Question about Ovens
Would like to know if the control circuit is 24 volts
    Sergeant:
    Champion:
  • 257 Answers
If your referring to the power going in to the main board it should be a bout 115v.
Posted on May 29, 2011
Oven doesn't seem to work though te light goes on
Check your circuit breaker for the house. It will be 2 breakers side by side with their handles pinned together. If one trips, but not the other then you'll get 110 volts to work the light and the control panel but not 220 volts for the element.
May 15, 2017 | Ovens
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
The control panel on my oven doesn't seem to be working. I pressing COOKING MODE for 5 seconds and nothing happens. The display just blinks once in a while.
In the power panel on your house. There are two circuit breakers with their handles joined.One of these breakers has tripped internally which will stop the heating elements but not the control panel or oven light since they work on 120 volts. Reset the breaker or replace it.
Feb 02, 2016 | Bosch Ovens
Turn on oven and temp stays at 75. No gas comes on and igniter does not glow. Replaced igniter and still have same problem. Have 120 volts in and out of igniter and it does not glow. Help?
Lets take a look at yer wirin diagram.
You have 4 components in the oven heating circuit. The control, the ignitor, the safety valve, and the sensor.
Ignitor has been replaced with no help right? Did you check for continuity of the gas safety valve?
themobilian_1659.jpgIf yall have nothing (open circuit) between the two terminals then the valve is bad. Won't no ignitor glow with an open safety valve. Next thing:
Sensor: 1100 ohms @room temp. Erratic or open sensor and the oven won't KNOW what the temp is. themobilian_1660.jpg
Finally and I say finally because yall want to replace the most expensive part which is the control last, after yall know for sure it ain't all of the above mentioned components.
I have some service manuals and more HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 03, 2011 | Maytag CWG3100A Gas Single Oven
I just bought a maytag 24 inch double oven.it is 240 volt and i need to know if i need to put a 3 wire or 4 wire for the power
I trust that your voltage system in your house is 240 volt. The number of wires or the size of the wiring will depend purely on the kilowatt rating of the oven. Normally on a 240 volt system a 3 wire 32 amp circuit will generally be used on ovens/ranges up to at least 6.0 kilowatt. If you need more information please reply.
Feb 14, 2011 | Maytag CWE5100ACB Oven
Oven will not go on. It is saying : F-3. What is F-3 ?????????? My oven is a slide in 30"
F3 means that the electronic oven controller has detected that the temperature sensor circuit has opened. This could be due to a failure of the temperature sensor itself, a bad wiring connection in the sensor circuit or a failure in the electronic control.
Best Regards,
Bruce
www.fixyourboard.com
Jun 22, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
I have a gas oven that is a couple (4-5) years old. I hit the bake button, hit 350, hear the click or tick and that's it! That's where it ends no "whoosh" of gas or flames afterwards.
check the voltage to the gas valve in bake cycle if the 12/24 volt is there then change the gas valve if not voltage is present then check the tranformer circuit and limit switch to the gas valve
Jan 22, 2010 | Ovens
Replacement Element does not work
If it is a double circuit element, then you will only get 110 vlolts across one circuit, and 220 volts across the other circuit..
If however it is a single circuit element, and you are only getting 110 volts, then I would suggest that you have a high resistance somewhere that is stoping it from getting 220 volts.
Hook the element directly to a 220volt supply and check voltage .
Plz rate my solution.
Thanks.
Dec 16, 2008 | GE JRP24 Electric Double Oven
Kitchenaid oven model #KEBC207
this was taken from the installation guide
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=kebc207&siteCd=WHRCOM#installation_instructions
Oven must be connected to the proper electrical
voltage and frequency as specified on the
model/serial rating plate. (The model/serial rating
plate is located on the oven door or on the oven
frame.)
Models rated from 7.3 to 9.6 kW at 240 volts
(5.5 to 7.2 kW at 208 volts) require a separate
40-ampere circuit. Models rated at 7.2 kW and
below at 240 volts (5.4 kW and below at 208
volts) require a separate 30-ampere circuit
Nov 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
