Question about Garden
How to reverse rotation on type k4120 3 phase motor?
  • 252 Answers
Hello
make note of positions of wires and colors before moving and wires so can be put back if need to
in general 3 phase motors can be reversed by reversing only one of the phases that come in
as far as i know forward rotation sequence would be red, yellow, blue , (these are the 3 phase wires and could also have a black wire nuetral if the motor is a unbalanced load motor
but think that phase color blue is now white according to electricity regs for 3 phase motors
if the motor is a balanced load motor it may not have a black wire
(the function of the nuetral conductor is to to carry the out of balance current if the loads on each of the 3 phases is diffenent ) and of course has a earth wire as well ( which is yellow/ green )
you should reverse either red and yellow position only or yellow and white position only
but if in doubt check with your local electrcian to confirm
always check electrcity regs before altering
cheers
Posted on May 29, 2011
How to reverse rotation of single phase capacitor start motor
You have to reverse the coil (body) from the armature (center). Remove screws of your motor, armature is the center of the motor that rotates. Body is the part that has copper winding in the middle. Reverse this body and screw it back again. Try this and you will find that the armature rotates opposite the way you had it before.
May 03, 2017 | Heating & Cooling
Tip
How to Reverse the Rotation of Single Phase Capacitor-Start Electric Motors
Reversing the rotation of electric motors can be done easily with 3-phase motors. This can be easily achieved by swapping the connection of any two motor leads. But 3-phase motors are usually found and used for industrial purposes. The ones found and used in our homes, from water pumps to electric fans, are single phase capacitor-start type motors. Unlike 3-phase motors, reversing the rotation of single phase electric motors is no easy task. Swapping any two motor leads will not result in the reversal of the motor rotation. Analysis of the motor windings and connections are necessary before any modification can be done to achieve the desired result. Let's take a 3-speed single phase capacitor-start electric motor with electrical diagram shown below as an example. Make sure the motor is disconnected from the power supply before attempting to follow this tip. This tip is intended only for individuals with electrical knowledge, necessary tools, and understand the risks associated with handling electrical equipments and devices.
The first step in the process is determining the start winding which is connected to the line (AC white) and to one side of the start capacitor. To accurately determine the start winding, disconnect all motor leads from the start capacitor and the speed switch for multi-speed motors and then setting your ohmmeter to the lowest scale (R x 1), measure the resistances between the AC white line and each of the motor leads connecting to the start capacitor. The one with the least resistance is the starting winding lead.
Once the start winding lead going to the capacitor is determined, reconnect the capacitor then connect the black AC line to the found start winding lead (marked X). Connect the white AC line to L of speed switch, the motor lead formerly connected to AC white to 3, red to 2, and white to 1 as shown below. Leave the green/yellow ground wire connection as is.
Below are the wiring modifications for 2-speed and single speed single phase capacitor-start electric motors.
on Jan 11, 2011 | Dryers
How to reverse rotation of single phase, 1/2 HP, 110V electric motor.
Changing the "polarity" of the start winding by swapping the wires over should reverse the direction. Lots of online motor-related generic and manufacturer information is available.
Feb 16, 2015 | Air Tools & Compressors
How do I reverse a three phase electric motor?
Reversing rotation of 3 phase motors:
CAUTION: Before attempting any repair of electrical equipment verify the power is disconnected to the device.
CAUTION: Three phase motors could potentially be controlled by frequency control systems. It is recommended a trained electrician perform repairs to any electrical system. In particular, consult a trained electrician if the system includes a frequency control system.
Most 3 phase motors can reverse rotation simply by swapping any 2 of the 3 phase wires. A typical 3 phase wiring circuit will include a safety ground wire (usually green) and 3 phase wires, often designated A/B/C, or 1/2/3, or color coded to distinguish each. By swapping the terminal connection of any 2 of the three phase wires, for example, 1 & 2 or 2 & 3 or 1 & 3, but leaving the third phase wire unchanged will reverse the rotation of most motors.
Jun 12, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
How do I reverse the rotation of a WL330002AJ dual capacitor ac single phase compressor motor made by campbell hausfeld
Chpower motors will only run in one direction, the primary use for this motor is chpower pump. However the motor can be useful for other purpose but you must be creative. What were you going to use the motor for?
Apr 08, 2014 | Air Tools & Compressors
Fi have a older furnace that operates like this. main burners will come on then the blower turns on and furnace continues to heat untill it shuts down on the high limit. there is no blockage on the cold...
Maybe there is a blockage in the air conditioning coil above the furnace? This happens when people have pets, or dont use filters. Single phase 120-240 volt motors won't run backwards if you reverse the wiring that's dc or three phase, you have to check the rotation of the wheel, the right rotation is usually marked on the blower case. Some motors will allow you to change the rotation but you have to check the wiring diagram. Also use new capacitors when they go bad the motor can run backward. God luck
Dec 20, 2011 | Honeywell L4064B2236 Fan/Limit Control...
Ingersoll rand model 2340 air compressor,how do I wire it?motor has 5 5 wires red black blue yellow & brown. Which ones go where? Also which ones reverse rotation of motor? Thanks.
The red, black, and blue wires should go in any order to the 3-phase motor starter. Reverse any two of these wires to reverse the motor, and bump start the motor until rotation is verified . Not sure about the yellow and brown wires--they may go to the motor starter as an over-temp shutdown or as power to the unloader valve to close it when the motor runs and opens the valve when the motor is off. Hope this helps!
Dec 19, 2010 | Garden
On the haywood superpump model c48l2n134b1 i have 2 wires to wire on L1an L2 witch wire goes were
Either wire can go to either line as long as it is only one line lead to each post. Rotation is fixed and unlike a three-phase motor, reversing the two wires does NOT reverse the motor rotation.
John
Dec 07, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
How do I wire a 30amp 3phase 250 volt receptacle for proper phase rotation ie x,y,z on the device with phases a,b,c in the panel?
You will either need a phase rotation meter to identify the rotation, or, if it is a motor, reverse any two leads to spin the motor the opposite direction (this works on single phase, too).
i hope this is helpful
matthew
Oct 31, 2009 | Gb Electrical 1 30 Amp Ground Fault...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
