Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
KitchenAid dishwasher, Model # KUDP021RBS1 - "Normal and cancel lights blink constantly". I had this same problem about two weeks ago so I googled your site and though the solution I found was not exactly applicable to my problem but I tried and that is - Press high Temp, heated dry, high temp and then heated dry and then cancel button and then close the door. Would you believe it worked like a magic wand. But this same problem resurfaced and I am trying all those old tricks but nothing is working. Normal and cancel lights keep blinking. Any help would be greatly appreciated. brij.
Krazytech
  • 725 Answers
SOURCE: Lights blinking and won't clear
the solution #3 should work.. you may want to try again.... first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes. let me know if you can get into it...
Posted on Aug 25, 2007
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
Have u chked for any reset button in dishwasher?
Posted on Sep 21, 2008
  • 3 Answers
SOURCE: My normal cycle and cancel button lights are
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Posted on Apr 27, 2009
  • 56 Answers
SOURCE: the light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
Posted on May 31, 2009
KUDP01ILBL6
Technical sheet say you have a stuck key on the keypad
Feb 04, 2014 | KitchenAid Dishwashers
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
Dishwasher clean light blinks constantly, can't get washer to start up and wash. Buttons will light up but it wont start.
Hello, Thank You for using FixYa. I will be helping you today.Try pressing heated dry,Normal,Heated dry,Normal and all lights should come on if they do wait like 5 seconds and hit cancel and see if the unit will start. If this happens again it may be a heating issue.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | KitchenAid Dishwashers
Kitchenaid kudp02crbl1 dishwasher. Normal light is constant blink. Cancel will also go into constant blink if pushed. No other response from other buttons. I've reseated all ribbon cables. Was hoping...
This means the touch pad sense a stuck or shorted key. Try pushing in all the keys to make sure there not stuck. If not, the touch pad needs to be replaced.
The screws around the door come out and the assembly will slide forward. All plug and play type connections and a few 1/4 screws. The repair is really straight forward. Good luck with your repair friend
May 19, 2011 | KitchenAid 24 in. KUDP02CR Built-in...
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Control panel cancel light blinking as well as normal and light china light cannot cancel or start dishwasher
where do i connect the upper rack water conduit tube for the kitchenaid dishwasher
Aug 16, 2009 | KitchenAid Dishwashers
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Feb 05, 2009 | Kenmore Dishwashers
Blinking normal and cancel lights
I had the same problem- needed a new control panel. good luck. Didn't bother going through kitchen aid even though its still under warranty- figured they'd nail me on labor (it's in the 2- 5 yr warranty period) and I'd be waiting forever. had a private appliance tech take care of the problem.
Aug 25, 2007 | KitchenAid 24 in. KUDS02FRSS Stainless...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
147 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
