Question about Vacuums
No Manual for Dimplex OFC 2411T1 Oil Heater, can not get it to operate at all
  • 844 Answers
Welcome to FixYa!
Please click the link below to download the manual of the Dimples OFC 2400 series.
http://assets.glendimplex.com.au/assets/0000/2025/v1/OFC1200_-_OFC2400TIF_User_Manual.pdf
The manual is a PDF file and opens in acrobat reader. If you do not have an Acrobat Reader, you can download and install from Adobe http://get.adobe.com/reader/
I hope this manual will reach you in time before you freeze! :-)
Thank you for using FixYa. Have a great day. Jas247
Posted on May 29, 2011
Where do you put oil in the overlocking machine
what does the manual say to OIL .many do not require oil as in the OLD DAYS
Feb 11, 2015 | Singer 14T968DC Serger/Overlock Machine
Which kind of oil using for SV 520T sammic vacuum machine
Here is the link to the owner's manual for your model. It tells you everything you need to know about adding & changing the oil and what oil to use:
http://www.sammic.com/dl/116722/a1f67/instructions-vaacum-packing-machines-sv-t-timer-w-vac-norm-new.pdf
Feb 03, 2015 | Vacuums
The Orange "ON" indicator light
We need lots more info...oil won't heat ?...is this a vacuum cleaner ? Pop corn popper ? Oil filled radiator heater ? Company name...model number...anything ?? Help us help you. Thanks.
Nov 06, 2010 | Vacuums
I have a McCulloch Model PM 310 , Gas Chainsaw. How would the spark plug be accessed?....Rich
Storing a chain saw for longer than 30 days requires storage maintenance. Unless the storage instructions are followed, fuel remaining in the carburetor will evaporate, leaving gum-like deposits. This could lead to difficult starting and result in costly repairs. Never store a chain saw for longer than 30 days without performing the following procedures:
Remove the fuel tank cap slowly to release any pressure in tank. Carefullydrain the fuel tank.Start the engine and let it run until the unit stops to remove fuel from carburetor. Allow the engine to cool (approximately 5 minutes).
Using a spark plug wrench, remove the spark plug.
Pour 1 teaspoon of clean 2-cycle oil into the combustion chamber. Pull starter rope slowly several times to coat internal components. Replace spark plug.
Store the unit in a dry place and away from possible sources of ignition such as a furnace, gas hot water heater, gas dryer,etc. When removing the unit from storage, be sure to perform the following procedures:Remove spark plug. Pull starter rope briskly to clear excess oil from combustion chamber.Clean and gap spark plug or install a new spark plug with proper gap.Prepare unit for operation.Fill fuel tank with proper fuel/oil mixture.
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 15, 2009 | McCulloch MC1275 Steam Vacuum
How to operate bissell carpet cleaner.
Look at the Bissell web site. You can enter the model number and get the operator's manual for Bissell products.
http://www.bissell.com/
May 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
Indicator lights on Bissell 7920
According to the owners manual there is a red light that signals temperature, this light will come on when the water reaches optimal temperature, the heater may need to warm up again. Here is a link to your owner's manual.
http://www.bissell.com/images/UserGuides/7920.pdf
I hope this helps.
Jan 21, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Heater/fan issues
There is a safety switch which will shut the heater element off if the fan doesn't run. If the fan doesn't circulate air, the element would overheat and could possibly start a fire, so the switch will shut the element down. I'm not familiar with this heater, but I would check to make sure the fan is operating and also check for any filters that may be plugged and restricting air flow. If anything interferes with the air passing through the heater, the overheat switch will shut down the element. That's the best I can do from here. Good luck.
Feb 28, 2008 | Vacuums
Power Consumption Refridgerators
I have a 10KW stik welder/generator. I have no problem running a large freezer and 2 fridges except for the startup current draw. I have a $300 transfer switch connected to a 60amp sub panel with current meters on each leg. I have to watch the current draw and turn on & off breakers. I do have to play the "green acres" game because I have the water heater, well pump, and kit ckt all connected as well. Coffee machine, toaster, oil furnace, microwave all have to take turns as well as the water heater(4500WATTS). Cost was about$3500 in 2001 and $600 for a generator shed. lots of my labor. Last time we lost power it payed for itself. 28 hours without a generator would have been a trip to a hotel and lots of spoiled food to dump. hot shower and coffee anytime a big +
Nov 20, 2007 | Vacuums
Vacuums Logo
53 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
