Question about Refrigerators
Please send to saide386 Dear Mr. salde386 Thank you for your solution to the defrost problem with my GE TFH24PR (detailed model tag is missing) refrigerator. I bought the heater assembly and installed it with no problem. I also need help with the icemaker which has stopped making ice. The water outlet on the outside door of the freezer works fine, and so does the ice door flipper mechanism and the motor that rotates the ice pushout rod. However, even when the ice bucket-filled-up automatic shutoff lever is lowered onto an empty ice bucket, no water flows out into the ice cube tray and no sounds are heard. Is there a separate switch to enable this function? What do you suggest? Thanks. Bob Trippi
  • Robert May 30, 2011
    How can I test the ice cube valve for passing water?
  • Robert May 31, 2011
    Please send to salde386 ONLY:
    Thank you for your previous help with the defroster on my GE TFH24PR refrigerator, which worked out fine.
    Another question: how can I test the icemaker water solenoid valve from the front of the unit. Everything else works fine, including cold water coming from the outlet on the door and the ice pusher motor.
    However, lowering the icemaker bail does not let water into the ice cube tray, or make any noise at all for that matter.
    I understand that after removing its front plastic cover, shorting a pair of test points (L-V?) near the timing gears on the front of the icemaker should temporarily actuate the solenoid valve, but I do not see the test points shown in the picture on youtube.
    I can send you a photo of mine
    Thank you.
    President:
  • 1,216 Answers
I see that you are intended to ask salde386 only.
so do 1 thing
click here to visit his profile
ask him directly but the company will make you pay for it.
Thank you for your solution to the defrost problem with my GE TFH24PR.
from this line i assume if you have been in continuation then you can comment in that problem only to get an answer. you will have all his solutions listed in his profile
Thanks
Posted on May 31, 2011
  • 1,998 Answers
Hello Bob,
the icemaker starts making ice when the unit reaches 32 degrees if you have no water flowing to the ice maker tray you would then pull the unit out and go around to the rear of the machine and assure that you have power to the solenoids on the water inlet valve if you do shut off the water supply and remove the lines and check for any type of a clog in the inlet valve screens if there is no clog this is a video on the refrigerator water vale test http://www.youtube.com/watch?v=AlYCJr9dc3E and would also tell you if your icemaker is working properly if you have any further questions message me back I await your reply Thanks Rick
p.s if you have no blockage at the screens and you have power to the solenoids replace the valve
Posted on May 29, 2011
  • Rick Ead
    Rick Ead May 30, 2011
    you can always try turning off the water and unscrewing the hoses that go to the valve and then either plugging in the wire like in the video which would make water come through the line or you can also take the female end of an extension cord and cut it off and add two electical connectors this is knows as a powered jumper wire or suicide wire you would then unplug the solenoids and touch to one side of the solenoid briefly if the valve did work then when power was applied to the top of the valve you would have water coming out remember to turn back on the water to perform this test definetly sounds like you might have a bad valve there Message me back if you have any further questions I await your reply Thanks Rick
  • Rick Ead
    Rick Ead May 31, 2011
    Great guess your unable to perform simplistic tests on your own unit have fun with this one salde lol and thanks again for the great rating Bob and have a great day
I need new handles for my GE Profile Refrigerator. Model TFH24PR 23.6 cu.ft
Contact GE we do not have any parts for ny thing on FIXYA
May 10, 2018 | GE Refrigerators
Ubuntu 15.10 driver are missing
Hi Mr Daniel
Thank your for choose the Fixya..
Can you please send the more information about it, which drive are missing, so it is better to present the good solution.
Thanks
Prashant Sharma
Apr 19, 2016 | Intel Computers & Internet
Freezer model 970-225-926 about defrosting instructions
Please resubmit with make and model, we don't send to personal emails, and you shouldn't put your personal details on here. I suggest you delete this
Jun 17, 2014 | Dryers
GE electric range JPB66
Please post a new help request with the full model number from the tag on your unit, as well as detailed symptom information - what is or is not happening, and when the failure occurs.
Dec 05, 2013 | GE Kitchen Ranges
Please send to salde386 only. Dear Mr. salde386 Thank you for your solution to the defrost problem with my GE TFH24PR (detailed model tag is missing) refrigerator. I bought the heater assembly and...
i just got your message,they made a mistake when it was sent to me,i'll get back to you tonight when i get in and will be happy to help you.
Jun 01, 2011 | Refrigerators
Defrost heater mnot completely defrosting
unplug it and get your hair dryer remove the panel again and blow dry the entire thing untill all is melted be carefull not to over do ad not to put dryer in the freezer stand back where the water will not splash on the dryer after leave it off for 1 hour than turn back on and put setting on number 3 for 2 to 3 hours than adjust to your normal setting not higher than 5 or it will repeat problem.It is getting very well cool causing to over cool to fast.
also air spray out back side and bottom of refrigerator is always a big help
Good Luck
Apr 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Need doors for GE profile TFH24PR refrigerator
Complete doors can usually be purchased from GE themselves for models which had problems with sweating on the exterior. Other models I'm not sure it's possible to get.
Ge can be reached at 800-626-2000
Aug 23, 2009 | Refrigerators
What its this?
Is what is call SPAM, if you delete all this will cam back but if you click SPAM won't.
Don't belive in this e-mails , don't send any money they want your Credit Card, all your infomation, to take your identity n sell it to the internet so others can do the same.
Your rating is very important to me.
Was this information helpful?
May 17, 2009 | Google AdWords
Lost manual
I am having a problem with the language on my Ge corded speakerphone md#29585fe1.how do i change it to english. Thank you in advance.
Nov 21, 2008 | GE 29385GE1 Corded Phone
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
