Question about Seagate FreeAgent 2TB GoFlex Desktop USB 3.0 USB 2.0 Hard Drive
The external hard drive isn't being read from the computer. Sometimes, the hardware will light up and sometimes it doesn't. The computer is not able to detect the hard drive. Please advise.
  • Seagate Master
  • 32,281 Answers
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Posted on May 29, 2011
Hi there, my packard bell external is slowing down my pc when I plug it in. Sometimes it doesn't read, if it does, it takes very long, otherwise I just receive an error
It sounds like your connecting an external storage device (Such as a hard-drive) over USB.
The device you purchased has not been formatted-- that is, the file-system isn't prepared, and when its connected your operating system is trying to "figure out" what the heck it is... eventually coming back with "I dunno..format it?"..
The answer is simple-- say YES.. Format the device. OR, open "My computer" and then plug in your device. You'll eventually see a drive letter appear (such as D: or E: or F:...etc-- just not C:). When it appears, right-click on the drive, and click "Format"... select "Quick Format", then "OK"... Wait a few seconds..and poof..your device will show quickly next time you use it, and you'll be able to store data on it.
Oct 18, 2012 | HEWLETT-PACKARD Hewlett Packard HP 500GB...
Maxtor basics 500GB external hard drive not working
Every time you turn your computer on it is going to "spin up" and the light is going to come on. Just because the light goes out and it idles so that you can't hear it anymore doesn't mean it isn't still on. It is. You can verify this by using windows explorer to view it and its files.
Jun 29, 2012 | Maxtor BASICS Personal Storage 3200...
Nexxtech external USB hard drive stopped working. Light comes on but drive does not seem to activate and produces no response in the laptop.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
a cnet rview
Pros: Lots of space, very low price, doesn't require outside power
Cons: Sometimes stops working, no firewire (but still a quick transfer speed)
Summary: This doesn't require outside power, but sometimes you need to hook it up to 2 USB ports. The USB cable has 2 heads. Sucks when I only have 3 USB ports on my laptop.
Also sometimes it spontaneously stops communicating with the computer. I don
Oct 04, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
Hello, I formatted my external hard drive Samsung G2 HX-MU050DC and i lost the drivers. I can not find drivers. Can you help me please? Because i can no longer read the files that are on it. Thank you...
According to the microsoft site your external hard drive which is the Samsung G2 HX-MU050DC doesn't need any additional software it is automatically installed when connected..Maybe try to connect it to other USB port I preferred you connect it at the back of your CPU..If this doesn't work try to connect your external hard drive to other computer if it still doesn't work. sad to say but the problem is your external hard drive..
Jul 06, 2011 | Samsung G2 Portable External HX-MU050DC/...
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
The Hard Drive is on. Blue light is on and I can hear the drive working. It doesn't, however, show up in disk management or isn't detected by my laptop.
Hello vunit2007,
I've read your "post," and I think that the best solution to the 'problem is to:
Get an "Update on the Drivers and Software.
"Most situations cannot be solve by 'pressing a couple of buttons'; sometimes
We have to go into the "Control Panel," or go to a "Website" to get updates for the computer,
"Drivers are needed for Hardware, eg, (Hard Drives, Printers, CD / DVD Players, Audio Sound, Speakers, Microphones, Mouse, Keyboards, and Webcams), to work correctly; also, some Software products."
"Upgrading the computer in any way, or added a 'new' software product?"
Causes the System Configurations, to change!
Many cases involving "Upgrades from an 'older' {Operating System, eg. XP or Vista}, to Windows 7, can cause a change in "Hardware Devices," not functioning properly; or not to work at all!"
"These easy instructions will help you solve these issues, and hopefully, we'll be able to fix the problem the first time."
"This is what you need to do first!"
1. Click on the Website [below].
2. Download the Fantom G-Force MegaDisk {NAS Source Code}, at the [botton of the page].
3.Turn-off the computer.
4. Disconnect the Hard drive.
5. Restart the computer.
6. Install the Drivers.
7. Restart the computer again.
8. Connect the Hard Drive.
9. Turn on the Hard Drive.
10. Check the in the -> Control Panel -> Device Manager -> Hard Drive / Mega Disk!
11. Check in the Disk Management.
"Let me know if you need more help, if it didn't fix the problem?
Post a "Comment" to get more help.
"I would appreciate it if you let me know!
Best Regards, paul7of9
Click here for Download: http://www.micronet.com/support/software.htm
Scroll to the bottom of the page until you see the download for the
"Fantom G-Force MegaDisk
Jun 15, 2011 | Fantom G-Force MegaDisk 1.0TB 7200RPM USB...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Hey there. I have a problem with an external harddrive. "My Passport Essential". When I connect it to my compute sometimes nothing happens and sometimes "Local Disk (E:)" shows up in my...
The problem might be a loose connection or bad configuration file (an autostart ini file that makes the hard-drive do certain things when plugged in) in the root folder of your hard drive. Are you able to connect to it sometime or it doesn't work at all? If you can read it, try backing up all your data and format the hard drive and copy back the backup again. But remember to copy only the needed files and not the system or ini files.
May 06, 2011 | Western Digital My Passport Essential...
I moved and when I reconnected my WD 2.0 external hard drive my computer isn't finding the drive. Serial # WMAJ94042847. The drivers should still be in the computer, but it isn't finding the drive. I have...
First.
Make sure that all the connections inside in your computer are secure - also- makesure that no dust has collected in the machine. Sometimes when moving wires come unplugged and dust moves around and can break connections.
Then- Back up the driver - just in case.
Next.
Please go to my computer, right click properties, and click hardware and then device manager.
Scroll to the bottom of the list.
and delete the USB's -
Turn off your computer. Plug in your Drive.
Wait for about 8 sec.
Turn it on.
Now is it reading your drive?
I
Mar 19, 2009 | Western Digital External USB 2.0 80 GB...
Open Questions:
Seagate FreeAgent 2TB GoFlex Desktop USB 3.0 USB 2.0 Hard Drive Logo
186 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
