Question about Husqvarna 20HP Hydrostatic 42" Cut Riding Mower
I have a husqvarna 2454 hydrostatic riding mower about 3 yr. old that backs up slow ,if you back up over a sm. clump of dirt or something it will stop backing wont even spin tire. thanks,bruce
  • 109 Answers
SOURCE: MTD PRO RIDING MOWER/LAWN TRACTOR 18 HP ENGINE HYDROSTATIC DRIVE
In the back of the mower...probably under the seat, there should be a lever to release the transmission, or it is on the back plate. As far as the noise when trying to move drive the mower, the brake in the back, next to the transmission is jammed, use a 1/2 inch wrench to loosen it maybe 1/4 turn and this should unlock the brakes
Posted on Apr 22, 2009
  • 376 Answers
SOURCE: Craftsman 19hp won't move when in gear
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
panilling9
  • 284 Answers
SOURCE: what kind of oil for a husqvarna riding mower?
Yes Briggs and Stratton recommends sae 30 in most all their engines even overhead valve (OHV)
Kohler uses 10w-30 in most of their overhead valve engines
Briggs has their own bottled oil with their label and additives and can find at lowes
Kohler the same
Posted on Jun 14, 2009
youcandoit2
  • 11 Answers
SOURCE: I HAVE HUSQVARNA 1548 RIDING MOWER HYDROSTATIC
You may have a drive belt that is worn or broken. Check the drive belt for slack condition see if it is not slipped off idler pully wheels or the belt tensioner. I had one that was streched out and was very slack on the pully wheels - I had it replaced with new one and was fine to go. There is a device on the back of your tractor to release the transaxle for manual pushing your tractor about with out starting the engine. Make sure the device is positioned correctly for running mode (engine) - There is a symbol on the back to help you know what to do. The tractor manual has good trouble shooting info and if you don't have one, try googling for it with the model number of your tractor - you will be able to download one free to your computer for viewing it.
Posted on Jul 17, 2009
  • 4 Answers
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
Posted on Sep 16, 2009
How can I adjust linkage on my 2015 zero turn husqvarna mower
If you follow the control arms down to the Hydrostatic hydraulic pumps on either side with should be a bolt that will adjust the forward and reverse aligning of the arms. if you are adjusting the speed of either side, there should be a flow adjustment screw on the pumps as well. Usually backing the screw out will slow the movement of one wheel and adjusting the screw in will speed the movement up of one wheel. Each wheel is done individually.
Nov 10, 2016 | Husqvarna Garden
Forward is slow
need to change hydrostatic fliud and filterthat will take care of it
Oct 02, 2014 | Husqvarna "YTH26V54 54"" Briggs And...
Husqvarna 24hp VTwin Hydrostatic 48' cut riding lawn mower will not move either direction.
I would check the drive belt going to rear end if not that I would check fluid level in transmission.
Aug 04, 2013 | Husqvarna 24HP VTwin Hydrostatic 54" Cut...
This ZR4625 is new. It will not track straight. With both levers forward it tracks to the left, I can pull back on the right lever and it tracks ok but it slows down a little. What do you adjust?
First check both rear tyre pressures, if ok you need to adjust the rod that runs between the left lever and the hydrostatic drive on the left rear wheel so that the short lever on the hydrostatic drive travels further when push the drive lever forward. Regards Phil
Apr 14, 2011 | Husqvarna Zero Turn Mower Z5426
Riding mower accelerates extremely slow and seems to stop on inclines
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
Apr 12, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The back wheels want go cause somethings locked how do i fix that?
the hydrostatic transmission has failed. about 1200 for a new one and the mower is only worth 250 running. sell the mower AS IS on eBay and buy a new one.
Mar 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Husqvarna 20HP Hydrostatic 42" Cut Riding Mower Logo
81 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
