Lumatron lcd tv we receive only two programms
We cannot use our lcd tv bacause it is only working with a digital receiver but not with our cable anntenne
I have a problem with my lumatron ftv-42p5 it shows a pink picture when i turn it on and first when I change the mode to scart2 rgb thw tv picture shows, but you can se that the picture is not ok it is a bite to white. If I try to connect my xbox. I cant not use it at all. solution??
Posted on Nov 11, 2008
SOURCE:
Need help with rv tv
If signals by cable is digital, and your Tv is no a digital compactable one, you need a set top box to view cable programmes.
Apr 20, 2012 | Televison & Video
How can I connect an HD LCD tv to an ancient (I think 1980s) Pioneer Receiver Model VSX-305? The receiver is in great condition, and I'd rather not replace it. I have Bose speakers connected to i
I have never seen RCA to digital conversion, and if it did exist you would have to convert from digital to analog in order for this to work, the sound quality would be degraded and unreliable, plus sound level would drop.
Mar 20, 2012 | Pioneer VSX-305 Receiver
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
How can I set up with my lcd Sony tv
If your home theater receiver has a digital optical input, run a digital optical cable from digital optical OUTPUT on TV to digital optical INPUT on receiver. If receiver is older and only has analog inputs, you can get an 1/8 inch to RCA cable(red/white), and plug 1/8 inch side to an output on back of TV and plug RCA side to aux input(or CD or cassette input) on back of receiver. DO NOT PLUG INTO PHONO INPUT! Either one of those cables can be found at Walmart, radio shack, or best buy, etc. Digital Optical cable is definitely the best choice, but I just used the 1/8 to RCA setup to hook up a Sony led to my brother's early 90's Pioneer receiver(not the ideal setup, but will work). Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
May 08, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
No analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
Feb 10, 2010 | Yamaha HTR-5740 Receiver
My Yamaha receiver model rx-v565 audio is putting out choppy sounds when cable is playing. I am using all HDMI connections. My TV is an LG 240 Hertz model and using the comcast HDMI box.
Do not run HDMI to your receiver. Run Digital Coaxial or Optical from cable box to your 565. The problem is on many levels. Hardware, Software, Audio Codecs, etc. your receiver is HDMI version 1.1. The current version is 1.3b. You can thank the recording industry for copyright protection for this issue. To have your receiver updated would be Very expensive and not worth it. If you want a blow by blow explanation of all HDMI's issues, Google HDMI forums or problems, and you can read for hours. Hope this helps.
Sep 26, 2009 | Yamaha Rx-v565 Receiver
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Apr 11, 2009 | Yamaha HTR-6130 Receiver
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
Televison & Video Logo
425 people viewed this question
Top Televison & Video Experts
Ekse
