Broadband connection type using Belkin NIMO
I am uncertain which connection type to use Dynamic or one of the other types from the drop down menu. Can you help
    Sergeant:
    Champion:
  • 236 Answers
Use dynamic for normal use of the network and internet.
If you have servers and/or a domain, you should choose another option that corresponds to your setup.
Posted on Aug 25, 2008
  • Randy Villalobos
    Randy Villalobos Aug 27, 2008
    the last part is only for advanced people.
Sir The belkin wireless router is not responding in BSNL PPOE broadband connection what is the way to get connected through the ISP of BSNL. murali
IF u are using the BSNL broadband connection, you might be having a modem provided by the BSNL, 7230 model is only a router, it doesnt have modem option so all u have to do is
1. Go to belkin page 192.168.2.1(if u changed the ip address in router, then type the default gateway of the router)
2. Click on connection type
3. Setup as a dynamic connection since the PPPoE is already set on the modem
4. Follow the on-screen instructions
5. Check the internet status, if its still showing as not connected then powercycle the router for 15 sec and then reconnect the cable
Hope it will work
Sep 29, 2010 | Belkin (F5D7230-4) Router (587009)
Belkin G wireless basic home router installed ,followed instructions on cd .showing no connection on laptop.provider is virgen media,broadband via ethernet connection.any ideas.thanks
connect computer to router with an ethernet cable, open IE, on address bar type: 192.168.2.1. hit enter, u'll get a belkin router set up. in the left hand side click on "connection type".. it'll ask for a password, leave it blank and hit submit. on the next window click on dynamic ..click next.. click apply changes. then on the left hand side click MAC ADDRESS, click clone, click apply changes. then unplug the power from the belkin, unplug power from ur modem. and plug out the co-axial cable behind ur modem. wait for 2 mins. plug the modem back 1st.. wait for 3 mins.. plug back the belkin.. it shud work
Jan 13, 2010 | Computers & Internet
Belkin N Router does not recognise PPPoA connection type
First reset the router by pressing the reset button for 10 seconds while power is ON and then after that run again the setup , just to give you a clue which one to choose for the internet setup, if you use Cable internet select Dynamic and if you use DSL internet set it to PPPoE and provide your email and password from your DSL company...
Dec 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Zyxel to connect automatically
Connect your modem to internet port of the router and your computer to any numbered slot.Now open 192.168.1.1 in your internet explorer,it will ask for username and password.Leave the username blank and in password type admin.You will get the linksys page.On the setup page you can see internet connection type.select PPPoE from the drop down menu.In username and password enter the username and password which you use in dialing broadband.Scroll down and click on save settings.Turn off the router and modem.Power up your modem first and then router.Now you wont need to dial broadband.You will be connected automatically.
Mar 27, 2009 | Linksys Wireless-G WRT54G Router
No internet connection
I received this solution from Belkin. It worked for me & I hope it does for you. Good luck!
Belkin solution:
Please follow the details given below:
1. Please contact your internet service provider to know the connection type details (Is it PPPOA,PPPOE, Dynamic or static)
2. Belkin router F5D8633 ADSL router works only with ADSL broadband connection and does not support Cable broadband connection.
3. Do not use the Setup CD Assistant; reset the unit and configure it manually. Make sure to set the correct VPI/VCI values in the process as the default settings may not be correct.
4. When using PPPoA, always use VcMux encapsulation, when using PPPoE, always use LLC encapsulation. Keep the VPI and VCI as 0/38.
5. Please follow the instructions given below to configure the router manually:
- Connect the phone line direct to the router, or through the filter.
- Connect the computer to one of the LAN ports on the router.
- Switch off the router and power it back after 5 seconds.
- Restore the router to factory defaults by holding down the reset button on the back of the router.
- The power light will flash and then come back ON solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the router should be lit-up.
- Check if the computer has an IP address in the range of 192.168.2.x
- Click on `start` & click `Run`.
- Type in `cmd` & click `ok`.
- Type `ipconfig` and Enter. Check for IP address, subnet mask & Default Gateway.
- If not, specify a static IP address, gateway and DNS by following the steps at http://web.belkin.com/support/kb/kb.asp?a=2824
Then follow the below instructions to reset IE.
-Open Internet Explorer
-Click on Tools -> Internet Options
-In the General tab, click on Delete Files under Temporary Internet Files
-Click on Clear History
-In the Connections tab, select Never Dial A Connection and click on LAN settings
-Uncheck all the options and click on OK
-In the Advanced tab, click on Restore Defaults
-Click on Apply and then OK.
- Open a new Internet Explorer window and on the address bar please type in http://192.168.2.1 and click on go.
- You should be able to access the routers set up page.
- By default the password is blank.
- Click on Connection Type and Reconfigure the connection on the router (using your ISP details).
- Save the Changes.
Note: Please obtain the correct values regarding the Internet connection from your Internet Service Provider.
Internet Status should show Connected on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information given below:
1. Type of connection provided by the ISP (Is it PPPOA,PPPOE, Dynamic or static)
2. The ADSL light status on the router. Please let us know if the ADSL light status on the router is solid or flashing.
3. ADSL broadband connection or Cable broadband connection.
4. Operating system on the computer and the version number for the internet explorer like IE 6 or IE 7.
5. Internet Status shows as Connected or Disconnected on the top right hand corner of the router web page.
Log on to the router web interface at http://192.168.2.1
- By default, the password is blank.
- Click on Security log under "Firewall" option (let us know the message you see under the security log or send us the screen short of the message you see under the security log)
6. Then, check the IP address of the computer. For checking the IP address:
- Click on start & click `Run`.
- Type in cmd & click `ok`.
- Type IPCONFIG and Enter. Check for IP address, subnet mask & Default gateway.
- The IP address should be in the range of 192.168.2.x (x=2 to 254)
- In the command prompt type PING 192.168.2.1 & Enter. Check if you are getting replies.
- Type, PING 4.2.2.2 & press Enter. Check if you are getting replies.
- Try pinging yahoo by typing PING yahoo.com and Enter. Check if you are getting replies.
Dec 28, 2008 | Belkin N Wireless Modem-Router F5D8633au4A
I cant get my belkin router to work with sky broadband
You may need to ask Sky Broadband with the type of connection you may need to set up to the router. It could be a dynamic IP or static IP. Whatever settings your ISP requires, then it must be configured in your router.
Hope this helps!
Nov 14, 2008 | Computers & Internet
How do I go about securing my home network. I use Belkin G Plus NIMO.
Open a browser window and in the address bar type 192.168.1.1 or 192.168.2.1 and this will open the router page. Navigate to the security and enable whatever security level you require. Hope this is a help. Let me know if there is anything else.
Aug 22, 2008 | Belkin Computers & Internet
Have belkin wireless/modem router, was using aol but now with the utility warehouse using there uwclub.net service. They sent a thompson speedtouch fixed line modem which we had to connect to get on i.e.,...
Try using a dynamic ip address. I think you only use the static if having problems. Just read this.
A dynamic IP address is assigned to a customer’s modem or router, generally via a remote server (such as our own UWClub server). This provides the user with an IP address from an available pool of addresses every time a connection is made. This is the most common type of IP address for our broadband/Broadcall customers.
Thats off The Utility Warehouse page.
Aug 04, 2008 | Computers & Internet
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
