Question about Maytag Neptune MDE5500AY Electric Dryer
The Dryer panel says the door is opened but the dryer door is closed and the dryer will not start.
  • Maytag Master
  • 3,053 Answers
The dryer switch is most likely out, need to replace. If you push in the slot where the peg On the dryer door does not click ( use a flat head screw driver to slush in slot) then the switch needs replacing.
Posted on May 29, 2011
  • Jennifer P Boals Jun 04, 2013
    Ok, when I open the door to test the dryer switch, there is a button that the door pushes when it's closed and there is also a slot where the" male" part of the latch goes into the "female"part. The "male part being on the door and "female" attached to face of dryer. Do both have sensors or just the push button? Which when I push , seems to click.,
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Posted on Dec 23, 2007
  • 1028 Answers
SOURCE: Dryer door pops open after
door strike is bad also door may be warped make sure door is not warped if it is just twist in opposite direction if strike needed part #279570
Posted on Jun 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
SOURCE: Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Posted on Jul 10, 2011
Dryer door will not start because of the dial in stating door is opened.
Good Afternoon friend, thank you for your inquiry!
If you Frigidaire dryer is stating that the door is opened it could be a potential problem with your door latch assembly or door strike. I would suggest opening and closing the door to make sure proper connection is being made with the door and latch.
If could additionally be an issue with your control panel and that may need to be replaced. I would highly recommend reaching out to a technician for proper diagnosis and repair with your dryer. -Matt
Oct 11, 2014 | Frigidaire Electric Dryer
Control panel turns on but dryer won't start. Start/pause button flashing as usual, but just beeps twice when pushed.
That generally means the door is open. Assuming you have the door closed I would investigate the switch that tells the dryer the door is open. It may be bad.
Jul 10, 2014 | GE Profile DPVH880EJMG Electric Dryer
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
I have a Kenmore Elite dryer model #11087872602 that would not start or light up the panel on the front of the dryer. I had a general appliance repair man come out to look at it. He took both computer...
the start switch needs replaced, as far as the front panel light not lighting you will need to open the back top panel of the dryer and find the wiring diagram and trace it out, it may something as simple as the connector is unplugged. Hope this helps Tim
May 03, 2011 | Dryers
Maytag Bravo 400 series won't start. I click the start button and it beeps but nothing happens.
Well first of all you can check door switch - If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. The door switch is a simple on / off switch to indicate whether the dryer's door is open or closed. The dryer will not operate when the door is open. If your dryer runs with the door open, the switch may shorted closed or there may be a dangerous electrical short in your dryer. If your dryer will not start when you press the start button and you hear no sounds, the door switch may be the problem.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Maytag Dryers
Kenmore dryer doesn't recognize when the door is closed.
first try unpluging the dryer for 5 minutes and then check it,this resets the computer board just like your house computer or you could have a bad door switch or something wrong with the main board,the main board is alot more than the door switch,if you have a meter you can read out the door switch,there should be a tech sheet in the dryer maybe taped to the side wall behind the bottom panel that might help you out.
Jan 14, 2010 | Kenmore Elite HE4 Electric Dryer
Won't start
if the door is not tight as in you can move it slightly when its closed,the door strike and door catch need replacing and can be done without dryer disassembly at the front door,open the dryer door and in the lower right hand corner theres a small plunger switch push this in with your finger you will hear a click,then start dryer with door open being careful,this test will rule out switch problem,then just replace door parts
Jan 09, 2010 | Danby DCD5505W Electric Dryer
I have a whirlpool duet washer and dryer the dryer lights all come on but I get a beeping sound and dryer will not start
try to unplug the dryer for 5-10 minutes this should reset the board. if not take off the bottom panel and test the resistance of the thermistor ( the tech sheet is in the bottom there or up top)
Dec 09, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer
Tiff...there is a switch which indicates that the door is open. Most units require that you push the start button on the timer panel to start/restart. You must have time set on the timer to direct the dryer to work.
Nov 12, 2007 | Amana DLE330RAW Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
179 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
