Question about Sony Playstation 3 (PS3) Console
Ps3 The red standby light is on but when I push the power button the green light comes on for about a second then everything shuts off.
This happened to me today also. Strange. Sony claims it means it has overheated. Check the vents are not clogged and use a vacuum on them. If it still does it call them for repair. Still within a year warranty and you have the original reciept - they will repair for free. If not it'll cost $150 for repair.
Posted on Aug 17, 2008
    Master:
  • 623 Answers
Just take it to a technician,no diy's for this...
Posted on Aug 16, 2008
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
Aug 18, 2012 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up and everything it comes on but it won't come up on my tv screen, BUT EVERYTHING IS HOOKED UP, The hdmi cable is plugged in to
Please do the following steps to reset your PS3 display :-
Turn the PS3 off into standby mode (red light on)
Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Wait for the PS3 to detect your HDMI cable.
Hope this helps and thank you for using FixYa
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
unplug the tv for 10 mins to let the tv reset then
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
Red light comes on but the shuts off?
Mine did that and it really pised me of, sony told me to turn the power switch onthe back of the console on, when the stand by light comes on to push and hold the on button for at least 3 seconds until you hear a second set of beeps. This however didn`t work so I sent it back to Sony Australia and got it fixed up no worries.
Oct 11, 2008 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
On my PS2 thin the red standby light is on and I push the button to turn it on, the light turns green like usual, but only for a second and then the light completely shuts off as if it was unpluged, after...
Try pulling the power adaptor out of the back of the ps2 ,then make sure no dust or debree is in the part that plugs into the ps2 then plug it back in and make sure its attached firmly. The ps2 should turn on now
Jul 12, 2008 | Video Game Consoles & Games
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
