Question about RCA Televison & Video
How do you set up the tv for dvd use? Under the menu the setup options for dvd says N/A.
    Sergeant:
  • 247 Answers
When you connect a device to a newer model flat panel, it assumes a source input witch in your case it may be video1 video2 hdmi1 hdmi2 or component 1 or 2 and so on. Hit the source button on your remote and toggle it until your reach the input source your are plugged into.
Posted on May 29, 2011
How do I get digital channels instead RF channels on my TV DWM32H1G1
Have you hot a digital receiver connected to the TV.....Sky or Cable?
Jan 02, 2015 | Televison & Video
How do I reset settings for DVD-S661 when I am unable to get the setup menu to display on my tv screen. Is there a "blind" setting change option?
Are you you using a HDMI connection fromt eh DVD to the TV? if so are you changing the input on the TV to the correct HDMI port?
Oct 26, 2014 | Televison & Video
When I turn on my recorder and tv and then go to component on my tv all I get is a blank screen. I would like to know how to reset the recorder back to factory settings
To use the Setup menu:
1. Press the SETUP button to bring up the menu.
2. Once the menu appears, use the up and down buttons to navigate the sub-menus listed at the side of the menu.
3. Press > to enter a sub-menu. (Press < repeatedly to leave a sub-menu.)
4. Use and to select an item.
5. Press ENTER to bring up a list of the available options for the selected item.
6. Use up and down to select the desired option and then press ENTER to select it.
7. Press the SETUP button to exit the menu.
The following is a description of the contents of the Setup menu and their use.
Jan 20, 2012 | Protron PD-DVR100 DVD Recorder
I have no sound. Do i need to setup to run this dvd and get sound.
You better check first the sound setting.Try to set up dvd and check if there is a sound.If didnt work,maybe the problem is in the speaker, wirings,connector , amplifier or the sound signal.So its better to check inside the following.Thanks..
Aug 25, 2011 | Televison & Video
Hello. I switch an option, i switch to progressiv option and i dont see anithing how can i reset the DVD player? It is a piooner DV-300-K DVD player. Thanks for help.
According to the Pioneer FAQ for this item :
"You can reset all models of DVD Players with the following method:
1) Switch the player into standby and empty the disc tray.
2) Using the front panel buttons, hold down the STOP button and press STANDBY/ON to switch the player back on."
Mar 03, 2011 | Pioneer DV-300-K Player
The store demo mode is stuck on my insignia tv. the user guide says go to menu and then setup and select plug & play. however the plug and play option is grey and it wont let me select it.
Are you using an HDMI cable? Go to input and select TV. Then you should be able to access the Plug & Play option and be able to turn off the Demo Mode.
Jan 03, 2011 | Insignia 42" Flat-Panel Plasma HDTV
My player seems not able to upscale the signal from my antennea and DVDs
Upscaling will only occur when playing DVDs. You have to use an HDMI connection from the DVD player to the tv. For upscaling of DVD's you will also have to setup the upscaling resolution in the DVD player's setup menu. Be sure to set the resolution to one that your tv will support.
If your tv does not have a HDMI input, then you will not be able to use the upscaling feature.
Upscaling will not occur on antenna signals. This is not possible because the hardware (inside DVD player) is only meant to upscale DVD video.
Again, to upscale DVDs ONLY, you will have to have an HDMI cable going from DVD player to TV, set up your upscaling options on your DVD setup menu and have a TV that has a HDMI input and is capable of recieving the upscaled resolution you have set your DVD player to.
If you have any further question regarding this, let me know!
Oct 07, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Onkyo 705
You have probably done this, but have you changed the video settings in the setup menu to have the tv using HDMI out? I believe it is under the first option when the menu comes up.
Dec 23, 2007 | Onkyo TX-SR803 Receiver
Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Dec 10, 2007 | Sony Playstation 3 (PS3) Console
Programming channels
Press Menu, press up and down arrows to choose the Input Select option then press side arrows to set the channel. Tuner will automatically cycle through all available channels in your area. After the Auto channel search is complete make sure the Channel source is set appropriately (TV or CATV) by pressing up and down arrows and chossing the correct source by pressing the side arrows using the channel setup menu. Press Menu to return to the TV screen. Use CH/TRK arrows or CHANNEL arrows on the front panel to cycle the DVD+VCR through the channels in memory.
Sep 02, 2007 | Sanyo DVW-5000 DVD Player/VCR
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
