Is there a schematic somewhere that shows how to plug these things in? I may be short a cord Thanks! Jack
  • Computers & ... Master
  • 5,660 Answers
First thing to plug in are the Power Supply cables.
The main one to start with is the ATX main power cable.
There are two main variations of the ATX main power cable.
The 20-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
,and the 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
The 20-pin version was used on the older model computers. It was found that more power was needed to the motherboard due to newer computer components, and four extra power wires were added.
In the center photo note the lock on the side of the connector. It operates in a see-saw fashion. The top is squeezed in, to release the hook of the lock from a tab on the female connector, on the motherboard. Then the male connector can be removed from the connector on the motherboard.
Depending on the motherboard you may also have a 4-pin ATX +12 volt power cable. This is additional power to the motherboard, and is mostly used to provide additional power to a Processor.
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Note the lock on the side of the connector. It operates in the same fashion as the ATX main power cable's connector.
Peripheral devices inside the computer also require a power cable.
If you have an IDE, (Also known as PATA), harddrive it will require a 4-pin standard Peripheral power cable.
Commonly misnomered as a Molex power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
This power cable is also used on IDE type optical drives. CD or DVD.
It can also be used along with an adapter cable to power a computer case fan.
There is no lock, but there is only one direction the cable will plug in.
There are two rounded corners on one side of the plug to line it up.
On all power cables use the connector itself to unplug the cable, Not the wires!
(Sometimes unplugging a 4-pin standard Peripheral power cable is tough.
The connector is rocked side to side while removing.
Sometimes an additional tool is needed to EASE the connector out.
In all cases make sure the computer is unplugged from power BEFORE working on it, and assure that you are following Anti-Static Precautions)
You may have a SATA harddrive, and also you may have SATA optical drives. (CD or DVD drive)
They use a SATA power cable.
The SATA power cable has 15 pins.
[Note a SATA data cable has 7 pins. It is the shorter of the two cable connectors]
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
NOTE*
IF you have a SATA harddrive that has provisions on the back of the unit, to plug BOTH a SATA power cable, and a standard 4-pin Peripheral power cable, ONLY use the SATA power cable!
Using both power cables will burn out the harddrive.
Sometimes it doesn't happen right away, but it eventually will.
The last power cable I will mention here is the 4-pin small Peripheral power cable.
On older computers this power cable was used on a Floppy Drive.
Now more used to provide power for a Card Reader.
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Additional information to be included in a Comment.
Regards,
joecoolvette
Posted on May 29, 2011
  • joecoolvette
    joecoolvette May 29, 2011
    A SATA harddrive requires a SATA data cable. The connector is 7 pins long.
    http://en.wikipedia.org/wiki/Serial_ATA
    An IDE (PATA) harddrive requires a 40-pin flat ribbon cable. [Data cable. Also known as an Interface cable]
    (Note only 39 pins are used)
    http://en.wikipedia.org/wiki/Parallel_AT...
    The male connector of the 40-pin flat ribbon cable has a Locating Lug on one side. This lug lines up with a cutout in the circuit board of the harddrive.
    You may have a male connector which does not have a Locating Lug.
    The pins in the male connector are numbered from 1 to 40. (39 actually. There is an empty socket hole)
    PIN 1 - Always goes toward the power cable.
    On one side edge of the 40-pin flat ribbon cable there is a faint Red stripe.
    This red stripe is on the same side as number 1 pin in the cable. (And connector)
    Make sure the faint red stripe is facing the power cable plugged into the back of the harddrive.
    For the SATA data cable the socket hole in the connector is L shaped.
    Only plugs in one way.
    On the motherboard you may have more than one SATA header to plug into.
    The beauty of SATA is that you can plug into ANY of the SATA headers on the motherboard, and BIOS will find it.
    So if you have unplugged a SATA data cable from the motherboard, and do not know which SATA header it plugged into, it DOESN'T matter.
    Plug into any of them.
    You believe you have a short in a cable?
    You'll have to check each one individually then with a multimeter.
    Computer doesn't come on when you push the Power On button?
    I suggest you use the test to see if it is the Power On button, or the Power Supply.
    Post in a Comment if you wish to know how to perform this test.
    Computer power supply comes on, but the computer doesn't?
    (No Signal on monitor)
    You may have a bad Power Supply.
    Weak voltage rail.
    Enough power to light LED lights, and maybe spin fans, but NOT enough power to turn the Processor on.
    1) IF all of the LED lights were on at once they would use less than 1 Watt of power.
    2) EACH fan uses 2 to 3 Watts.
    3) A typical processor can use from 51 to 125 Watts.
    This video may help in understanding the various computer cables, and where they plug in,
    http://www.youtube.com/watch?v=VhDp6Wpcp...
    Post in a Comment if you have any questions, or need clarification to something I have stated.
    Regards,
    joecoolvette
2 lines are on conference with each other
Either there is a phone somewhere that is set to conference, a phone has both buttons pushed. Or if they are both single line phones, one or both of them have 2 line modular cords plugged in thus shorting the lines together. There could be a shorted jack. Or finally it could be in the outside phone company lines. With the weather we have been having there could be water in them shorting out your 2 lines.
