Question about Nintendo Video Game Consoles & Games
Error code 51301 when trying to set up WIFI connection between DS and a 2Wire router
    Sergeant:
  • Nintendo Expert
  • 260 Answers
Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area.
for more help visit CBR Tech Solutions
Posted on Nov 04, 2015
  • 12 Answers
SOURCE: cant connect ds lite wifi with homehub2
the codes online are not always right
Posted on Dec 28, 2008
  • 161 Answers
SOURCE: Wifi not working
usually, yes, it's a coding goof. cheat devices can crash consoles and peripherals. if it was a hand entered code, rather than an "on the software", one error will render it useless. also, some codes, when activated clash with each other and crash. try using a minimum of codes, or onr at a time, and see if that works.
Posted on Jun 11, 2009
  • 33 Answers
SOURCE: cannot get a DS to connect to my router.
Our experience has shown that this error message is typically caused by a basic setting in your router, such as transmission rate. Please carefully read the instructions below:
  • Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router Configuration page.
    2. Use the drop-down box on the left to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  • If the router is not listed on our pages, or has no suggested basic rate and transmission rate changes, log into the router, and check likely areas for the basic rate and transmission rate. (e.g., "Wireless Settings," "Advanced Wireless Settings," "Connection Rates") Change the basic rate to "1-2." Change the transmission rate to "2." (Make the change even if only one of those options is available). Test the connection.
  • Another device may be sharing the same I.P. address of the DS. Try manually assigning an IP address to your Nintendo DS.
    1. The first thing you'll need to do is find out the range of IP addresses you should be using. To do this:
      1. Click the "Start" button in the lower left-hand corner of your computer.
      2. Click "Run."
      3. Type "cmd" into the box and press Enter.
      4. Type "IPCONFIG/ALL" and press Enter. The IP address of the PC will be displayed.
      5. The IP address you are going to assign to the Nintendo DS must be 10 digits higher than the PC's. (e.g., 192.168.1.100 becomes 192.168.1.110).
      6. Enter in the exact same values for your Subnet Mask, Default Gateway, Primary DNS and Secondary DNS as you see listed on your computer screen for IPCONFIG/ALL.
    2. You will now need to manually assign this new IP address to your Nintendo DS. For step-by-step instructions on how to do this, please click here.
  • Ensure you have entered the correct DNS into the DS's manual settings. You can verify this by using the steps listed directly above (IPCONFIG/ALL).
If you are still unable to connect, please call 1-800-255-3700 in the USA or Canada for more information.
Posted on Mar 13, 2010
  • 14 Answers
SOURCE: connection error code 51301
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);This error is caused by issues with the WEP Key of your wirless network.
To solve this error :
Try changing the channel of your wireless router to either channel 1 or channel 11 which can increase download speeds.
If your router is using WEP encryption
  • * Ensure your key is hexadecimal, consisting of 0-9 or A-F only, no other special characters or letters.
  • * 64 bit encryption requires your WEP key to be 10 characters consisting of numbers or leters A through F.
  • * 128 bit encryption requires your WEP key to be 26 characters consisting of numbers or leters A through F.
If your router is using MAC filtering, ensure the DS MAC address has been added to the list of approved MAC address on your wireless router settings
Set your router settings to "mixed" or "b and g" mode when using connection files 1,2, or 3 .
Posted on May 02, 2010
  • 56 Answers
SOURCE: i cant get my nintedno ds to connect to my router
The problem may be your security settings. The Wii and PSP can access WiFi no matter what the security settings are if you have the key, but the DS can't access highly encrypted WEP security. Double check your security settings and then re-input your code.
Posted on Jun 22, 2010
Ds lite wi fi connect wpa
Try changing your WiFi encription to WEP or no security, this should be available on your cablemodem/router web internface (need a user and password for that) under the Wireless/Security option.
DS Lite is not compatible with any other WiFi encription for online gaming: "Important note about the Nintendo DSi and WPA security: While the Nintendo DSi is compatible with WPA security, Nintendo DS games with online play still require the use of WEP or no security to connect with the Nintendo WFC. Therefore, your connection settings for using these games must be set up on slots 1-3. If you need more details on using your adjusting your router's settings,click here and select your router (if available).
Nov 04, 2013 | 2wire Computers & Internet
I cant connect my ds to router
you may need to manually input the ip adress or MAC of router in ds. on on your cpu, you can look up your router and its properties, record ththe type of securtiy or encryption, the pass word, mac address and ip address .
On ds, check to see if ip auto config is enabled or DHCP enabled. if after scanning and connection faills, manually configure wifi settings to mmatch those found earliear on your cpu running the router, entering the mac, ipaddress ect. also be sure you are not to far from the router and the wife switch is turned on somewhere on side of unit so the wifi arcs symbol is iluminated or lit up
Jul 13, 2012 | 2wire Computers & Internet
Is there a fix to wii error code 50300 ?
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
If the problem persists, try our general troubleshooting for tips.
If you are still getting this error code, please call 1-800-255-3700 for further assistance.
