Question about Toshiba 37RV530U LCD TV
My Toshiba 37RV530U LCD TV won't boot up. I've tried unplugging and replugging the power cord. All I get on front panel is 3 blinking yellows then a pause then 3 blinking yellows. This continues forever. Pushing the power button on the remote or on the set does nothing
SOURCE: yellow light blinking - blank screen - won't turn on
The problem is with the signal board. Basically, it is not allowing the power signal to go from the on button from the set or the remote to the TV. I am having the exact same problem with my 42" LCD Regza. Currently, if you are under warranty, Toshiba does not have these in stock. They will not have them available to send until early January. My TV has been at the repair shop since December 4th. I am very upset as I won't be able to watch the bowl games in HD. If your set is still under warranty then call Toshiba help line at 800-575-5469. You will need the model number of yout TV that is listed on the front of the owner's manual. They are:
27HL67
32HL67
32HL67U
37HL67
42HL67
The first number will be the giveaway as to which model you have. It is the size of your set. They will ask you to try a hard reset. (Hold pwer button down for 5 seconds until you see the yellow light go solid and go off.) This will most likely not work. If it does, you are lucky. I found that if you unplug the TV for an extened period of time, ie overnight, ity may come back on. It will eventually give out completely though. Better to get the problem addressed with the manufacturer. If you are not under warranty then I do not know what to tell you. Right now I am searching the internet to see if I can find this part to maybe purchase myself. Only if it is not too costly. If I find anything I will post here for all. If you have any questions, feel free to email me a wkjtx@hotmail.com and I might be able to give you more details on your problem. Good Luck.
WJ
Posted on Dec 17, 2008
SOURCE: Doesn't power on - Amber LED Blinking
Here's how I fixed mine...
Look inside the back of the TV just above the power cord - there are two small LEDs, one green and one yellow (no need to open the case - you can see them through the cooling slots). In my case, the green LED would light for a few moments after plugging the TV in, then the yellow one would light and stay lit.
Go to the Toshiba site and download the latest firmware upgrade.
Copy the firmward upgrade to a SD memory card using your PC (SDHC cards larger than 2GB don't appear to be supported by the TV, so use a smaller one). I copied *both* the zip file as downloaded from Toshiba, and the contents of the zip file. That is, I expanded the zip file and copied the contents to the SD card as well.
There's a metal cover over the SD card slot on the back of the TV. Remove it (a single screw)...at one point, Toshiba has directions on the firmware download web site.
Unplug the TV and insert the SD card. Plug in the TV again, and in my case, those little LEDs stayed green. I saw none of the instructions on the TV screen - rather I just let it sit for about 10 minutes, then I unplugged the TV, removed the SD card, and plugged the TV in again. Viola - the TV works.
I'm thinking perhaps Toshiba uses a type of memory that requires battery backup, and if the TV is unplugged for an extended period of time, it's necessary to re-flash it.
Posted on Jun 21, 2009
  • 4090 Answers
SOURCE: Flashing power button tv won't turn on
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Posted on Aug 17, 2009
eagle338
  • 4889 Answers
SOURCE: i have a 42 inch toshiba lcd tv its bran new led
3 Blinks indicates that there is fault with the power supply of the set. Since the set is brand new, run back to the store and get a replacement. Also purchase the extended warranty(Think of the 250$ that you are gonna spend on this repair if the same thing happens right after your 1 year warranty expires?)
Hope this helps,
Sai.
Posted on Dec 25, 2009
SOURCE: TOSHIBA REGZA 32LV67U USUALLY (ALMOST ALWAYS
This is software problem Call me at 905 6021613
Posted on Jun 23, 2010
The yellow LED on my Toshiba 32CV510U flash all the time and TV won't turn on
check some leak or bulged capacitors at the power supply board then replace it.
Oct 02, 2012 | Toshiba 32CV510U LCD TV
What's your problem? won't turn on..... yellow/orange light continually flashes three times...
Toshiba Regza 37in - 37HL17
TV will not turn on - Yellow power ind. Light blinks three times...
Fixed with a firmware update (hard to believe, but true). Search Google for a file named: 2007SEN069.zip (don't worry if the page you find it on doesn't mention the 37HL17 - it worked fine). Unzip the file, and copy the 3 folders and 3 files to the root of a small SD card. The SD card MUST be 2GB or less in size (I used a 1GB card), and it MUST be formatted with FAT-16 (not FAT-32). Mine was pre-formatted as FAT (FAT-16). The SD port is on the back of the TV behind a cover plate near the power cable. You do NOT need to remove the back cover of the TV, just the small cover plate (1 screw). UNPLUG the TV; remove the cover plate; insert the SD card (prepped as explained above); Plug in the TV; Watch the yellow lights blink, then turn blue, then go dark; UNPLUG the TV; remove the SD Card and replace the cover; Plug in the TV; Yellow lights will blink a few times (this is normal); when blinking stops, turn on the TV and you should be good to go. :-)
Pictures attached are from a Toshiba software upgrade bulletin I found online.
09adb97e-8925-4d59-b218-7443a6e64989.png 82ea33aa-2353-4e13-a5db-8be13ba85711.png
Aug 06, 2012 | Toshiba Regza 37HL17 37 in. LCD TV
HP F4140 Printer - all lights flashing, blinking E
This is a printer hardware error, you cant try below reset methods.
Power Drain:1. Unplug the printer power cord from wall and the printer, disconnect USB cable from printer.2. Press and hold the power "ON/OFF" button for 30 seconds and release it.3. Connected the power and check the printer.
Dec 08, 2011 | HP DeskJet 6988 Printer
Yellow light blinking on my Dell Inspiron one 19 and won't start up
if you have replaced the MB and power supply, then the from IO panel could be the failed component
Nov 16, 2011 | Dell Inspiron One 19 All-in-One Desktop PC...
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
I have a Toshiba Regza 47ZV650U 47" LCD TV that
I am having the exact same problem with my 47ZV650U, what was you solution
Jul 13, 2011 | Toshiba Televison & Video
37rv530u service manual
You could try
operatingguides.com
if you need a user manual
or
servicemanuals.co.uk
if you want the schematics etc
We've used them in the past and found them very good.
Also if it is not listed then ask via the link and they
will probably be able to get it for you.
Jul 05, 2011 | Toshiba 37RV530U LCD TV
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Power not coming on, the green light keeps blinking
Tries unplug,replug the tv an hour later.Now,the tv it resetting itself back to the factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 17, 2010 | Toshiba 37AV502R 37 in. LCD TV
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
Nov 06, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba 37RV530U LCD TV Logo
108 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
