Question about Sansui Audio Players & Recorders
I have a 9090 receiver that powers on but no sound output. this happened before about 20 years ago and it was a simple fix but i dont remember what it was
    Brigadier General:
  • 8,546 Answers
Was the 'fix' a hardware repair or a switch position? You should at least remember that.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through defect or idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Posted on May 29, 2011
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
Why is my monitor shuts down after a few minutes of use?
It sounds like its shortiung out my freind Dust is a horrible little "feind" and is not computer/electronics freindly
May 07, 2014 | ASUS VE208T 20 inch LCD Monitor
All the lights are not working found 2 blown fuses / replaced still not working the power lite flashes red then turns to green
When a fuse blow suspect an overload. In an amp this old it will certainly be one (or more) of the main output transistors that has shorted.
Sep 25, 2013 | Sansui 1976 9090 Receiver Amp Vintage
I found an old Sansui 9090 receiver that I'm told is a great receiver. It looks like it's still new but it hasn't been used in several years. I have one speaker plugged into the input, and it is...
Speakers don't plug into inputs. Check your work.
Try powering it up with nothing attached, then proceed to attach things (like a speaker to the speaker terminals) and see what happens.
Feb 01, 2010 | Audio Players & Recorders
Just bought a 9090 at a flea market; everything lights up, including the red "protection" light at the power button, which flashes. There's no sound, and the power meters don't budge.
The outputs are probably shorted. This unit requries service. I can say though, that once repaired, you will love this unit. Expecta repair cost inteh $150-$200 range. It is worthy it. If the unit is in good condition (appearance), than it is worth $400+ when working.
Dan
Oct 13, 2009 | Sansui Audio Players & Recorders
No sound output
hiya
have you checked the thermal fuses inside... they may of blown replacing the fuse may sort this out
Feb 26, 2009 | Audio Players & Recorders
Audio out problem
sounds like your sound output ic may have gone.this is normally connected to a heat sink.also check that sound output settings are ok before you go further
Feb 08, 2009 | Sony STR-DB780 Receiver
Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Dec 29, 2008 | Marantz SR-19 Receiver
BOSE | Radio
have heard of this but honestly dont remember much about it as this was many years ago in car rental but if i remember it was to do with resetting the radio ,their was 2/3 settings but to set it ??something to do with audio output for classical music
Oct 23, 2008 | 1996 Audi A6
RCA Home Theater Receiver won't work
I had the same problem but it happened 2 years ago. i went out and bought a new receiver for $200. The RCA receiver has flaws and isn't worth fixing
Jan 24, 2008 | Audio Players & Recorders
107 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Josh Whitehead
Josh Whitehead
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
