Question about Proform Crosswalk 500 Treadmill
My proform xp 580 powers up just fine but when i hit the start button it will turn the belt for about 1 revolution and then it stops.
    Top Expert:
  • Proform Master
  • 12,223 Answers
How do I get the belt unstuck from the right side?
You will need to loosen up the right side one revolution, then run the belt at .5 revolution. Watch the belt then retighten the right side slowly until the belt stays in the center. Once its running in the center for at least 1 min without moving over more to right you can stop tightening.
Exercise equipment service Treadmills Ellipticals and Bikes Parts Assembly...
Jul 17, 2015 | Proform Crosswalk Advanced 525x Front...
I have a proform xp trainer 580 . The display works but the actual walking belt doesnt move.
please see the video and fix it according.God bless youThis happen because the lack of maintenance schedule .
Apr 04, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 trips the breaker as soon as you turn it on
Treadmills have up to a 15 amp power draw. They are like space heaters, Proform often recommends having a dedicated 15-20 amp circuit for a treadmill. Ellipticals have less power draw.
I repair most Icon products, is this a new problem with an old treadmill? If it is a new treadmill, call the number in the front of the manual, if they can't fix it over the phone, there is a good warranty on it. At least for a little while. ;-)
Jan 21, 2013 | Proform XP 580 Trainer Treadmill
Proform xp 580 - Occassionally, any button i push simply beeps, and nothing else happens, no response from the panel.
Step 1:
please replace the old batteries with a new ones, with the same mark+same polarity+full charge.
Step 2:
adjust the REED switch, see the diagram attached, test for open or faulty, clean it, and tight the connector very well .
Step 3:
tight all connector a) ribbon cable inside for keypads b) upper connectors board display vs lower connector main board.
God bless you
Jan 04, 2013 | Proform XP 580 Trainer Treadmill
Loud clunking noise in rear roller of proform 580 treadmill
You must LUBE the deck belt first, this happen because you do not lube maintenance schedule, Do it every week from use.Maybe you have a WORN deck belt.
2) LUBE the rollers bearing front and end, use WD-40
3) Test the drive belt motor, for cracking or worn, and replace.
God bless you
Nov 29, 2012 | Proform XP 580 Trainer Treadmill
Can't get my proform xp 580 trainer treadmill out the door
sony ericession text pro ck 15i i want incoming sound incrise (or)...how to sending blooth with video
Nov 20, 2012 | Proform XP 580 Trainer Treadmill
Stops running, display flashing
1) LUBE THE deck belt, maybe you have WORN deck belt, time to replace
2) LUBE the rollers bearing too, very well
3) test the bearing from the main motor, time to repair.
God bless you
Nov 11, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580 and my treadmill makes a clicking noise as if it is trying to incline what should i do?
1)Please lube the gear and shaft, very well from elevation motor
2) Test the motor, and replace if necessary.,see for ball bearing and lube
3) Lube the deck belt, and guide for instruction manuals.
4) Test the main switch, and reset button with VOM, for open, test and replace see the diagram how to do it.
God bless you
Jun 08, 2012 | Proform XP 580 Trainer Treadmill
Just starts and stops immediately
1) Lube the deck belt, maybe is worn, to due the lack of maintenance.
2) Lube the rollers bearing front and rear very well.
3) TEST THE voltage motor input, if there are voltage, the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
May 14, 2012 | Proform XP 580 Trainer Treadmill
I have a proform xp 580. when I turn it on,
Press the Stop and the Speed Up keys down while inserting the safety key.
Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
Press either incline key and the incline will calibrate automatically.
After completing calibration of incline, press the Stop key and then remove the safety key.
Jun 12, 2010 | Proform XP 580 Trainer Treadmill
Proform Crosswalk 500 Treadmill Logo
89 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
