There are more than one markings on the right side of the key board. How do we operate each one
  • Ben Beharrell May 29, 2011
    You will need to provide more information about your keyboard or type of computer you have. What is the make and model of your computer? If you do not know that, what do the symbols look like? They may be controls to a music player or web browser.
  • 159 Answers
If your refering to the number pad that is fast becoming a feature of new laptoops then press tthe numlock button on said keyboard. if what you refer was to the multiple optioons on a single key then you would need to press and hold alt button thenn press the key that has the option you require
Posted on May 29, 2011
Drivers information display doesn't work
I researched and finally found a fix for non functioning Driver Information Center.
The solution was similar to that found for similar modules on other brands of vehicles.
Remove the Driver Information Center Module
(See GM manual for procedure)
Push back clips from black housing box and carefully remove circuit board
Place circuit card flat on table.
Place display and component side of circuit board facing up
Rotate circuit board so the display module side is facing you
There are button switches on either side of the display module
Look at the right button switch.
Next to it just left and above are four 1/4" X 1/8" black components attached to the circuit board
They are marked 430, 430, 820 and 820 reading from top to bottom.
These are resistors with 43 and 82 ohm values.
On the two modules I have repaired the problem was with the top most resistor. It is marked 430 and is 1/2" above and 1/4" to the left of the right button switch. The soldering to the circuit board had fractured. I resoldered the resistor into place using a bit of solder and 15 Watt pencil soldering iron.
All fixed.
The problem is NOT the black spot on the display in the upper left corner
The problem is NOT the DC to DC converter modules.
Aug 29, 2012 | 1999 Chevrolet Venture
Iam trying to get the black slash and question mark what keys do i use to get them
Depending on setting, assuming that the keyboard is set to United States, the ? and / key are next to the shift key on the right side, bottom row. For a question mark hold down the shift key.
I hope this is helpfull
Jul 27, 2011 | Computers & Internet
I have an acer aspire 7551-2755 and cannot for the life of me find out how to insert a ``question mark`` or the ``backspace`` hyphen mark
The question mark is the key that sits to the left of the right hand side "Shift" key. Use the shift key by holding it down, then hit the question mark key once while holding down the shift key. Let the shift key go, and you should see a question mark displayed. The hyphen mark key is the one to the right of the zero key. It is also called a minus key.
Bruce
May 04, 2011 | Computers & Internet
How to find out ram? of my dell laptop
There are two straightforward ways to figure out how much RAM your computer has installed and available to Windows XP, actually. The first, and probably the easier, is to go to START --> Control Panels and choose System.
Double-click on that and the very next window you'll see will indicate your available RAM, listed under "Computer".
Hope this helps! If it did, feel free to rate me. Thanks for using FixYa.
Mar 14, 2011 | Computers & Internet
How do find the question mark on an Acer Computer keyboard
The question mark can be found on the bottom left side of your keyboard on the same key as the " / " it can be used by holding shift and pressing that key.
Feb 28, 2011 | Acer Aspire 3680 Laptop
Drivers
Go to http://support.asus.com/download/download.aspx?SLanguage=en-us
and Type the model of *********** board (P5GC-MX/1333) in search box and click on search info button.
Wait for sometime . you will get *********** board number on the right side
Click on the mother board number and wait for sometime. it will ask you to chose your operating system. select operating system and click on search
Now you will see all availabe driver for the chosen operating system.
Click on the + mark near the device of which driver you wanted.You will get all the details like version , release date and download links also.
Chose any downlaod link and you will have to enter securitycode. Then click on download . you can download drivers easily
Aug 15, 2010 | ASUS P5GC-MX/1333 - Motherboard - micro...
What button makes an apostrophy
Look to the left side of the right side enter key....you will see the apostrophy on the bottom and the quotation mark on the top. Apostrophy will come up without hitting the shift key and the quotation mark will come by hitting the shift key + the quotation key.
Jun 29, 2010 | Acer NSK8458AN Keyboard
How do I use the question mark key all i get é
Dear it is very easy first press the shift key and hold it and then press question mark key on right side. Both keys should be press but sift key first and then second key that is question mark key on right side with shift key.
Good Luck
Nov 26, 2009 | Acer NSK8458AN Keyboard
Right key
5145ad1.jpg Just use a usb key board or use ps2 keyboard by usb to ps2 convertor and open bios function by F2 key and change boot option to usb then use an external cd drive and insert windowsXp cd and follow intruction of installing windows
Sep 19, 2008 | Intel Dot Station (INTC300AIO) PC Desktop
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
