Comment programmer une manette universelle nexXtech
3 Suggested Answers
dauphine
  • 207 Answers
SOURCE: philips universal remote codes
http://www.urc.philips.com/
Posted on Apr 10, 2008
anthony_quit
SOURCE: j'ai perdu les code pour
jai besoin le code pour ma manette URC-386 pour ma TV LG FLATRON
Posted on Sep 26, 2012
Comment programmer manette universelle URC-383 ?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Nov 24, 2016 | Televison & Video
Besopin du code pour manette universelle philips
If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 19, 2013 | Jasco 24911 Remote Control
Quelle sont les etapes que la manette universel fontione
Lorsque vous souhaitez programmer un dispositif trouver le premier code.
Ensuite, appuyez et relâchez le bouton que vous souhaitez attribuer le code,
Ensuite, appuyez et maintenez enfoncé le bouton SETUP jusqu'à ce qu'elle occupe une lueur.
touché les numéros de code. il devrait clignoter deux fois, en indiquant un code de bonnes.
puis cliquez sur le bouton que vous venez de configuration, et le diriger vers le périphérique, et cliquez sur le bouton d'alimentation.
Si elle vient, vous avez choisi le bon code
Il ya généralement plusieurs codes pour une marque, afin de les essayer tous, un par un jusqu'à ce que vous avez.
Répétez la procédure pour d'autres articles. Soyez sûr d'assigner une touche différente et appropriée labeld.
Aug 31, 2011 | One For All URC4110 Remote Control
Bonjour comment l'activer pour pouvoir enregistrer le disc dur de mon portable merci
Bonjour Arnaud,
ce produit est habituellement livr? avec le LaCie Setup Assistant. Une fois celui-ci ex?cut?, votre disque sera disponible sur votre ordinateur.
Le produit est aussi livr? avec le Genie/LaCie Backup Assistant. Une fois install? et ex?cut?, ce programme vous guidera afin que vous configuriez la sauvegarde de vos donn?es vers le disque LaCie.
Si vous croyez avoir effac? par accident le contenu du disque avant d'installer le logiciel, il peut ?tre t?l?charger ?: http://www.lacie.com/download/drivers/LaCie%20Genie%20Backup%20Assistant%208.0.364.534%20Win.zip pour le PC et http://www.lacie.com/download/drivers/LaCie%20Intego%20Backup%20Assistant%201.0.1%20Mac.zip pour le MAC.
Vous pouvez aussi faire une copie directe de vos fichiers vers le disque LaCie comme s'il s'agissait d'un disque local.
Faites moi savoir si vous avez besoin de plus de d?tails.
Jan 29, 2011 | LaCie Rikiki Go 1TB USB 2.0 Portable -...
Comment programmer la minuterie extérieure
1) Je ne parle pas fran?ais. J'utilise google translate.
2)
Ouvrir la page Web.
http://waterheatertimer.org/Woods-timers-and-manuals.html
3)
Trouver minuterie sur la page web.
4)
Manuel Ouvrir, puis utiliser google translate.
5)
Coller paragraphe entier dans Google Translate.
6)
Utilisez Google traduire poser une autre question.
7)
Cliquez sur "add a comment" pour poser une autre question directement.
Jan 23, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
J'ai perdu les code pour programmer ma manette urc-386 avec ma t.v Toshiba.
Jan 15, 2011 | Televison & Video
Cam?ra embroyer..
Pourquoi les images provenant de la caméra sont-elles déformées, floues, granuleuses ou décolorées? trnsp.gif Réponse Plusieurs facteurs ont une incidence sur la qualité de vos images. Si les images sont floues, réglez la bague de mise au point située autour de l'objectif. Vous pouvez ainsi réaliser la mise au point sur des objets situés à des distances différentes. Veillez également à ce que l'éclairage soit adéquat. L'amélioration des conditions d'éclairage influe considérablement sur la qualité des images.
Si la qualité des images est médiocre pendant une transmission vidéo sur Internet à l'aide de programmes comme MSN Messenger, Yahoo! ou AOL Instant Messenger, votre vitesse de connexion à Internet a une incidence directe sur la qualité de la vidéo transmise. Les connexions d'entreprise de type modem câble, DSL ou RLE permettent d'obtenir d'excellents résultats en termes de qualité d'image, alors que les connexions commutées engendrent une qualité globalement médiocre et instable en raison de la lenteur de la connexion. Il peut arriver que la vidéo soit instable même avec les connexions haut débit (comme DSL ou modem câble) en raison du trafic Internet ou de la lenteur de téléchargement. Si l'image apparaît clairement sur le logiciel de la caméra, il est fort probable que votre connexion Internet soit à l'origine de la mauvaise qualité des images dans votre programme vidéo.
Si malgré tout, les images obtenues sont toujours déformées, floues ou granuleuses, vous devrez peut-être modifier les paramètres d'affichage. Pour une qualité optimale, vérifiez que la résolution est réglée sur Moyenne (16 bits) ou plus. Pour modifier la palette des couleurs:
  1. Cliquez sur Démarrer, puis Paramètres et Panneau de configuration.
  2. Double-cliquez sur l'icône Affichage.
  3. Cliquez sur l'onglet Paramètres.
  4. Dans la section Qualité couleur, vérifiez que l'option Moyenne (16 bits) ou Elevée (24 bits) est sélectionnée.
  5. Procurez-vous également les pilotes les plus récents auprès du fabricant de votre carte vidéo.
Si vous ne pouvez rien faire pour améliorer les conditions d'éclairage, certaines caméras vidéo Logitech sont équipées de l'option Optimisation de la lumière variable. Si tel est le cas pour votre caméra, activez l'option Optimisation de la lumière variable dans le logiciel QuickCam. Pour ce faire, procédez comme suit:
  1. Lancez le logiciel QuickCam.
  2. Dans l'angle inférieur droit de la fenêtre vidéo, cliquez sur la flèche en regard de l'icône QuickCam.
  3. Sélectionnez Paramètres de caméra avancés.
  4. Dans la section Amélioration de l'image, activez l'option Optimisation de la lumière variable.
  5. Si la qualité des images ne s'améliore pas, essayez de régler les autres paramètres, tels que le contraste, la saturation, la luminosité, le gain et l'équilibrage des blancs.
  6. Cliquez sur OK lorsque vous avez terminé.
Enfin, vérifiez que vous utilisez la version la plus récente du logiciel
Mar 03, 2008 | Logitech QuickCam Communicate STX Personal...
USB 2.0 cardbus pc card adapter N2PUCB
Straight from NexxTech's website:
http://download.nexxtech.com/nexxtech/N2PUCB_pcmcia_USB2.0.zip
Jan 05, 2008 | NexxTech NCARDBUS Network Adapter
Programming my nexxtech 3-in-1 remote control
looking for instructions for  remote control nexxtech 3 in 1 universal
Oct 28, 2007 | Televison & Video
Televison & Video Logo
167 people viewed this question
Top Televison & Video Experts
