Question about Toshiba Satellite X205-S9349 Notebook
My x205-s9349 toshiba laptop is getting hot in the area of #1 hard drive and shuts down. I have vacuumed the case out and still does the same thing. this laptop has run hot ever since it was new.
  • dbh7896 May 29, 2011
    where is the cpu fan on this model
  • Toshiba Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this. Use a fan assisted laptop cooling pad for addition cooling.
Posted on May 29, 2011
Testimonial: "still need to know where cpu is located"
  • Chris Hingee
    Chris Hingee May 29, 2011
    The fan and heat sink is under the keyboard.
    This WEB site shows you how to take apart your Toshiba.http://www.irisvista.com/tech/laptops/To...
    You can download a manual for your model Toshiba from this WEB site.http://www.retrevo.com/search/v2/jsp/myt...
  • 21 Answers
I think you are on the right track in trying to clean out the dust. I had a Toshiba laptop that had the same issue. What I learned is that I was unable to get the amazingly packed-in lint and dust without taking the laptop completely apart and removing the cover to the heat sinks. Compressed air and vacuuming only removed about 20% of the crud in there. Once i got it completely cleaned out, it worked great. Good luck!
Posted on Jul 02, 2011
Dell computer cd rom drive disappeared
First, try a cold start, shut down, unplug, remove battery, plug in, reboot. Any change? Yes/No? If no, do a system restore to a date before this issue, or re-install the CD rom driver. Toshiba Support: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1757702&rpn=PSPB9U&modelFilter=X205-S9349&selCategory=2756709&selFamily=1073768663
Jan 05, 2013 | Toshiba Satellite X205-S9349 Notebook
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Toshiba x205-s9349 overheating and shutting down
First thing you need to do is vacuum out your cooling ports. Sometimes they get so clogged with dust it packs solid. Using a new can of compressed air will help also. You will be surprised how much dust comes out so don't trash your room.
Also, don't make the mistake of sitting it on soft surfaces (like your lap or bed) that may block off intake vents for cooling.
One more thing, make sure your battery was not part of the battery recall that took place several years ago because of over heating. Google the number on your battery and see what comes up.
May 10, 2011 | Toshiba Satellite X205-S9349 Notebook
Where is the jumper located on the Toshiba satellite x205-s9349 motherboard? i need to reset my bios password and on this model i cannot find it.
Pointing you to another FixYa member who had the same problem. Follow the steps outlined here!
http://www.fixya.com/support/t8428898-get
Mar 09, 2011 | Toshiba Satellite X205-S9349 Notebook
What brand bios does this model laptop use? X205-S9349
In the toshiba startup post display, should be a F key promting you to press for setup. Press that F key and it should take you into the bios menu, and your should be able to know what version or who the bios company is.
Jan 31, 2011 | Toshiba Satellite X205-S9349 Notebook
I have an x205-s9349 and the number pad doesnt work at all. i can get the key lock to light up if i press fn f11 but thats it. any ideas?
restart the laptop, if it did't help shutdown and take out the battery, put it back after a minute...
hope this helps...
Sep 06, 2010 | Toshiba Satellite X205-S9349 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
233 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
