Question about Stainless Steel Patio Heater
Our patio heater ignition lights but when you let go of the button the pilot light does not stay on. Have tried blowing out entire workings with an airline and put back together still same problem.
    Brigadier General:
  • 4,736 Answers
Since cleaning the heaters inner workings did resolve the problem, that leaves only one other thin ... The Thermocouple has failed and needs to be replaced. It's not difficult to do, but does a take a little time and patience. Since you didn't mention what brand and model number heater you have, it's hard to direct you to where to purchase the replacement thermocouple. However, Blue Rhino manufactures most of the Patio Heaters under several different names and models, that's the place to start. Their Customer Support number is 1.800.762.1142.
Hope this helped to solve the problem.
Posted on May 29, 2011
I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
Propane Patio Heater Troubleshooting - YouTube
? 6:54
www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
My pilot light wont light and my heater will not stay on.The ignitor is cliking as if it works but will not ignite and if I manually light it the lighter will not stay on.
Essentially all gas devices regardless of which gas used, are equipped with a thermocouple that monitors the pilot light's condition and if it fails, it will not permit the main flame to light or the pilot light to stay lit. In your case, it may be that the TC failure also prevents the lighting of the pilot light.
May 20, 2011 | Endless Summer 200209 Open Flame Patio...
Pilot light is too low - will not touch thermocoupler and ignite
the pilot orfice is blocked needs taking out and cleaning or try blowing it with air , or place a tube on and blow down it with the pilot off might blow the dust out
Oct 02, 2010 | Vanguard International Blue Flame - Medium...
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
The propane ignites, but shuts off after 2-3 minutes
check to make sure the thermocouple is stays in the pilot flame could be bad i think lowes has them in the water heating section
May 11, 2009 | Stainless Garden Sun Steel Propane Patio...
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
162 people viewed this question
Top Stainless Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
