Question about Dishwashers
I need to get a replacement element for my Concept II DW. where can I get one?
    Sergeant:
    Champion:
  • 257 Answers
Any appliance parts store should carry it but I would go with one relatively close to you to avoid high shipping charge. Just give them your model number and they will be able to send it to you.
Posted on May 29, 2011
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
My concept ii oven's lower element has stopped working. What can I do?
check it with a multi meter? should have continuity.
Mar 10, 2015 | Ovens
Can I use an incandescent bulb in a MInka Aire Concept II with light & remote? What is the highest wattage I can use?
Take the bulb to a bulb store & show it to them. They should be able to find a different bulb you can use.
Feb 26, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
No light or fan minka concept ii ceiling fan
You need a new receiver or tyr resitting the one you have and see if that works.
Mar 24, 2013 | Minka Concept II Flush 44 Ceiling Fan by...
I can't unlock the latch of the concept II oven
clear everything in panel latch should open. if it doesntu need to replace that latch
Feb 12, 2010 | Kitchen Ranges
It does not heat up or dry the dishes
Depending on the make of your DW, the Heating element inside the bottom of your DW might be at fault.
Your may have a fuse that connects to the heating element that may have blown- relace fuse.
Check the heating element to make sure it is functional.
go to Appliancepartspros.com and enter your model number and find schematics of your DW to see where these things are on your DW
or if you have bosch dischwasher read this:
http://www.squidoo.com/Bosch_Dishwasher_Drainage_Problem_Fixes
Nov 01, 2009 | Dishwashers
I have a JNC digital concept power voice II
The part which shows the files to be downloaded from the JVC recorder does not open when the software starts up. It only opens when the recorder is detected attached to the USB port. I suggest 1. Start the software. 2. connect the JVC recorder to the PC with the USB cable. 3. Turn the JVC recoder ON. The recoder display says "PC link" and the files to download show up in Power Voice II on the PC. Michael C
Sep 30, 2009 | Audio Players & Recorders
HOW TO REPLACE HEATING ELEMENT
Turn off the electric panel breaker that powers the unit! Check to make certain it is off before proceeding.
You will need to disconnect the Dishwasher (DW) from the electric, water and drain lines and remove it from under the counter in order to be able to access the underside of the DW. There you will find two (2) wires connected to the heating element along with a couple of fasteners that hold it in place. Also check inside the DW for any hold down clamps, etc. on the heating element there.
Once you have removed the connectors and mounting screws, you can then remove the element from the inside of the DW. You will need to "pop" out the grommets that the element passes through from the inside to the underside of the DW, as these keep water from leaking past the elements. Just remove and save those grommets and reinstall them onto the new element and slip it back inside the DW and through the holes in the floor of the unit. Reconnect the wires and re-fasten the screws or clamps that hold the element in place and reinstall the DW back under the counter, reconnecting the water and drain lines and the electric power.
This is a fairly simple and money saving repair for the DIY'er and well worth the time it will take you to perform the replacement. Good luck and hope this helps. Here's a link to the versions of your DW that will show you what it looks like for the parts and placement for your specific unit as I couldn't locate an exact match without the rest of the model number series. Just select yours and look at the diagrams to find the heating element on the inside of the wash tub.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GU980SCG&pop=flush
Jul 28, 2009 | Whirlpool 24 in. GU980SCG Built-in...
How complicated is it to replace the heating element in the whirlpool gu1500xtls1 Dishwasher? It is not drying. Can the element be replaced from inside the unit or does it does the whole dw have to be...
would be easier to remove the dw form the cabinet , at least partially. Hopefully there is enough slack in the electrical line as well as water feed line. sometomes you can walk the d/w out woithout disconnecting them. the heating element can be unscrewed from underneath( 2 white lug screws mount them to the underneath of unit)..
Feb 23, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Concept II
Depending on what year the fan was made try looking very close at the actual body of the fan. you may find a small switch you can manually use to reverse the direction of the blades.. I may have some used working remotes that will work with your fan if you like please feel free to contact me at payitforwardx2 @ gmail . com .
Jun 08, 2008 | Minka Concept II Flush 44 Ceiling Fan by...
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
