Question about Panasonic DMR-ES40VS DVD Recorder/VCR
My DMR-ES40V Panasonic fell to the carpet dangling from the wire still plugged.Now the unit will not turn on.The plug on the back of the unit is OK.I tested it with another unit
  • Panasonic Master
  • 508 Answers
Sadly, that could be the death knell on this unit as something may have broken internally; possibly rendering the unit U/S.
These can be extremely expensive to replace any fractured boards (and other broken parts) in - making the overall repair uneconomical. And in the event of any broken boards/parts replaced, there is no guarantee that the unit will be as reliable after that as when it was new.
If you decide to submit the unit to a service centre, be warned, if you tell them it fell to the floor, they may tell you the same thing as I did above (although they might not put it quite so nicely). Even if you convince them to take on the repair work, it may be expensive; more than the cost of a new DVD recorder.
Up to you, but save yourself the agony (and the expense) - bin this unit or keep it for parts (or try to find a similar WORKING unit on eBay to replace your broken one).
Accidents will happen; most times unavoidably. Sorry to be the bearer of bad news.
Posted on May 29, 2011
Testimonial: "THANKS A BUNCH FOR THE iNFO... WILL TAKE YOUR ADVICE"
Panasonic dmr-es40v
Ron, F60 is a general error code usually related to a failure on the video processing board. You could fix this by just replacing that board. Try to place it in standby mode first by unplugging it, wait a couple of minutes and then plug it back in. When the 000000's starts, hold down the power button for 15-20seconds. The unit should then be in standby mode. From this mode try to start it normally using the power button and see if it cleared the error. You could also try a complete reset by powering the unit off and press and hold the "Stop" and "Channel Up" buttons at the same time for a few seconds while powering the unit up. Hope this helps, good luck.
Jul 08, 2016 | Panasonic DMR-ES40VS DVD Recorder/VCR
DMR-es40v f60 error
Problem for Panasonic DMR-ES40V DVD-Video Recorder with Built-in... Maching displays F60 as soon as it's turned on and
Nov 13, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
F60 Error message on DMR-ES40V unit
Unplug the unit.
Plug back in and wait till you see 000000.
Press and hold the power button in at least ten seconds or until the clock shows up.
This worked to fix mine.
Jan 05, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
RDVD won't record
Dear Valued Customer,
Thank you for your inquiry, reguarding model DMR-ES40V.
Try this reset to fix the issue.
1. Unit power must be on.
2. Press [STOP] & [VHS > DVD] ON THE UNIT for over 5 seconds.
Thank you for contacting Panasonic.
Thank You,
Panasonic Consumer Support
http://catalog2.panasonic.com/webapp/wcs/stores/servlet/CustomerSupport?storeId=11251
Nov 26, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic ES40v - Can't play DVD's - Incorrect region
I had the same trouble, also wouldn't play back discs that I recorded using it. The commonly listed reset of channel up and down at the same time was not meant for this model.
Below is the official solution that was sent to me by panasonic.
After using this method to reset my player it worked great. it was just like taking it out of the box for the first time.
Thank You,
Nov 02, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DVD Recorder
We need to narrow down where the problem lies. Even without finalizing the disc, you should be able to play back the recording. Can you do this? If you can play back the recording, the problem exists in the finalization stage and we'll need to concentrate there. Pplease update this and we'll proceed to the next step.
Thanks,
Dan
Sep 07, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40V, error codesF60 & U99...
Same problem. Contacted Panasonic. Technician indicated that there is a problem between the CPU and the timer. The unit is three years old and out of warranty, so he offered Panasonic's service at $120 for labor plus any parts.
So I gave it one more try. I pressed and held the REC on the Power button for about 10 seconds, which reset the unit. Then I was able to play a DVD and eject it.
Hope this helps with your unit.
Jul 21, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Panasonic DMR-ES40VS DVD Recorder/VCR Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
