Question about Symbol Computers & Internet
My problem is, my wire of barcode symble scanner is deffective, i want repair it and change it to new usb, hwo to change usb from the end rj11?
  • Symbol Master
  • 5,660 Answers
A USB connector uses 4 pins.
It may have 5 pins in it, (Depends on the style of USB connector), but only 4 are used.
http://pinouts.ru/Slots/USB_pinout.shtml
The number 1 pin is used for 5 Volts. 5 volts is transferred from the computer through the USB cable on Pin 1.
The number 2 pin is used for Data transference.
The number 3 pin is also used for Data (Information) transference.
This is DC electricity so there is a Positive connection, and a Negative connection.
Pin 2 is the Negative connection.
Pin 3 is the Positive connection.
Pin 4 is used for Ground.
Suggest you match up the style of connector you have with the illustrations on the link.
Find Pin 1.
Look at your existing USB cable, and note what color wire goes to what pin.
Write it down.
Use the above to replace the USB cable.
For additional questions or clarification to what has been stated, please post in a Comment.
Regards,
joecoolvette
Posted on May 29, 2011
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
Sep 14, 2011 | Metrologic Instruments Eclipse MS 5145...
I dint get connection with my pc. to my USB.. it is not recognizing
Does some other USB device work properly when connected to the USB port that you are trying to use with your Transcend Barcode Scanner?
Did you try to connect the Transcend Barcode Scanner to some other computer? If so, did the other computer recognize it?
If the Transcend Barcode Scanner is "brand-new", did the packaging for it come with a CD-ROM that you need to use -before- trying to connect the Transcend Barcode Scanner to your computer?
Aug 19, 2010 | Computers & Internet
I have Symbol scanner(1908T-I300) USB Type. It can read bar code but can't move next cell or line when testing Excell or Note Pad.
In the barcode is usually no order, which would say to the computer to change to new line or cell.
You would need to add an suffix to the barcode, check the manual for the procedure or use the following tutorial http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=12295&sliceId=SAL_Public&dialogID=189588227&stateId=1%200%20189576907
Aug 16, 2010 | Symbol LS1908T Wired Handheld Barcode...
I have a royal alpha 9500 ml cash register and also a royal PS700-USB hand held barcode scanner. Everything worked great yesterday getting my barcodes in the cash and stuff, but I unplug it by accident...
the scanner comes with a programming card, just scan the barcode to start programming, then scan the barcode that says usb and then scan the barcode that says end programming, and it will start working again
Aug 11, 2010 | Royal PS700-USB Handheld Barcode Scanner
Microsoft Metrologic MS9520 Voyager Barcode Scanner problem
If it is using the MX009 USB Cable it wont scan with the standard configuration. You will need extra configs such as enable Rs-232 Mode, Enable Xon/Xoff handshaking etc..
These can be found on the www.Metrologic.com website which will divert you to Honeywell website
May 25, 2010 | Microsoft Metrologic MS9520 Voyager...
Need an adapter that changes a connection from PS2 to USB.
p/n 42206202-03e is the usb retail lenght, but there are other options
Kim Ganoe 800.933.2839 x251
www.datexcorp.com
Mar 17, 2010 | HHP ImageTeam 3800LR-12 Handheld Barcode...
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
SCANNING PROBLEMS
We are major Symbol/Motorola dealers...I can help. I don't understand your question. (By the way, by changing the cable on your keyboard wedge models, you can also use them on the USB ports. Give me a call at 1-866-306-7226, or you can also contact the Help Desk at 1-800-653-5350
Cheers.
Bill Matisz,
qdata inc.
Edmonton, AB
Mar 03, 2008 | Symbol LS2208 Handheld
Computers & Internet Logo
293 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