Apr 16, 2014 | NEC Lands Phones
Pluged coffeemaker into power, time went on, then no power at all
powerr short in the connection.check it properly.
thanks.
Sep 23, 2008 | Cuisinart DGB-600 Coffee Maker
Blowing fuses when power is applied on my Toshiba VHS M-754
you might have to change the entire power cord as well as the plug
Apr 13, 2014 | Toshiba Six Head Vcr Deck M-752 W/ Remote...
Presario laptop issue with power indicator light and detecting powers supply
Sounds like your DC Power Jack is bad or broken. The DC Power Jack is where the power cord plugs into the laptop? Most times it get damaged by too much stress on it such as sitting in bed with the laptop, or putting the laptop in the laptop bag with the power cord still plugged in.
Take an ink pen and put it into where the Power Cord normally plugs into the laptop. If the pin inside the DC Jack is loose or wiggles then the jack is probably bad. Sometimes the jack can be completely burned out and you can smell smoke .
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 05, 2012 | Computers & Internet
The battery on my laptop stopped charging, but was working for a over a week, then it was acting funny and slow.. I shut down moved to another room and it won't boot up! The light doesn't come on...
I think your power cord is bad. It probably was not charging the battery at all and so now all your battery power has drained since you were running on it. Once the battery power is drained and if the AC Adapter Power Cord is not working the computer will not boot because it has no power source.
Some AC Adapter & Power Cords have lights on them to let you know when it is plugged in if it is working. Normally when you plug the power cord in the laptop somewhere on the laptop lights up to let you know it is receiving power. Sometimes the light is where you plug it in, sometimes at the front of the laptop or right above the keyboard area.
I thing you need a power cord. And don't settle for one of the one size fits all (with a removable tip designed to fit any laptop) that the big box stores will sell you.
If your power cord is good and the laptop is not receiving power then the problem could be your DC Power Jack where the power cord plugs into the computer.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 03, 2012 | Acer Computers & Internet
Just installed my new bridge with piezo pickup and my 1/4 inch jack lead will not go into the jack mount on my fiddle. After about a cm in it just stops and wont go any further! Would appreciate any...
I hate to say it but you probablly need a bigger hammer... grip the jack, not the fiddle, and put more force on the plug... they can initially be tight... I do NOT like carpenter jacks myself. They are too heavy. At the 1 cm point is where the plug has to displace the contact. Expect to put 1 to 2 pounds of force to get the plug in... SUPPORT the jack so the force doesn't go on the fiddle. Make sure to use a high impedance cord and preferably short, say 3 feet cord. The capacitance of a guitar cord heavily loads a piezo pickup reducing the high frequency component of the fiddle sound and distorting the waveform. The impedance of the piezo's are around 1 to 2 megohms. Looking on an oscilloscope I found that a guitar cable and amp input made the normal sawtooth violin waveform into peak like mountains. We are now using a short cord (2.5 feet) into a Line6 X2 wireless digital body pack. The link transmits the wave undistorted.
Jul 14, 2011 | L R Baggs Violin Pickup W/ Carpenter Jack...
KX-TG6441 Phone shows "in
You have a short circuit somewhere...start by unplugging the phone from the phone jack in the wall. Wait 15 minutes or so for the line to clear, then try calling your number from another phone. If you hear a ring, the problem is either in your phone internally, or the cord connecting the phone to the jack (which can be replaced at Radio Shack or similar). BTW, are there other phones in the house? If so, do the same with them one at a time to isolate the problem. If disconnecting all phones (and waiting) doesn't clear the problem you have a short elsewhere, such as house wiring, or the phone jacks. But a busy signal ALWAYS indicates a short... good luck.
May 31, 2011 | Panasonic Lands Phones
Glitch with the power jack on our DRC630N
Return it for warrenty sevice,the connection jack port ave some kind of shorts.
Jun 29, 2009 | RCA DRC630N Portable DVD Player
ACER 3680 will not power up
hello, am temab concerniong your problem on powering your system right?
I hope the best thing for you to do is by checking whether the processor cooling fan is running cause that causes the system not to power on or power on and before short seconds it flickers and go on off again . there is nothing wrong with your power jack. If the problem is that the pc fan is not rolling then change the fan but if the fan is roling then change the processor itself. any other question?
Aug 25, 2008 | Acer Aspire 3680 Laptop
No Power, standby light blinking, power cord in/out two quick clicks
sounds to me to be a shorted HOT transistor or short somewhere. the click sound is the switch mode power suppy powering up sensing a short and quickly shuts down. the hot transitor is mounted to a heatsink near your flyback. check for emitter to collector short. you can try replacing it if shorted and if lucky that all that was ..but if shorts again you looking at probably a bad flyback. good luck
Aug 17, 2007 | Sony KP-48S75 48" Rear Projection...
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
