Question about Honeywell Heating & Cooling
Honey Electronic Air Cleaner #F50A1074 After cleaning, there is now a strong ozone odour that doesn't dissipate. So much so that we are not using it any more. Went to Enerplace Inc with the filters and they looked okay. The tech at Enerplace suggested that it could be the power supply output that is too strong. What do you think and if so, about how much would it cost to replace the power supply
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Living Air XL 15, no ozone
My XL-15 had the same problem a few years ago. I had a broken wire on the fan, and the Ozone problem turned out to be a problem with the power supply. I had to send it in to have it repaired.
Posted on Jun 06, 2008
Exidous
  • 63 Answers
SOURCE: How do you change the
here is a complete manual.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-0756.pdf
Posted on Oct 06, 2008
machtcl1
  • 61 Answers
SOURCE: Connecting electronic air filter to furnace fan
You may need a "current sensing relay" to clip around the neutral wire on your blower.
Run the 120v power to the main power (the power switch- hot,neutral and ground) . Run the Hot wire through the "Current Sesing Relay" wires to the EAC unit's 120v. power input. The unit will only run when the fan is on.
Hope this helps,
Matt
Posted on Jan 01, 2009
machtcl1
  • 61 Answers
SOURCE: cleaning electronic air filter
What brand and model is the air cleaner?
Often you can find the mfg. website and download the .pdf file of the manuals.
The air cleaner will be located on the return air duct of the furnace and should have a nameplate and a model# somewhere.
Some use disposable filters and some need to be cleaned with dish detergent and can be very fragile. Hope this helps.
Matt
Posted on Jan 04, 2009
Renault grand scenic - ac smells damp and odour - like bacteria
This vehicle's ac system has a condensation drain. Have your mechanic check it for blockage. Quite common on all vehicles for this to happen. Once the blockage is cleaned, run the heat on high to dry the ductwork out. The odor should dissipate slowly.
Nov 12, 2013 | Renault 181 Cars & Trucks
Tip
Air Electronic Cleaner - Electronic Whole House Air Cleaner
An electronic air cleaner can improve the indoor air quality as well as the performance of your heating and air conditioning system. That’s why many people are now investing in electronic air cleaners, to treat the air in their homes and minimize pollutants. Polarization technology now also effectively removes mold spores, bacteria, smoke and carcinogenic particles that other filter systems will not easily stop.
If you or someone in your family has health issues that relate to air quality, then an electronic air cleaner is the way to go. If you are installing a new heating or air conditioning system, then make sure you have an electronic air cleaner installed with the new system. If you have an existing hot air heat or air conditioning system, then you can have an electronic air cleaner installed in the old system. The new filter can be easily installed in most hot air heating systems.
An electronic air cleaner can clean up many bad things in the air that normal filters will not catch. For best results make sure to clean the plates often. The effectiveness of the air cleaner will degrade as the build up of dirt accumulates on the plates. Clean plates will give much better results. Electronic air cleaners can be effective in removing smoke and odors also. The only downsides to an electronic air cleaner that I have found are the noise (snapping or popping) and the creation of ozone in some instances. The noise you will get used to after awhile. The ozone will be stronger if the air cleaner is too large for the building. If it is a problem, either speed up the air flow or install a smaller air cleaner.
When installed into your home’s heating and cooling system, an electronic air cleaner traps and filters up to 99% of airborne particles passing through the system to make sure cleaner air is distributed to all rooms in your home. When this air goes through an electronic air cleaner, the pre-filter traps the majority of the large particles. The particles that are too small to be trapped in the pre-filter are charged positive, and then attracted to negatively charge plates.
This advanced air cleaner captures microscopic impurities like dust, smoke and smog particles in addition to larger particles like mold spores and cat dander. Plus, you can say goodbye to monthly filter replacements by simply washing the air cleaner cells in your dishwasher or sink. If you have pets, smokers, allergy or asthma suffers in your home, you may want to think about a whole-house electronic air cleaner.
Electronic air cleaners overall are a great way to filter the air that you breathe and make sure that the quality of the air in your home is the best quality.
on Jan 02, 2010 | Heating & Cooling
Hello, there. I have a 2009 Mazda cx-9, and I was running AC quite a bit in the last year and I noticed it has strong odour from the ac vent, when the AC is on, there is no smell, when I turn off the AC...
You need to clean your A/C main vent from center console using a special A/C cleaning equipment with ultrasonic waves. Here in Europe it's easy to find a workshop with this special A/C cleaning equipment with ultrasonic waves. I suggest you to search a workshop in your area, and ask them for this special A/C cleaning equipment with ultrasonic waves.
Sep 07, 2011 | 2008 Mazda Cx 9
Every time I clean the filter and the plate the ozone doesn't come on. I usually can fiddle with it and it will come on, but this time it didn't. What am I doing wrong and how can I fix it? this...
The plate is going bad. Sometimes it's just a bad part of the plate that has corrosion under it, try turning the plate and sliding in again. Sometimes that's all it needs. Sometimes it just needs to be brushed well, cleaned, and then blow-dried.
May 30, 2011 | Ecoquest Living Air Classic Air Purifier
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
I was considering Biozone for restrooms etc and I assumed,as your info.says that it would be odour free?Some I have seen are not odour free.Is it just a uv lamp system or is there some form of ozone...
the UV lamp does produce some ozone .. this one specifies .04 ppm .. thats not very much but might be detectable as a slight fresh air odor .. some other types use electrostatic filtering and some even have strong ozone generators .. ozone does kill bacteria, fungus and such and will freshen the air removing many odors but is not considered healthy in large or concentrated amounts or for prolonged periods .. the UV lamp will also kill bacteria and fungus without producing so much ozone.
Purifying Method: Photoplasma, UV, ions, and ozone.
Oct 09, 2010 | Biozone 500 Air Purifier
Meat spoiled over three week period in standup deepfreeze. Odour Contaminated freezer and general area with meat and fruit spoilage. Have cleaned everything with bleaches disinfectants and commercial...
use a strong solution of clorine bleach(in a spray bottle) to get into every nook and cranny/drainholes/drip trays/door seals and wipe dry(clorine is a gas and will dissipate within an hour or so)then wipe over interior with a damp cloth and plenty of bicarb,leave to dry and leave any bicarb residual inside fridge as this will absorb any smells left.leave door open for about a day in a warm (ish) room, this is the only way of deoderising......
Aug 20, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Ozone smell
When the unit is clean it will produce more ozone. If the unit is a bit oversized then it becomes worse. As an installer I have to be carefull to not oversize these units. O3 is harmless and actually will only stay in the air as O3 for about 1/2 hour. Because of this it will not build up in the air. O3 also in a powerful disinfectant and will help kill mold and bacteria in the air. As soon as the filter gets a little bit of dust on it the O3 production will become much less. Run your fan continuously for a day or so and it will go away.
Nov 15, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Heater exhaust emitting strong odour
sounds to me like you need to have some hardware looked at. Have you tried opening your case and dusting it with a can of compressed air ? If there is a lot of dust there, then it won't allow heat ( and there is a lot of it ) to dissipate. So you want to keep that area relatively clean.
Also, if your powersupply is going bad, it is time to replace. If you are smelling a strong odor, something is burning. You want to figure that out.
Jun 23, 2008 | Computers & Internet
Heating & Cooling Logo
116 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
