Question about Lands Phones
1. Too many rings before answering. How can I shorten? 2. Because message is short, how do I bring "beep" closer to my message?
    President:
  • 2,992 Answers
You don't say what brand and model phone or answering machine you have, so I can't give you a step-by-step answer. But here is general information.
The number of rings until the answering machine picks up is controlled on some units by a switch. Most of the time you'll find it on the rear or one of the sides. If it's a cordless phone/answering machine combo, the switch will be on the base unit. These usually have positions for 2 or 4 rings. Some have a "TS" position as well. This is for "toll-saver", which extends the number of rings if there are no new messages. If you call to check message while you're away, if the phone rings more than the number of times you selected you know there aren't any new messages. Then you can hang up before the machine answers and you won't be charged for a call. (This is a hold-over from the days where you might need to make a long-distance call to check your messages. Most people have cell phones with national calling plans now and it doesn't really matter.)
Some newer units have a setup menu where you'll find the ring selection. On a cordless phone the menu button may be on either the base unit or the handset. It depends on the make and model.
On most of today's answering machines, the beep tone is added when you're done recording. Usually you press and hold a button to start the recording, make your announcement, then release the button. The beep is recorded when you let go of the button, so there shouldn't be much delay after the message end. If the beep comes a long time after you finish speaking, either you're not releasing the button, or you have a very old style machine with a fixed recording time. The instructions that came with these usually gave suggested messages that would take the time, and typically had you end with "...please wait for the beep and leave a message".
You can usually find manuals for downloading from the phone or answering machine manufacturer's website, or on one of the many other manual sites on the Internet. Try a search for "(insert your brand and model here) owner's manual" as a start. Of course, if all else fails another option is to get a new machine. Basic models aren't expensive, but if what you have can be made to work the way you want, why spend money?
Good luck and thanks for using Fixya!
Posted on May 29, 2011
Testimonial: "Thank you! Both problems have now been fixed. I am delighted."
MY PHONE only rings 3 times no matter what, when people leave message I can not retrieve it, and the message allert light flashes continuely. just put new batteries in all phones. 3
you can alter the number of rings before it goes to answer machine
set the answer machine up properly and when a message is recorded , the alert light will flask every so many seconds along with a short beep
set it as per the user manual and if you don't have a manual then down load it from the manufacturers site on the net
Jan 20, 2016 | Lands Phones
Cordless phone has error message "get closer to base", the phone rings but you can hear person or If I call the phone, it rings but answer machine does not activate????
the get closer to base message displays when you are too far from the phone's docking station. It could be as simple as replacing the battery with a new one from radio shack or such electronic places. But then again I don't know if it was damaged, dropped, or got wet, so this is my most reasonable solution.
Dec 10, 2010 | Panasonic KXTG2344 Cordless Phone
How do you change the number of rings before machine turns on?
When the AT&T 1717 digital answering machine is powered off it will answer an incoming call after 10 rings, it will announce "machine is off" then beep twice, dial 0 to turn it on. The machine is now ready to answer calls. This 10 ring setting is factory set and cannot be modified. To set the number of rings to answer for normal operation press <SET UP> button and hold for 2 seconds, machine will announce current ring setting. Press and release <ANNC/SKIP> or <MEMO/REPEAT> until you hear the number of rings you want. Press and release <PLAY/STOP> to exit. The ring settings available are 2, 4, and toll saver. When set to toll saver machine will answer after 4 rings when there are no new messages and after two rings when is anew message. Here is a link where you can download manual, http://safemanuals.com/user-guide-instructions-owner-manual/AT%2526T/1717-_E
Dec 09, 2010 | AT&T 1717 Digital Answering Machine
How to recover saved messages remotely
To retrive the messages remotely please follow the steps...
Dialing In to Your System:-
1.Call your telephone number and wait for the system to answer. (If your answering system is off, it will answer after ten rings and sound a series of beeps instead of your greeting.)
2.During the greeting or beeps, press 0 and immediately enter your security code. If you enter it incorrectly 3 times, the system hangs up and returns to standby.
3.The system announces the current time, the number of messages stored in memory, and a help prompt. It will beep intermittently to let you know it's waiting for your command.
When you hear beeping, enter a 2-digit command from below:-
01Repeat message
02Play message
03Skip message
04Delete message
05Stop playback
06Turn the system on
09Turn the system off
10Hear help prompts
Thanx
Jul 20, 2010 | Uniden DECT 6.0 Cordless Phone ID
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
How to access messages remotely
While you are away from your home or
office, you can use a touch-tone phone,
or a pulse (rotary) phone with a pocket
tone dialer (available through your local
RadioShack store) to enter your PIN and
do any of the following:
• set the phone to answer or not
answer calls
• listen to your messages
• record a new outgoing message
• erase messages
• monitor the room where the phone
is located
Notes:
• You cannot remotely operate the
phone using its handset or another
telephone on the same line as the
phone.
• You can also listen to the message
recorded on Line 2 by making a call
to Line 1’s number (or vice versa).
USING THE TOLL-SAVER
If RING TIME is set to TS (toll-saver),
(see “Setting the Number of Rings” on
Page 15), the phone answers after three
rings if you have new messages (ones
you have not listened to). If there are no
new messages, the phone answers after
five rings. This gives you time to hang
up before the phone answers so you
can avoid unnecessary long-distance
charges.
