Question about Motorola Televison & Video
Motorola DCH 6416 HD Dual Tuner DVR cable box does not show picture. Displays du 1 on front of box. Cable company has been unable to fix it so far.
3 Suggested Answers
  • 3 Answers
SOURCE: i need remote control code number for motorola dvr 6416 III
If this is a remote by UEI or Atlas (usually the black remote that the cable company supplys with the box) the code is 1376.
To set the code, you will need to do the following:
Unlock the Cbl button:
Press CBL once. it will blink once.
Press and hold SETUP until CBL blinks twice. Release setup
Press 982
CBL will blink 4 times, indicating it is unlocked
Program the code in:
Press 1376
CBL will blink twice if the code is accepted.
Re-lock the CBL button:
Press 982
CBL will blink 2 times, indicating it is locked again
If it is not a UEI or Atlas remote, let me know the remote make and model
Posted on Dec 04, 2008
  • 41 Answers
SOURCE: Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
Posted on Dec 01, 2009
I have no IP. How do I fix this?
I'm unsure why you think it would have an IP address on the DVR. Does it actually have a network connection jack?
The manual doesn't reveal anything about networking:
http://www.nwtel.ca/media/documents/tv/dcx3510-m_user_guide.pdf
Feb 27, 2015 | Motorola Lot Of 2 Dch-3416 Hd Dual Tuner...
I'm trying to hook up picture in a picture with my TV using the HD dual tuner DVR DC H 6416 converter box. Is there a place that I can connect a cable to the box that has video out to use individually for...
The TV requires two inputs to use the PIP function. Your setup box Has multiple outputs, but the same picture comes out of all of them. The only way you can use PIP in your TV is to split the signal and connect it to both the set-top box and the TV. However; you will not receive the additional channels that the setup box picks up unless you use 2.
Some set top boxes already have PIP built in. If it does you can view a PIP display even if your TV does not have that feature. Because the cable box has 2 tuners built in they are designed to do two different things at one time. If yours has PIP capability they will proudly and prominently tell you about it in the instruction manual..
Nov 15, 2014 | Televison & Video
Dec 01, 2009 | Televison & Video
No sound
you need audio cable also (red and white).for each device
reply for more help bama46 please rate
Aug 19, 2009 | Audio Players & Recorders
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
May 30, 2009 | Toshiba 61A61 61" Rear Projection...
I need remote control code number for motorola dvr 6416 III
Press 982
Press 1376
Press 982
Dec 01, 2008 | Arris DCT6200 DTV Receiver
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Televison & Video Logo
Top Motorola Televison & Video Experts
Jaime Hernandez
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
