Question about Cycling
The left pedal of my daughter Kawasaki KX 16 Bike wont go in i think it do not have enough threading
    President:
  • 2,080 Answers
Only the left pedal (as you are sitting on the bike) is reverse threaded.
So for the left pedal you turn the bolt head clockwise (towards the back of the bike) to loosen it.
And for the right pedal you turn the bolt head counterclockwise instead (still towards the back of the bike) to loosen it.
Here are a few links to some website articles and videos with more information:
http://www.jimlangley.net/wrench/pedalbasics.html
http://www.youtube.com/watch?v=SXxplE_L1Rw
http://www.ehow.com/video_4415604_remove-pedals-bicycle.html
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and videos at the websites indicated.
Thank you and good luck.
Posted on May 29, 2011
How to get pedals off
the pedals are reverse threaded. So instead of "righty tighty" it's just the opposite.
Apr 19, 2014 | Toys R Us 1001325 Avigo 20 inch Little...
I cant remove my bike pedals
Frozenbike pedals are not a problem if you follow a few simple steps. To begin with,the Right Pedal is standard, and the Left Pedal is Reverse Thread. If you areturning the wrong way, they will never come off. The trick is to use thecorrect wrench, skinny enough to slide in place without slop, and try toposition the wrench next to the Crank Arm in such a way that you can squeezethe Pedal Arm and Wrench together as if giving a very firm hand shake. Justsqueeze hard, and 90% of the time it will break free. If it doesn't, then sprayWD-40 or some other penetrating lubricant on both sides of the threads takingcare not to contaminate the grease inside the pedal bearings. You might have togive it a good soak, and bang the metal crank arm several times to make thelubricate work its way into the thread, sometimes leaving it for 24-hours canmake easy removal the next day. Remember, the Right Pedal is Right, and theLeft Pedal is Reverse, meaning, the Right Pedal tightens normally in theclockwise direction, and loosens in the counter-clockwise direction. The Rightpedal is from the Bike Riders perspective, when sitting on the bike, the Rightpedal is on the Right Side. An extension pipe can be slipped over the wrenchextending its length 2 or 3 feet, and will bust free just about anything frozentogether, however such a method risks damage, and you might end up needing toreplace the Crank Arm.
Feb 07, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
Bought a sunny pro indoor cycling bike sf-b901. left pedal wont thread into crank, csn sending crank but i cannot get crank off of bike. how can i do this
Try turning it in in the opposite direction. Bike pedals are reverse threaded which some people will miss when they are putting different pedals. Otherwise try starting the pedal at a slight angle, this may be enough to get the thread started.
May 05, 2011 | Cycling
Are the pedals 9/16 or 1/2" shaft. I have to
Remove the right one and measure it or take it to a store or bike shop. Keep in mind the left one is LEFT HAND THREADED.
Some illustrated guidance...
http://www.parktool.com/blog/repair-help/crank-removal-square-spindle-type-and-campagnolo
Feb 01, 2011 | Schwinn Meridian Adult 26-Inch 3-Wheel...
What is the size of the thread of a standard bike pedal?
There are 2 standard sizes:
Standard one-piece cranks 1/2" x 20 tpi
Standard 3-piece cranks 9/16" x 20 tpi.
The Right Pedal (gear side) has a normal thread, the Left has a reverse thread.
Dec 21, 2010 | Huffy Pro Thunder Boys 16-Inch BMX Bike
2001 KX 250 - Cant get the clutch hub nut loose (30mm) used breakover bar and socket also used impact wrench. Nut wont budge. Any suggestions ?
Sorry guys but its probably not!!! left hand theads the clutch nut is peened down on the threads dont beleive me look you eill see little lines or punch marks on the nut their is a special tool you can buy or you can make one like i did to hold the clutch hub still.You were on the right track with the impact wrench if that dont work you dont have a big enough air supply for the wrench good old elbow grease should get it i did it by hand after i had the tool. PS- you must punch the nut in a few places once reinstalled. I learned the hard way by breaking it first
May 28, 2010 | 2003 kawasaki KX 250
The pedal came of my daughter's bike. How do I
the left side pedal is a left hand thread, turn it anticlockwise to install, Right side pedals are RHT turn clockwise
Apr 26, 2010 | Huffy 20 In. Girls Celebration Single...
How do i no wo model my bike is
Well if it looks like that picture, it's a dirt bike, not legal for street use. If it has head lights and blinkers, it is a dual sport. The engine size is stamped into the head. Like .125 liter or .250 liter. I think the dual sport is a KZ and the dirt bike is KX. That is Kawasaki.
Feb 20, 2010 | 2003 kawasaki KX 125
Barbie bike petal broke
You'll have to replace the pedal-it's not really wise or safe to reuse or fix the old one if they break.-they may hurt your little one's feet.
On a side note, pedals are usually only sold in pairs, so you would have to replace both of them-if you want them to match.
Also, take note: the left pedal is a left hand thread, the right pedal is a regular(right-hand) thread. This is so they don't unscrew while the bike is being pedaled. On a standard bike you need a 9/16" wrench to screw/unscrew the pedals. Put the wrench where the pedal goes to the crank, and unscrew it there. The left hand thread means it will be the opposite of the "righty-tighty,lefty-loosey" rule for unscrewing normal right hand thread screws.
Might want to hit it with some penetrating oil and let it soak for a bit, before you try breaking it loose, it might be stiff!
Hope this helps!
Nov 07, 2009 | Dynacraft Girls 16" Barbie Bike
Cycling Logo
49 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
