Question about Toshiba 50H72 50" Rear Projection Television
We have a toshiba projection tv 50H72. we are getting picture distortions of lines verticle & horizontal. convergence has been rest, the only way to get rid of the squiggly lines is to turn tv off & on. lines return after awhile. this is happening more often each day. what can we do to get rid of this?
    Genius:
  • 1,030 Answers
There is a common problem with this particular model that involves what is known as the"Hypermodle" this is a cuircit board that controls signal processing. The symptoms you describe sounds similar to this problem. This board has 11 very small parts call capacitors,that go faulty over time and get worse with more time. Ideally replaceing this board was the right thing to do in the past however since this was a common occurance the boards quickly became in short supply. Toshiba issued a Service bulliteen to shops on how to repair them. I repaired 2 of them a month at the shop. Now this is a repair that only the most experience tech should attempt. very small parts and easy to damage if not done right. Our shop generally charged around 250 to do this repair. most of the cost was in labor. but always ask if they have done this repair before.
Posted on May 29, 2011
Toshiba 50H72 have blue and yellow ghosts
Sounds like your convergence circuit went out. It lines up the red,green and blue picture tubes so the colors are lined up. Usually these TVs all use the same type of IC chips called "STKs" both usually get replaced along with any resistors etc.. around these chips that may have burned up. Depending on who fixes it could be around $300-400 parts and labor.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 26, 2009 | Toshiba 50H72 50" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
PICTURE HAS DISTORTED HORIZONTAL LINE IN CENTER OF SCREEN.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jan 03, 2009 | Toshiba 55H70 55" Rear Projection...
I have a toshiba model 50h72 double vishion
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 12, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba 50h72 picture and sounds takes 20 min to warm up
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Sep 09, 2008 | Toshiba 50H72 50" Rear Projection...
50H72
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 25, 2008 | Toshiba 50H72 50" Rear Projection...
Diagonal distorted picture
convergance amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50 in. Rear
possibly the STK392-110 ic's? it seems like it is the vertical convergence.
Nov 28, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba Rear Projection 42 "
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 23, 2007 | Toshiba 50H72 50" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
83 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