For more help visit cbrtechsolutions
Mar 27, 2012 | Belkin Surf N300 Wireless N Router
Connecting to a "2WIRE" wifi connection. Says the
I understand that you are having trouble connecting your Nintendo DS wirelessly to your 2Wire router. The solution is simple, your Nintendo DS only supports WEP (Wireless Encription Passkey) security. It is highly possible that your 2Wire router's wireless security is set to WPA. That means you will need to reconfigure your router so that it will be utilizing WEP as a security for your wireless connection. To be able to do this, you need a couple of information from the one who setup your router. 1. User name of your router 2. Password or your router.
Once you have gotten this information, you will need to access your router configuration page through one of the computers that is linked to your 2Wire router by typing http://gateway.2wire.net on the address bar of your browser.
It will be asking you for the username and password. If nobody had setup or changes the username and password of the router, use this default username and password of a 2Wire router. Username: (none) Password: Wireless or Username: 2Wire and Password: (none). Try any of the two. If it does not work, try admin and the word password for the password or any other combinations of the two.
Once you have entered the router's configuration page click the Home Network Tab and then click on Wireless Settings. You will see there a portion that says Wireless security. In that area, you will see a drop down where you can choose what kind of wireless security you want on your system. As I have said, the Nintedo DS does not support any other wireless security setting but WEP. That means you will need to change the drop down to WEP. That also means after changing this, you will need to reconfigure your other wireless devices (like your laptop) to use WEP as well.
Jul 21, 2011 | Nintendo DS Lite Console
I dont know how to set up the nintendo wi-fi connection
  1. At the Setup screen, tap "Nintendo Wi-Fi Connection Settings."
  2. Tap "Connection 1 None."
    emptyconnections.jpg (Don't see "None" for Connection 1? To ensure any existing settings don't interfere with getting connected, tap the button, then choose "Clear Settings.")
  3. Click on "Search for an Access Point."
  4. The Nintendo DS will search for any wireless networks within range. Once it is finished searching, it will display the names of all the wireless networks it finds.
Once you have done this you may find next to your wi-fi, a lock this is what they mean:
unlocked_g.png No security - Your wireless network is unlocked.
  1. Tap on your network name to select it.
  1. Select "OK," "Save Settings," and then "Yes." The Nintendo DS will run a connection test with your wireless router.
  • The connection test was successful - Your Nintendo DS is now connected online and you can enjoy the Nintendo Wi-Fi Connection features of the game!
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51300: This means the security code or network name entered into the Nintendo DS is not the same one the router is set to. To reach your connection settings, click "back" on the error code screen. Make sure to pay extra attention to the security key you find in your router's settings and enter it exactly as it appears (the key is case sensitive).
    • All other error codes: Try our error code lookup where we have detailed information on many common error codes.
wep_g.png WEP security - Your wireless network is secured with WEP and requires a security key.
  1. Enter your router's WEP key into the Nintendo DS Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands Enter your WEP keyOn the upper screen you will be informed that "A security key is needed to connect to this access point." Enter your security key by tapping the empty field, and select "OK" when finished.
wpa_g.png WPA security - Your wireless network is secured with WPA and requires a security key.
The Nintendo DS and Nintendo DS Lite are not compatible with WPA security. If you would still like to connect your Nintendo DS online, you will need to either change your router's security to WEP, or disable security entirely. Please note that any changes you make will affect other devices that connect wirelessly to your router.
Jul 05, 2011 | Nintendo Video Game Consoles & Games
Pokemon wifi error code51099
Look on your ds pokemon game. go under where it says "new game" and it will say Nintendo wifi settings. Choose your network. If the error shows up again, try going closer to the wireless router. That should resolve your problem.
You can also try resetting your router, and changing the security settings of it from WPA to WEP. Though it should be noted that WEP has very little security, but is the preferred DS connection method.
Mar 12, 2011 | Nintendo DS Lite
Yes im trying to connect to the internet on nintendo ds xl it as an error code 051310-1what can i do
Make sure the security key and security type are entered into the Nintendo DS exactly as they appear in your router's settings.
Let us help! Select the brand of your router below and we'll show you how to access your router's settings. Linksys Netgear DLink Belkin Apple 2Wire All other brands
    Once you have entered the correct WEP or WPA key into your system, try the connection test again. If the problem persists, keep reading this page.
Additional information:
  • Using an Actiontec or 2Wire router? The default security key is often found on a sticker located on the router.
  • Security keys are case-sensitive.
  • WEP keys contain numbers 0 through 9, and only letters A through F.
Feb 20, 2011 | Computers & Internet
Connection error code 51301
May 01, 2010 | Nintendo DS Lite
My 2wire router will not connect to my nintendo ds wifi system.
The DSi only works with WEP encryption. The 2Wire and most other newer routers use WPA encryption.
Simply logon to your router with a web browser. The default IP for it is 10.1.1.138 but it might be different, just check the manual or internet for the IP. Go to "Home Network" then "Advanced Settings" and change the security from WPA to WEP and save.
Thats it!
Hope that helps.
Nov 18, 2008 | 2wire (1000-000057-000) Modem
Video Game Consoles & Games Logo
441 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
