Question about GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur...
I have GE Artica PSC23MG . fridge and freezer temp is fluctuating fridge 42 and going up and freezer between -1 and 11 degrees. fan seems ok , I cleaned it up from the back and was normal but in the morning freezer is warming up again.
  • 93 Answers
SOURCE: fridge running warm
one thing to check for if you whant the freezer to colder the fresh food compartment will not go down i temperature because you stre blocking the air floe lower the freeezer control knob thanks from gilles
Posted on Mar 15, 2009
SOURCE: I HAVE THE GE PROFILE
likely the compressor... we have the same fridge and had the same thing happen. It was sporadic...would work, then not. Finally had GE out to repair - not cheap. Part and labor was almost $300.00 and took 2 attempts to repair.
Posted on Jun 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: GE Profile Artica refrig is freezing food
Replace the cold control
Posted on Apr 09, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Artica side by side stainless steel wont get cold
The Profile and Artica are good refrigerators. the problem may be the defrost element, defrost thermostat or the mother board. Let me know if you want help on this one. Thanks Sea Breeze
Posted on Jun 18, 2009
SOURCE: temp fluctuates in ge profile refrigerator and freezer
Mine is doing the same, but because we were getting frustrated with the interminted noise and motor we kept switching on and off until we realised the frig did not work at all. The key to our problem was, let the frig do its own thing as we realised it was auto defrosting. After 3 days of meddling with this thing, we thought we killed it. Just leaving it on and forgetting about it, it righted itself, and walla it has not missed a beat since. We even blew up another frig in the mean time because of the predicament we thought we were in with all the produce. Good luck and just let the frig do its own thing.
Posted on Sep 05, 2009
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
I have a GE side by side fridge Mod. psh23pss-sv that is showing 42 degrees on the fridge section and -2 in the freezer. No frost in the evaporator. Fan is working. Condenser is clean. Temp selection is...
check the damper assy in the upper left corner of the refrige compartment you need to remove all the plastic parts on the roof and back walls to access this part there are 2 possibilities either the fan inside this assy quit or there is a door inside here that opens and closes to throttle cold air in from the freezer compartment,a lot of times this doors mounting breaks from cold and can stick shut or wherever position it breaks in,remove it and then run the diagnostics and watch this door for operation as you enter the diagnostics,also make sure the fan in there works also,if both of these work ok then you could have a thermistor problem in one or more of the thermistors mounted in the left and right side walls midway up behind oval plastic grilles
Apr 30, 2011 | GE PSH23PSSSV Side by Side Refrigerator
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
Ge artica pss25ngmd refrigerator fan on freezer & fridge warm
Most likely motherboard has gone bad. Check to see if compressor is running.
Oct 06, 2017 | GE Refrigerators
GE PFS22SISBSS Refrig compatment freezing
There is an internal door between the fridge and freezer section that allows the freezer air to enter the fridge side to keep the fridge cold. Sounds like the internal door is stuck open. Steve
Dec 21, 2008 | GE Profile PFS22 33" Artica French Door...
GE PROFILE FREEZER PFS 22 SISBSS
hopefully you have a service warranty. I have had me fridge for two years and have replaced the temp control panel twice thus far. serviceman coming AGAIN on Tuesday because now everything in the fridge is freezing. cna't get the temperature in freezer and refrigerator regulated properly. GE knows they have a problem...something in the computer panel board sticks. I'd give anything to be able to put this on the curb and buy a new refrigerator.
Jul 19, 2008 | GE Profile PFS22 33" Artica French Door...
GE Profile CustomStyle PSC23MGSWW 36" 22.7 Cu. Ft. Side-by-Side Refrigerator w/ CustomStyle Configur... Logo
212 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
