Question about Maytag M7DH65B2A Dehumidifier
Dehumid. runs and fan blows but no water in tank and never shuts off, 5yr. old maytag, only runs in summer
    Brigadier General:
  • 4,736 Answers
Several things can cause this problem. The leading one, is that the humidity extraction level is set to high. Lower it to 35%. One of the others, is a dirty or clogged air intake filter. Followed by obstructed air flow. You need to maintain at least a minimum of 12" clear air space around the unit. Also, most humidifiers struggle to operate correctly, if the ambient air temperature at floor level is between 40 to 60 degrees F. This will also cause the fan to run a lot if the unit is set in continuous mode, rather than a timed mode. And finally, if any doors or windows are open, the unit will run forever. Make sure all doors and windows are closed.
Here's an in home test to see if it's working properly. Move the dehumidifier to the bathroom. Plug it in turn it ON and set the humidity/moisture extraction level to 35%. Turn the shower ON hot enough to generate steam. Do Not turn the bathroom exhaust fan ON and close any windows that may be open. As you exit the bathroom, close the door. Wait 15 to 20 minutes before returning to the bathroom. Once you do, turn the shower OFF and allow the unit to run for 5 minutes more. Then check the bucket for any signs of water. If you find some, the unit is working as it should.
If you don't see any signs of water, the unit's compressor may need to be recharged with refrigerant.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 29, 2011
Why does compressor continue running, even with dehumidifier turned off?
So I just had this happen with my Frigidaire fad704dwd dehumidifier. I went to basement and heard it running and sounded off. The compressor was running fan was off which is bad and humidity said 30. I then pushed the off button and it stayed running. I was able to fix it. To make long story short it was a bad ground. I took the plastic back, sides, and front off. There was a green ground (main ground) and Green/yellow ground (fan ground) on the front coil with a bunch of rust. Removed the grounds connected them both together and cleaned the surface area and used a new stainless screw nut and screw to remount the wires to evaporator coil. Everything started working fine after that and I put it back together. Good Luck
Feb 16, 2016 | Frigidaire a/c fad704dwd 70 pint...
I have a 2 year old Frigidaire dehumidifier model FDM7051 and this summer when I turned it on it runs continuously with the fan moving normal amounts of air. The air filter and coils are clean and I have...
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
Jul 20, 2011 | Frigidaire Dehumidifiers
Dehumid. was working, went to empty it and now it acts like it has no power
If you mean you emptied it, and replaced the holding tank and now it doesn't work ... The holding tank probably didn't activate the safety trigger. Remove the tank and reinstall it, making sure that the tank triggers the safety switch. That should solve the problem.
Apr 05, 2011 | Kenmore 54701 Dehumidifier
Trying to use the hose rather than emptying the bucket but water continues to drip onto bucket even tho connection to hose appears snug
This may not help because I'm not sure of what you have, but most dehumids when using a hose hook to a fitting on the tank. If that's what you have, before you hook the hose you have to either punch a knockout in the center of the hookup on the tank or cut it out. Hope this helps.
Aug 30, 2010 | LG LHD65EBL Dehumidifier
Not condensing
Check to see if coils are getting cold, (run for 10 min. then unplug, and check inside unit). If they are, check and clean filter and coils. If not, most likely no economical to fix. Check consumer reports before buying a new one. New standards came in to play this year. Changed quality on the units.
Jun 02, 2010 | Maytag M7DH65B2A Dehumidifier
Fan runs but does not collect water
It sounds as though the compressor is not running or the machine is low or out of refrigerant.
May 26, 2010 | Maytag M7DH45B2A Dehumidifier
Unit fan is running but the compressor is not.
It could be a bad compressor, circuit board, or maybe even a sensor or dehumidistat...
Here is a tip about dehumidifiers that run but do not extract water from the air..
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 24, 2010 | Maytag M7DH45B2A Dehumidifier
Dehumidifier
Dear rmclpc
huuum at your service.
Here is a site offered by fixya.com for owners manuals.
http://www.pronto.com/user/search.do?displayQuery=
kenmore%20elite%20oasis%20owners%20manual&SEM=true&query=kenmore
%20elite%20oasis%20owners%20manual&adid=1210312579-6519660d_10_gc&ref=
owners%20manual&creativeid=1167763135&site=
www.fixya.com&loadingComplete=true
Bless You,
huuum
Please give me a good rating before you sign off here at fixya.com
Sep 17, 2008 | Maytag M7DH45B2A Dehumidifier
It runs but there is no water coming out. We have checked the hose for a blockage. What else could it be?
If the compressor is running but no air is blowing out, then your fan motor is shot. If the fan is blowing air but you don't hear the click and vibration when you turn it on, then your compressor needs replacing. Those are the most likely culprits.
May 29, 2008 | Maytag M3DH30B2A Dehumidifier
Goldstar dehumidifier won't stay on
Check the relative humidity in the room or space where you are operating the dehumidifier. Damp feeling and actual humidity level are two separated items. Humidifiers will run for a few minutes until it is signaled that the humidity is already low enough and then shut down.
Oct 27, 2007 | Goldstar DH504EL Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
165 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
