Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
Ge model ssl25kfpd bs it clicks and doesnt cool
4 Suggested Answers
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
Maytag317
  • 1136 Answers
SOURCE: GSL22JFRE BS Not cooling
Hi, Ifwhat you are getting is frost, remove the rear panel again and locate the defrost heater. There will be two wires going to it and it is fastened to the bottom of the evaporator coil.Remove the two phillips screws holding the heater and pull it out to remove the wires. Check the element for continuity. If there is no continuity on the element, replace it. If the element shows ok, locate the bi-metal switch that is fastened at the top of the evaporator coil. Test it and make sure it has continuity. NOTE: the bi-metal must be tested while it is cold.
The most common problem with this model is the defrost heater.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 20, 2009
2coolrick
  • 560 Answers
SOURCE: GE side-by-side PS123SGMD BS won't cool
Check the door seals to be sure they are in good working order. Close both doors on a dollar bill at several locations all around the door and pull on the dollar bill. You should have resistance as you pull it out in every area you check. If you have any gapped areas and it slides easily, adjust the door or replace the seals. Also, is the circulation fan in the freezer working correctly? Lastly, unplug the unit for 5 minutes to allow the control module to reset itsef. Then plug it in again and reset your temps, clock etc.
Posted on Jul 31, 2009
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
Ge model gsl25jfpb bs not getting cold
Is it plugged in Is the compressor running ? Is it cool at all? Is there frost on the back side of the freezer wall? If there is frost on the back wall of the freezer the defrost circuit is usually the culprit there is a heater or heaters under the back panel of the freezer compartment.they might need to be replaced
Aug 01, 2014 | GE Refrigerators
MY GE GSL25JFPA-BS SIDE BY SIDE REFRIDGERATORS FREEZER TOP PORTION IS NOT COOLING
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | GE GSH25JFR Side by Side Refrigerator
Back wall of frezzer covered with snow, removed cover, coils frozen over with ice. have to de-frost freezer every 3-4 wks. Model#: GSL22JFTA BS
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 11, 2010 | GE GSS25JFM Side by Side Refrigerator
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GSL22JFRE BS not cooling. I need help troubleshoot my GE GSL22JFRE BS cooling issue. I found a temporary fix from this website by open up the "frosting-panel" in the freezer and blow-dry out the ice. It...
Vic
Jun 20, 2009 | GE GSL22JFR Side by Side Refrigerator
Ge model gsh25jfrfww not cooling just clicking
Feb 21, 2009 | GE GSH25JFR Side by Side Refrigerator
I CAN'T REGISTER HANDSET FOR GE MODEL 27911 DECT 6.0
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
The appliance interior lights works but it's not cooling or freezing
The compresser could fail yes, but you could also have an open circuit. If the contacts in the thermostat got corroded, or the starter relay, it may simply not be told to turn on. It may be time for a technician to measure continuity in the circuit.
Jan 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
109 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
