Question about DreamCatcher Interactive Wildlife Zoo Deluxe Edition for PC
I have Wildlife Zoo (not interactive). I installed the disc, but can not open it to play. I have Windows 7 and says not compatable with program name WLP2.exe Can you help me? Thanks
  • 159 Answers
1.
Go to the location of the file WLP2.exe in the root directory of the game, which is normally located on Computer>drive C>program files> and then under the company name, dreamcatcher.
2.
Then right click the file and choose "Properties" and then select Compatibility Tab and make it to run under Windows XP, and checkmark the box that says "Run as Administrator".
3.
Push ok, then restart the computer.
4.
Double click that .exe file: WLP2 where I directed you before and see if it worked.
Hope this helps!
Posted on May 29, 2011
Why am I missing one of the files needed to run wildlife zoo?
This is because with Win 7 and above the kernel was changed again, while I wont try and confuse you with tech talk, if you run a search for the file you are missing you will find it and be able to download it and set it up for your Wildlife Zoo to work.
May 13, 2014 | Dreamcatcher Wildlife Zoo jc
Zoo tycoon can't load/save games
Unfortunately running an older game like this, you will have issues. Make sure you have the latest updates installed. If that doesn't resolve the issue you may not be able to save under windows 7. I would try compatibility for windows 98 before I give up all hope though.
Apr 07, 2014 | Hasbro Interactive Video Game Consoles &...
SAYS I NEED TO BE AN ADMISTRATOR BUT I AM
Deep Silver Wildlife Park 2: released in 2006.
Try these options.
Right click the launch Icon / Shortcut - Select Compatibility tab -
Under Privilege Level - Check the "Run this program as an administrator"
Click OK and try launch the game.
Failing that;
Run the game in Vista compatibility mode ( there should be 3 ) and see if that works.
Same method as above.
If not, try the XP modes.
Check the "Run this program....compatibility...." box and select a mode.
Hope this helps
Nov 30, 2013 | Deep Silver Wildlife Park 2
Wildlife zoo won't pay on windows 7
have you tried the compatability mode?
Mar 14, 2012 | Video Game Consoles & Games
Hasbro MasterMind does not install on Windows XP or Windows 7 ! Do they have a newer version available ? I loved the game but it only played on Windows 98 ..... Anyone have any ideas ? Thanks...
Have you tried running the installer in compatibility mode? Right click on the installer (usually setup.exe or install.exe, and if you have it on a CD, you need to open the CD in My Computer as a folder by right clicking and choosing open), go to Properties -> Compatibility -> Check the 'Run this program in compatibility mode for:' check box, and select 'Windows 98/Windows' ME from the drop-down menu. Apply the changes or click 'OK', and try to run the .exe -file. If the game successfully installs, and you can't still launch it, do the same to the game's launch .exe -file.
Mar 22, 2011 | Hasbro Interactive MasterMind for Windows
I just downloaded a version of putt putt saves the zoo on my computer and it wont even open. i think its because of the fact im on a windows 7 computer , how can i make it work?
Hi.
Right click on the game icon and select properties.
Next select compatibility mode, and select windows xp, or any other version of windows.
Then, try to launch the program.
If everything goes well, then you are good to go.
If not, then you may not be able to play it on windows 7.
ALOT of programs have compatibility issues with windows vista/windows7.
I hope this helps you out some tiday, and good luck!
Mar 14, 2011 | Humongous Entertainment Putt-Putt Saves...
I have windows xp and i installed the game Wildlife Zoo Deluxe Edition. It installed fine but when I go to play it a box comes up saying that I don't have a virtex shader 1.1
Try to find updated video device drivers.This is a error found when your video device ie vid card or onboard vid is below the min req for your game.
New drivers may help.
Jan 16, 2010 | DreamCatcher Interactive Wildlife Zoo...
I'm running 64 bit vista and I purchased zoo Tycoon 2 because sites side it was compatable with windows 64 bit. When it insert the disc and try auto run it comes up with application has faild to start...
try the steps below:
  • Click the start button
  • Click Control Panel
  • Click the icon for Programs and Features
  • Look for the link on the left side of the page with the colored shield that says “Turn Windows Features On or Off” and click it
  • Click continue when prompted for permission
  • Check the box beside the folder labeled Games
  • Click OK and the installation of the games folder will be started.
Sep 26, 2009 | Microsoft Zoo Tycoon 2 for Windows
Game will not open up
Zoo Tycoon has several problems with windows XP after SP2
Uninstall completely...
Reinstall... RESTART AFTER INSTALLING
If your DISC does not have a UBISOFT logo on it, download and install the patch from
http://zootycoon.com/Downloads/patches.htm
If it DOES you do not need to download it as you already have it and installed it when you installed the game.
If the game does not run try rightclick>properties. Compatability tab, set compatability mode for: Windows 98.
My own copy of zoo tycoon had a weird glitch where you could only run it after you restarted the computer... and if you closed it when you were done playing you would have to restart it (the computer) to play again.
Mar 24, 2009 | Microsoft Zoo Tycoon: Complete Collection...
Open Questions:
DreamCatcher Interactive Wildlife Zoo Deluxe Edition for PC  Logo
466 people viewed this question
Top DreamCatcher Interactive Computers & Internet Experts
David Payne
David Payne
Are you a DreamCatcher Interactive Computer and Internet Expert? Answer questions, earn points and help others
