Question about Mitsubishi VS-60607 TV
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
  • 345 Answers
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: i thought i might need - captainhawk1_15.jpg
Posted on May 29, 2011
VS-60607 turns on then off
2,1 is X-ray protection or excessive High voltage
It is a circuit repair or may be related to a Glycol leak
Mar 13, 2012 | Mitsubishi VS-60607 TV
MITSUBISHI TV VS-60607
HI there,
Check for any bad solder on the mainboard of the TV, and also check for any burn fuse on the powersupply area... BAd solder was very common problem on Mitsubishi TV..
micro
Jun 07, 2008 | Mitsubishi VS-60607 TV
TV IS SNOWNY WHEN I FIRST TURN IT ON AFTER 2-3 MINUTES IT CLEARS UP FOR THE REST OF THE DAY
the problem in that case are the CRT sockets this are the socket that connects the cathode lamp and the CRT board it is place at the tip of the cathode lamp..just replace them with a new one and the picture will be ok.
Jul 17, 2010 | Mitsubishi VS-60607 TV
Power interruption model vs 60607
These units have had issues with the Yoke plug connections on the Yokes being intermitent. I would advise only a professional to check it out.
Hope this helps,
Skyassoc
Jul 04, 2009 | Mitsubishi VS-60607 TV
My neighbor has this problem...Their 60" vs60607 Mitsubishi Projection TV turns on and immediately turns off. The timer light blinks when this happens. I looked at the troubleshooting where other people...
My big screen had the same problem. According to my service repair person, the units have a latent defect in the lamp seals. Apparently, the lamps are encased in a silicone based oil. When the seals at the bottom of the lamp housing fail, the oil leaks onto the main circuit board and shorts out the system. The board woudl probably need to be repair or replaced. Again, according to my service person, the manufacturer corrected the design problem in subsequent models by installing a plastic shield across the circuit board.
Jan 01, 2009 | Mitsubishi VS-60607 TV
Does the VS-60607 have a digital tuner
No it does not. Only mitsubishis with a digital tuner are the ones that have a DM inside.
Dec 12, 2008 | Mitsubishi VS-60607 TV
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
MITSUBISHI BIG SCREEN TV MODEL VS-60607 CUTS OFF FOR NO REASON
My mitsubishi 65in projector model # ws65807Just started shutting off it only stays on for few seconds and cuts off. I cant get it to stay on
Jul 31, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi VS-60607 TV Logo
193 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
