Question about NAD T753 Receiver
Nad t753 av reciever, mains power off then back on think had power surge have i blown a fuse in system. amp turns on but then 2 sec later turns off . can i take the casing off to replace fuses?.... dan
    Brigadier General:
  • 8,546 Answers
Blown fuses don't self-heal. If power comes back there is no blown fuse.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 29, 2011
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
My nad t753 reciever went into protect mode. i switched it off and was able to get it back into standby mode. The receiver switches back on but no sound comes out of the monitors. I can even switch between...
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 31, 2011 | NAD T753 Receiver
Color plug came out. red color which position do I plug it into need diagram of back of unit for the NAD T753
Not sure what this cable is for but YOU should be able to follow it to the component at the other end and determine its fucntion.
Here's the manual. Page 12 shows the rear.
http://www.retrevo.com/s/NAD-T753-Receivers-review-manual/id/8043bh641/t/1-2/
Jun 08, 2010 | NAD T753 Receiver
NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Jan 29, 2009 | NAD T753 Receiver
My NAD T753 goes into protection mode as soon as I turn it on.
The unit grounding screws have come loose. All the ground screws should be tightened.
Jan 22, 2009 | NAD T753 Receiver
NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Dec 01, 2008 | NAD T753 Receiver
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
NAD L40
1.due to some short circuit in your receiver circuit has made the fuses blown
2.Replacing the fuses alone does not get solve.
3. Check the reciever power circuit
4. check whether output is being short circuited
5.Contact service centre
Jul 10, 2007 | NAD L40 CD Player
NAD T753 Receiver Logo
534 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
