes back to normal after turned off, but goes black again in about one second. Rebooting computer has not fixed this.
Sorry it is like your monitor needs service. Electrolytic condensators in power supply need to be changed. Give it to an electronic shop, it is a job for a specialist.
Oct 18, 2010 | Samsung SyncMaster...
Samsung syncmaster 226BW fails to wake up.
If pc not sending it to "sleep mode" or "power save" mode, then unit may need help of electronics technician to investigate the "internal switch-mode-power-supply" that may be going into "shutdown" mode after it detects a "fault condition" with itself or onother circuit.
12fixlouie
Sep 20, 2010 | Samsung SyncMaster 226CW 22" Monitor
Need to know if this monitor is hdcp compatible. Can it support hdcp?
here is the List of compatible monitors with their brand names :
Sony
Sony MFM-HT205
Viewsonic
Viewsonic VP2330wb
Viewsonic VP231WB
Viewsonic N3250W
Dell
Dell 2007WFP
Dell 2407WFP
Dell 2707WFP
Dell 3007WFP
Dell E228WFP
Dell E207WFP
Acer
Acer Al2423W
Asus
Asus MW221U
Asus MW201U
Gateway
Gateway FPD1975W
Gateway FPD2185W
Gateway FPD2485W
Gateway FPD2275W
HP
HP LP3065
HP f2105
Samsung
Samsung 205BW
Samsung 214T
Samsung 215TW
Samsung Syncmaster 225BW
Samsung 242MP
Samsung 244T(US version)
Samsung SyncMaster 244T
Samsung 320P-Black
Samsung 930MP
Samsung 940MW
Samsung 940BW
Samsung Syncmaster 931BW
BenQ
BenQ FP241W
BenQ FP241WZ (Includes 1:1 pixel mapping)
BenQ FP241VW (Includes 1:1 pixel mapping)
BenQ FP222WH (Unconfirmed)
BenQ FP94VW (Unconfirmed)
LG
LG L245WP
LG L226WTX
NEC
NEC Multisync 20WMGX2
If you can tell your monitor manufacturers name and model no i can let you know about it. Anyhow the above information will help you.
Mar 11, 2010 | Polyview MNTR |17'LCD V17D Monitor
My SamSung SyncMaster 226BW flashes about 2 times a second for about 30 seconds when first turned on. The background (computer) image is present, but dim. After about 30 seconds it appears normal. It does...
The first place to check will be the caps in the power supply, look for bulging top/bottom seal. See example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Feb 10, 2010 | Computers & Internet
Samsung syncmaster 226BW no backlight
Look for any bulging capacitors, instead of a flat top they will look "pregnant".
If you see any of those then replace them with capacitors of the same UF rating and the voltage needs to be either the same or higher.
If you dont see any bulging capacitors or burnt parts, then its got be the LCD at that point thats not staying on and the cost to replace the LCD is as much if not more then to just get another monitor.
Aug 27, 2009 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
If you can still faintly see data on your screen, it will be a faulty backlight in the panel most likely.
LCD panels have fluorescent tubes in them that provide the light needed to see the data. If one of these goes faulty, the circuit that drives it will turn off ALL the backlights, giving you a black screen.
Note: a faulty circuit that drives the backlights will often give the same apparent fault.
You will need to take the monitor in for repair.
Jun 23, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
746 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
