Question about LG Audio Players & Recorders
My LG surround sound is stuck in "bypass" - LG Audio Players & Recorders
I own a hitachi av surround reciever model No. HTA-DD3W. It has recently developed a problem in that it does not play in any other mode than stereo, ie no surround sound, multi stereo etc. please help
Hi amstok
Sounds like it may have a DSP failure. Straight stereo signals bypass the DSP stages. Could be an expensive fix. I suggest you take it to a Hitachi agent for a quote. Not something that can be easily fixed on the kitchen table I am afraid.
regards
Graeme
Mar 08, 2008 | Audio Players & Recorders
No sound from zenith dvt412 stuck in bypass mode..how to override?
this is a protection circuit.
When bypass mode then it means that something in the power supply module has failed and the unit then goes into protection mode to protect the board components.
Your surround sound need service from a qualified tech. No other remedy.
Mar 24, 2010 | Zenith DVT412 System
Lg lhb953 wireless streaming or not
what do i need to make the lg lhb953 play my tv in surround sound.
Mar 15, 2010 | LG LHB953 Theater System
How to hook old surround sound sound up to new lg
if your old surround has either optical or coaxial connections you should be fine. if not you'll have to go with the audio in jacks (video 1,2 etc.) you'll get sound but not true 5.1 sound
Oct 22, 2009 | Audio Players & Recorders
How do i get my ps3 to run through my lg surround sound
Connect your yellow and red lead from the PS3 to the surround system, connect them to aux input. (the white lead is not needed). Then in the sound settings on the PS3, go to audio multi-output and change it to on. On your remote for the sound system press the input button until aux appears on the front of your LG HT303SU, and thats it, happy gaming.
May 18, 2009 | LG Televison & Video
How can i get the surround sound to work.
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Apr 08, 2009 | Audiovox Audio Players & Recorders
LG HT 503PH Hi-Fi Surround Sound only come with one black lead that fits into the TV but nowhere to fit into the DVD system
You need to get an optical cable (not supplied with the system of course!). Will cost about £20. That will fit from the sound system to the TV to give you 5.1 surround (else you're stuck with stereo) and THEN you need HDMI from your DVD to the TV... presuming that's the way you're going. Else it's whatever you output from DVD to the TV and then the TV sees you have optical out and pushes the sound to the 5.1 system.
Dec 11, 2008 | LG Televison & Video
244 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