Note: Toll-saver works only on the line
you called. If Line 1 has no new messages,
but Line 2 has one, the telephone
answers after five rings when you
call Line 1.
USING REMOTE
COMMANDS
Follow these steps to operate the phone
from a remote location.
Note: If you wait more than 15 seconds
between keypresses, the phone sounds
a long beep and hangs up.
1. Dial your phone number and wait for
the phone to answer.
2. If the phone is not set to answer
calls, it answers after about 10 rings
and sounds a series of beeps.
3. When the outgoing message begins
(or the phone sounds a series of
beeps), press #, then enter your PIN
within 2 seconds.
If the PIN is correct, the phone announces
the day and time, then it announces
the number of new and old messages.
The phone plays all new messages,
then beeps about every two seconds to
let you know it is ready to accept remote
commands.
Notes:
• If the phone does not respond, try
entering your PIN again. If you enter
an incorrect PIN three times, the
phone beeps and hangs up.
Remote Operation 27
• When the phone is operating from a remote location, it stops all answering functions
and rC appears on the display on the base. The phone resumes answering
functions when it is no longer in remote operation, if you have not turned it off.
• The remote playback of incoming messages is limited to 4 minutes. If you have
more messages after 4 minutes have passed, you must press # 2 again to listen
to the rest of the messages.
• When using remote operation, you can only delete the current message during
playback. You cannot delete all the messages stored at one time.
The following table shows the remote commands you can use.
Note: Remote operation stops when someone picks up the handset and presses either
LINE 1 or LINE 2 (whichever is flashing), or any phone on the same phone line.
Remote Commands
Press #
then (within
2 seconds:
Function
Repeat current message during playback.
2 Play messages.
3 Skip current message during playback.
4 Delete current message during playback.
5 Stop playback, recording, and room monitoring.
6 Set the phone to answer or not answer calls.
7 Record or stop recording a new outgoing message.
8 Play the outgoing message.
9 Switch to the other line (Line 1 or Line 2).
0 Monitor the room where the phone is located for 15 seconds
Mar 19, 2009 | Lands Phones
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Feb 05, 2009 | Panasonic (KX-TG1032S) Phone
ANSWERING A CALL AND NON FUNCTIONING ANSWERING SYSTEM
no make or model listed
on many phones there is an ability that when the phone is picked up it is automatically connected to the caller and pressing the answer button is the same as hanging up
as for you second point , if a caller rings but hangs up before the message beep or after the beep but hangs up , there will be no message recorded
Nov 15, 2017 | General Electric 29115AE1 1.9 GHz 1-Line...
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
SW Bell FA-980 Answering Machine
Here is a link to a similar model: http://www.swbfreedomphone.com/ib/ibansw/fa970.pdf Here is what it says: TONE REMOTE OPERATION Remote Security Code To access answering functions from an outside line, you will need to enter the three digit security code located on the bottom of your unit. Write this number on the Remote Access Card, which you can keep in your wallet. Remote Turn On If you forget to turn on your unit: 1. Call your unit from a touch-tone phone. 2. Wait 12-14 rings until the machine answers. 3. The FA970 will automatically answer by playing your greeting. You may hang up the phone, and subsequent calls will be answered. Remote Message Playback 1. Call your unit from a touch-tone telephone. 2. After your FA970 answers, it plays the outgoing greeting and beeps once. Dial your three digit security code within 20 seconds after the beep, pressing and holding each digit for 1-2 seconds. Allow a 2 seconds interval between each digit. 3. Your FA970 will sound one beep to indicate the code was entered correctly. (If there are no beeps, enter your code again.) 4. You can press the following buttons on your keypad: Option Press Playback Mailbox 1 Messages (1) Playback Mailbox 2 Messages (2) Record Memo Message (3) Record New Greeting (8) Turn Off Answer Mode (9) If you press ?1? or ?2? (to playback messages), you have the follow options: Option Press Erase Current Message (0) Repeat Current Message (4) Repeat Previous Message (4) repeatedly Stop Message Playback (5) Skip to Next Message (6) To SAVE messages, hang up the telephone. Note: Your FA970 will sound a series of beeps if there are no messages. Remote Record New Greeting If you press 8 (to record new greeting): 1. When you hear a beep, begin recording your new greeting (up to 30 seconds). 2. When you have finished recording your new greeting, press (5). The unit will beep, and the new greeting will playback to you. 3. Hang up the telephone. Remote Record Memo If you press 3 (to record memo message): 1. Within three seconds of pressing ?3?, press ?1? or ?2? to select Mailbox 1 or Mailbox 2. Otherwise, the memo will be recorded in Mailbox 1. 2. When you hear a beep, begin recording your memo (up to 60 seconds). 3. When you have finished recording your memo message, press (5). 4. The corresponding Mailbox message count will be increased by one. To Retrieve Messages when Recording Memory is Full 1. When the message capacity is full, the unit will sound 3 beeps after answering the phone. 2. Within 20 seconds after the 3 beeps, dial your 3 digit security code. 3. Your FA970 will sound one beep to indicate the code was entered correctly.
Mar 22, 2007 | Southwestern Bell FA970SN Digital...
Lands Phones Logo
274 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
