Question about Uniden Cordless Phone
The hand-set on the main station, has a red light on the upper right corner, this light BLANKS all the time. Also, the message in the display window states
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Posted on Dec 02, 2013
  • 3 Answers
SOURCE: To turn the blue light off
What worked for me was to call my phone and leave a voicemail. I then retrieved and deleted my voicemail which reset my handsets.
I hope this helps!
Posted on Jun 05, 2008
SOURCE: Handset Won't Connect to Base Station
OK sorry guess I was thinking you had 2 handsets.
My suggestion is go to the Uniden website and maybe see what they have there.
Maybe do a search on the Uniden site for that Automatic Digital Security Code thing, seems it would be easy to fix, just a matter of how....
In the meantime I'll do some searching and see if I can help and find a fix
Posted on Dec 01, 2008
  • 18 Answers
SOURCE: E4 code on base station
i know that you dont want to hear this but that means it must be replaced. you should be able to get a replacment form where you purchased the phone
Posted on Jan 09, 2009
divatif
  • 39 Answers
SOURCE: handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Posted on Mar 17, 2009
cshannon1077
  • 14 Answers
SOURCE: DCT 646
If you have a phone that works off a broadband modem, that is a VoIP phone. That will not work with a home phone line. I'm assuming Verizon is your local Telephone carrier that provides your local dial tone.
The broadband modem would have the phone number of whatever VoIP phone service you have.
Posted on Apr 10, 2009
I have a Uniden Dect6.0. The message light in the upper left-hand corner of the phone continues to blink, but when I push the message button on the lower right-hand side of the phone, the recording says I...
You have unheard messages on the voicemail system provided by your telephone company. This system takes messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 19, 2011 | Uniden DECT 6.0 Cordless Phone ID
I want to set my EnviraStation DWS220 to the right time zone.
TIME ZONE SELECTION
Press SET" button on the front of home receiver to select from the following
time zones in the U.S. (zone is displayed in the upper right hand corner of
time display).
P - Pacific Standard Time M - Mountain Standard Time
C - Central Standard Time E - Eastern Standard Tim
Dec 05, 2010 | Measuring Tools & Sensors
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
Handset won't ring
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Nokia 2600 time display
I'm a cell phone sales representative and I came across a customer that had a similar problem.
What I found with her, she had so many icons displayed along the top row of the phone that the phone simply did not have room to display the time.
By clearing out her text message inbox, the sent messages, the outbox and being sure all of her voicemails had been checked, a number of the icons disappeared off the top of the screen and so the phone started to display the time again.
So that solve the problem for her. Hopefully it can help you as well.
Dec 11, 2008 | Nokia 2600
Cant display time
Upper right-hand corner, there's a button next to the "eject" button. Pressing this button while the unit is on will cycle between displaying the clock and the track number & play time (CD) or clock & radio station.
When the unit is off, you can press the same button to completely shut off the display, which is sometimes nice if you don't want the blue ring around the volume knob glaring in your face.
Jun 22, 2008 | Pioneer DEH-P3900MP CD Player
HOW DO I TURN OFF PREDICTIVE TEXT
First, hit the 'Message' button in the upper-left -hand corner. Select 'New Message'. Select 'New Short Msg'. An empty screen for inserting text will now be displayed. At this point press the top middle button (the one with the line on it like this -). Now the 'Message Menu' should be displayed. Scroll down to 'Entry Setup' & select it. Press the 'Change' button in the upper-right-hand corner when 'Primary Setup' is highlighted. Scroll down to 'TAP English' and select it. Now you are done. ('I TAP English is the setting for predivtive'. 'TAP English is the setting for manual').
Apr 23, 2008 | Cell Phones
Indicator message light on handheld phones do not go off!!!
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
poof! message gone
Apr 17, 2008 | RCA ViSYS 2-Line Speakerphone
Problem with initial set up palm
When you turn your Palm on, on the main page there should be a list of icons. Make sure in the upper right-hand corner All displays with an arrow pointing down.
Then, click on the World Clock icon to change the date/time for your Palm.
Jan 03, 2008 | Palm Tungsten E2 (Multilingual) Handheld
Uniden Cordless Phone Logo
54 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
