Question about Element Televison & Video
Hello i have an element 37'' tv and i have to unplug the tv several times just for it to turn on. There is a steady red standby light on but when you try to hit the power button it doesnt respond via remote or on the tv panel itself. The only way it will turn on is from a constant plug and unplug of the power cord. Please help?
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 29, 2011
The standby light on our Luxor Combi is flashing pink and the tv will not turn on either via the remote or on the tv. The standby light is normally steady blue when in standby. Steady red when in operation...
Flashing of standby light are fault indication, and is called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks carefully for at least 3 times switch ON / OFF. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Blinking codes details to many popular brand TVs are given in detail.
Oct 28, 2013 | Televison & Video
Blinking red
What is the brand name to your TV? Provide more details please. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. More than Nine and half Lakh viewers cannot be wrong.
May 14, 2013 | Televison & Video
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
My Sony KDF-50WE655 does not turn on. Only the standby LED Flashes several times and then goes steady green, but the lamp light remains off.
Hello
You just count the number of blinks of the standby light before it goes out to green. In sony sets this blinking count ic critical for us to locate the faulty stage. You just count it after switch it Off by Power switch and Switch it On by the power switch at the front of the TV, for at least three or four times, and make sure abut the number of blinks, and report it to me. Ok
Nov 14, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
Televison & Video Logo
135 people viewed this question
Top Element Televison & Video Experts
Joseph Hoffmann
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
