Question about Teac DVC200 System
Hi: When playing a cd on the July 2002 Teac DVC200 it slows down and sometimes stops. Also when I open the top up the lid goes up slowly to put the cd in. Any advice on what is wrong with it. I really love the way it sounds...
informatica
  • 1114 Answers
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 27, 2007
SOURCE: TEAC AG-D9100 freeze
Always be that legend when the audio amplifier IC damaged
Posted on May 08, 2009
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
  • 17 Answers
SOURCE: cd player stops spinning about 30 seconds after it
Is it belt driven? My guess is that the belt needs to be replaced. If it's direct drive, it's probably the motor itself. Make sure you try some different CDs. Sometimes when there are scratches or smudges, the laser can't read the disk and it will stop. You may want to try a laser cleaning disk too. They are cheap and I have saved several computer drives by using one.
Posted on Dec 04, 2009
  • 99 Answers
SOURCE: TEAC CD P1120 wont play
replace the loading tray belt as this also lifts the laser mechanism up to the level of the disc once loaded.
the humming sound you hear will be the motor trying to lift the mechanism up to read the disc but can't because the belt has lost its tension and is slipping.
Posted on Sep 24, 2010
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
I have a teac x-9, and during cd play, the cd doors randomly open and close causing me to restart cd play all over again. it does this on its own, and i don't push any buttons for it to occur. is this...
clean your eject button or check it 2 see if it is broke. if u have a remote try 2 play a cd with the cd player with the batterys out of the remote. last 1. the cd door could be off trak witch wood make the cd off balance when the eye goes 2 read the data on the disk it misses its data an will cause your cd player 2 open.
Mar 15, 2011 | Teac Audio Players & Recorders
Hi, the belt on our Teac Turntable has come off while moving to new home. Can I get manual that shows how to put it back on?
If you open the top lid of your turntable, you will see a black rubber disc that sits on the pladder, it should come off revealing the metal pladder, you should see holes that will show your belt and the turntable motor when pladder is rotated. In order to put the belt back on you must remove the pladder, but before you do check to see if there is a C clip holding it down, after removing the clip the pladder should come off, put the belt on the inner rim of the pladder, now slowly work the pladder on the spindle make sure one of the pladder holes allows you to see the motor, put a small blunt object between the belt and the inner pladder and use it to stretch the belt to slip over motor then push the pladder down and rotate it making sure the belt is turning with the motor, next replace the rubber disc and finally the C clip if it is present.
Dec 21, 2010 | Teac P-A688 Turntable
Cd player stops spinning about 30 seconds after it starts. I opened the case and watched. It starts playing ok and then slows down and eventually stops.
Dec 04, 2009 | Teac CD-P1260 CD Player
CD player cover/door won't stay closed
The intermittent version of this seems to be related to the cable that goes to the subwoofer portion. Have seen this behavior when the cable got loose. Unfortunately, I believe that this behavior may get worse in the long run and cause CDs to not play at all.
Jan 25, 2008 | Teac CD-X8 CD Shelf System
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
CD drawer won't open
hi, try opening up the cover lid, and manually give a mild push to the tray, must be some small jam, or the eject belt or gear,.let me know
Dec 28, 2007 | Teac GF-300 CD Shelf System
Xbox Halo editon
You can try manually ejecting it by using a paper clip and poking it in the small hole underneath the tray.  Keep pressing it and see if you can pull it out.  After that try the eject button again.
Oct 11, 2007 | Microsoft Xbox Console
Toshiba TEAC CD-224E BA - not playing CDs at all
Just replace the drive - the Teac CD-224E is housed in the SelectBay housing and any Teac CD-224E that came out of Toshiba will do. eBay would be your best bet. If you pay more than $10 then you must be a tourist...
Sep 23, 2007 | Toshiba (CD-224E)...
Teac DVC200 System Logo
49 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
