Question about LG LFD750 Shelf System
Can't get the stereo out of "demo repeat play" - it won't even turn off. If I unplug it, it automatically comes back on in "demo" play when plugged back in
    Brigadier General:
  • 8,546 Answers
It's in the manual, page 24.
DEMO
Press EQ master on the front panel in power off state to demonstrate the function in the display window. To
cancel it, press POWER or EQ master again.
Posted on May 29, 2011
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
My kenwood kdu-u7053bt won't keep it's memeroy. Keep going to demo mode when I turn the car on.
go back to the stereo shop and make sure they connected the memory wire on the unit to a constant 12v source
Feb 03, 2013 | Kenwood Car Audio & Video
Can't get rid of LED TV logo on Samsung TV
Apparently it's on demo-mode so you have to go to 1. Set up 2. Plug and play 3. Then change to home instead of demo
Jan 27, 2012 | Samsung 32 UN32D4000 LCD TV
My turn signal won't lit when activate and my brake light also wont also but is illuminate. The Top Brake light do light up when but only when the lights are turned on manual setting if they are on...
possible multifunction switch gone bad for turn signal problem. do headlihgts come on in a dark setting on automatic or not? if they don't come on when it is dark then most likely bad light sensor in top of dash or maybe unplugged if recent dash work has been done.
Jul 13, 2011 | 2002 Mercury Mountaineer
I am not getting any output to the phones or monitors. I've tried CD player, and I get levels, but no output. I've tried play back while attempting to to play through the system. Is there some way to...
See if you can download the original "demo song" into the unit and see if the demo works. Should be able to find that on the Korg site under support.
Apr 20, 2011 | Korg D3200 Digital Studio
"repeat demo play" is continuously
The manual on page 24 says:
DEMO
http://www.retrevo.com/support/LG-LFD750-Home-Theater-Systems-manual/id/17203ag405/t/2/
Dec 27, 2010 | LG LFD750 Shelf System
Panasonic SA-AK17 MASH stereo system
That demo mode thing is painfully annoying. With mine, I had to hold the 'display/demo' button in for about 1 second and then the words "NO DEMO" appeared. That fixed it.
Apr 24, 2008 | Audio Players & Recorders
Turns itself on
Hey there, you actually need to press the Stop /-DEMO Button when the device is doing the demo mode...it will take about 8 seconds and it will display "DEMO OFF" and turn off. This procedure needs to be run everytime there is a power failure OR you unplug it from the wall.
Pressing the Stop /-DEMO while it is on will cause it to start the demo while it is running!
Regards, Joel
Feb 23, 2008 | Panasonic SC-AK200 CD Shelf System
LG LFD750 Shelf System Logo
210 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
