Question about NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter
Hi! I'm using Windows 7 OS. Also i have NETGEAR Wireless-N 300 JWNR 2000 router, which has been setup and running fine. Now i'm trying to setup NETGEAR Wereless-N 300 USB adapter WN111 and i can't., 'coz the system says that "The NETGEAR WN111v2 adapter is not found". I have the software for Windows 7 installed (downloaded from www.netgear.com/win7)
    Sergeant:
  • 247 Answers
Hello sir, I would try to install the driver in compatibly mode, right click on the setup file for the driver and select compatibility mode, then select use windows recommended settings, after this the wizard will detect any further compatibly issues and reinstall the driver.
Posted on May 29, 2011
  • 61 Answers
Hello antonhs2000,
I assume you went through the direct instructions located HERE. It does not suggest a restart anywhere on the page, so I would suggest doing that. I have always made it a habit to restart my computer after uninstalling drivers and installing drivers as well just to be safe.
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I bought a netgear jwnr 2000 yesterday and tried to set it up at my sisters house for her, so i could take the other netgear router with me. It didnt work. The only indicating lights that were working...
1. Reset the router to factory settings.
- Before you reset the router, unplug all the cables attached to it except the power cord.
- Make sure the router is plugged into the power outlet, then hold down the reset button at
the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the
router(LAN ports usually they are labeled by numbers and have the same color, just pick one).
If you pick number 1, check the corresponding light indicator at the front panel of the
router, make sure light 1 is also lit up if not choose another port at the back of the router.
3. access the router's setup page by typing http://www.routerlogin.net or 192.168.1.1 in the
address field of your browser and then press Enter. Type admin for the router user name and your password (or the default, password). Setup and configure the router again.
4. If you notice the connection is not stable or the lights on the router are still not
displaying correctly, you may update or reload the same firmware(program or software) on the
router. You may download the updated firmware from http://support.netgear.com , just type the
model of your router, choose the version, press enter then click on Downloads, you should see
the firmware available for your router. Make sure to use wired connection when updating the
firmware.
Sep 18, 2011 | NetGear WNR2000 Wireless Router
Can i use Dir 300 on a windows 7? my desktop's OS is vista while my laptop's is windows 7.. would like to know if it supports windows 7..
Yes, this product is compatible with Windows 7.
To note, if you are upgrading to Windows 7 from either Windows Vista or Windows XP check before installing that your Wired/Wireless equipment on your computer will have compatible drivers for Windows 7.
Sep 08, 2011 | D-Link DIR-300 Wireless Router
Problem with NETGEAR Wireless router WNR2000 and DSL hookup. If I run westell 6100 DSL router independentlly on my desktop [windows XP] it works fine. But when I go thru the netgear router, both my Desktop...
1. If you can upgrafe firmware on router that can fix your problem
2. you can go to netgear website for latest firmware on router(you can download from there)
Mar 03, 2010 | NetGear WNR2000 Wireless Router
Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear WGR614 Wireless Router
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
I have a laptop with windows 7 pro I'm trying to install a wireless g router netgear wgr614 with the cd. It is telling me that I need windows xp or 2000 to install. It wont let me install it with windows 7...
You really don't need to use the cd. Below is a link to the setup procedure:
You'll need to connect a PC with a cable to the router. Open browser and type in http://192.168.1.1 in the address bar. Input username as admin, the password is password. If you need more help, let me know. I'm leaving a link to the setup manual for your router below:
ftp://downloads.netgear.com/files/WGR614v9_SM_26Oct07.pdf
Dec 30, 2009 | NetGear WGR614 Wireless Router
Can the wirless n router be used on windows 7
depends ...
Most likely, yes. There are connection issues you must address. Is your computer wireless ready? If not, you will have to install a wireless device in your computer. For a lap top it may be on a card or USB based. For a desktop it will be PCI based.
If your computer is network ready (has a RJ-45 outlet in the back - looks like a phone jack only bigger), and your computer is close by your modem - you are LOTS BETTER OFF using wire than wireless.
Why?
Speed. Security. Ease of setup.
Wireless runs at 10 on a good day. Wireless is limited to 300 feet radius (good circumstances). Wire runs at 100 or 1000 all the time. 600 feet radius.
Thanks for your interest in FixYa.com
Please vote
Dec 24, 2009 | NetGear WGR614 Wireless Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Computer, xbox live setup
the easiest way is to use another computer connected to router in any way.
windows xp os.
click start/run type in : cmd
then type in : ipconfig
there is the default gateway number.
Jan 26, 2008 | NetGear WGR614 Wireless Router
NetGear WN111 (DHWN111100NAS) Pre-802.11n Wireless Adapter Logo
214 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
