I have a Sony DAV C500 dvd player and it is unable to eject the discs that are in the system. There are presently 5 dvds in the player. The motor whirrs for a bit and then slowly quiets down with no activity. Any ideas on getting my discs out? Is it worth it to try and fix it, we worry that the surround sound cables will not be compatible with a new dvd player. Thanks!
  • Televison & ... Master
  • 508 Answers
Because it is a multi-disc DVD player, as opposed to a single disc type, and because discs are trapped inside, it may be worth submission to an authorised SONY service centre, obtaining a repair quote (and a second opinion as to whether it is economical to fix or not) - this allows you to decide on a further course of action.
Since you are concerned the surround sound cabling that you have may not be compatible with a new player, consider trying to get this one repaired first - but only if you agree to the quoted costs by qualified service technicians.
It might not be a good idea to try to retrieve the DVDs from the unit yourself; let a technician do it professionally as part of the overall repairs (make sure you get all the trapped discs back with the unit after repair completion).
Multi-disc DVD players are generally more likely to be worth repairing than single disc units. Up to you what you decide to do, but bear in mind, it could be expensive, but not unfixable.
The good news is this unit is repairable - just keep the workshop labour costs in mind.
Posted on May 29, 2011
My Sony Home thatre system DAV-DZ10 give a message : No Disk. How to solve that problem? Any help?
All DVD players will say no disc if there is no disc in the drive when closed. If however it does so when there is a disc in the drive, plus the disc is clean and undamaged, then you have a problem. It could be caused by dirt on the lens, but since it was doing funny things before there might be an electronics issue. I would still clean the lens first.
Jul 05, 2015 | Sony Dav-dz100 Home Theatre System
Tip
Sony DAV-C700, DAV-S400, DAV-S500, DAV-S800, CMT-S9D region free unlock code
Introduction
The DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the machine.
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Sony DAV-C700
 Sony DAV-S400
 Sony DAV-S500
 Sony DAV-S800
 Sony CMT-S9D
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD MOD Upgrade disables Macrovision to solve any problems.
User manual
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
Remote control command Function
[0] [ENTER] Default Default region code on the player
[1] [ENTER] Region 1
[2] [ENTER] Region 2
[3] [ENTER] Region 3
[4] [ENTER] Region 4
[5] [ENTER] Region 5
[6] [ENTER] Region 6
[7] [ENTER] Region 7
[8] [ENTER] Region 8
[Arrow down] [ENTER] Only play DVDs with the selected region; auto switching OFF
[Arrow up] [ENTER] Default Auto switching ON
[PREV I<<] [ENTER] Enable video interference impulses (Macrovision ON)
[NEXT >>I] [ENTER] Default Disable video interference impulses (Macrovision OFF)
[Arrow left] [ENTER] Enable user operation prohibitions* and access restrictions
[Arrow right] [ENTER] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
on Mar 02, 2010 | Electronics - Others
Hi!! I have a SONY DVD player(model- DAV DZ150K)...Recently it has refused to play DVDs (it says "cannot play this disc") and only plays VCDs and ACDs...please help!!!!
I have 1 sony DVD Model No-DAV-DZ150k .When i have select DVD mode so dest error show on VFD Disply .Pls tell me what is problem in DVD.
Oct 15, 2010 | Sony DAV-DX255 System
Sony 5 disc dvd player says c 31 00
C31 usually means a motor error. In your case, it sounds more like the loading sequence is not completing. Can you please confirm that the model is the DAV-FX10 system?
Thanks,
Dan
Mar 02, 2009 | Sony DAV-FX10 System
Dvd's wont eject from my sony dav-fc7
because of bad loading mechanisum.
its belt melted i think.can you observe the motor runing sound the inside of player.
nuwan...
Nov 22, 2008 | Sony DAV-C770 System
Got a code c-81 then dvd player won't do anything. Help
A bizarre coincidence but our Sony DVD player DAV C700 did exactly the same when the kids were watching a DVD. All other functions on the system are still working but the DVD player wll not eject or play - and the self diagnosis function C 81 remains illuminated on the display.
Aug 06, 2008 | Sony DAV-C900 System
FAC-FC7 DVD player is locked and the Standby indicator flashes
I had the same problem and searched FIX and found a solution for a Phillips DVD player that worked on my Sony DAV-FC7 dvd player. Someone posted that they called their Phillips Tech Service and was told to (a) unplug the dvd unit from the wall and wait 20 seconds,then (b) press the standby+plug the unit back into the wall at the same time and hold for 10 seconds. I did this for my Sony DAV-FC7 which would not power on nor eject (just red light on). IT WORKED!! after doing these steps, my SONY powered on and the rented DVD ejected. The dvd palyer works again. Thanks fellow FIXYA "posters".
Nov 12, 2007 | Sony DAV-FC7 System
SONY Model No: DAV-D150G DVD play problem!!
dav-dz100 a disc cannot be ejected and locked
Oct 06, 2007 | Sony DAV-DZ100 System
5 DVD disc changer doesn't open
are you using discs with labels that you out on your self? I had a similar problem before and my label peeled off in the player causing it to get stuck., you might just have to take it apart, and get the label out.
Dec 27, 2006 | Sony DAV-C450 System
DVDs won't play
Hi Pookie, This is an easy fix. All you need to get is a CD/DVD-Player Laser-Lens Cleaner for about $5.00. You can get these at Best Buy, Circuit City, Radio Shack, or any similar place. Use this, and let me know how it works for you. Best regards, nightdiver
May 27, 2006 | Sony DAV-C450 System
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
