Rca tv will not power on but power switch flashes 9 times pauses then flashes 5 time then repeats the sequence. full power off (unplug tv from power) has no effect.
  • bjesch May 30, 2011
    is a projection type tv, modeol D52W20B, chassis ITC222, if you need swerial let me know.
    manufacture date is may 2004.
    thanks
    ted
  • bjesch Jun 01, 2011
    any luck yet? i posted the information you reuested.
  • 1,238 Answers
May I know the following info on your TV?
  • what is the model #
  • what type it is crt?lcd?projection crt?projection DLP?plasma?
Thank you
Posted on May 29, 2011
  • bonifacio gomez
    bonifacio gomez May 30, 2011
    what type?
    it is crt type or DLP?
Won't power on, OPC & power light blink. Power light blinks immediately after then repeats sequence?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 02, 2015 | Sharp LC-42D65U 42" 1080p LCD TV - 16:9 -...
Rca hd52w59 tv. power light blinks three times in
Thats usually caused by the CP150, CP114 and CP120 capacitors which will need replacement. You can get that repair kit at www.tvrepairworld.com and the kit contains the CD with instructions for the repair.
Dec 14, 2009 | Televison & Video
I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Dec 04, 2009 | RCA HD52W56 52" Rear Projection HDTV
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
Flashes/blinks 9 then 5 won't turn on.
Check the CRTs . That model was notorious for laser like cuts right around the neck by the yoke. I just had one today doing the same thing. The CRTs are no longer available so the set is scrap. I hope that's not your case. Let me know.
Oct 20, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W19BYX2 power light blinks once pauses, blinks a 2nd time, pauses, and blinks a 3rd time. Wait about 65 secs and it will do it again. Happens whether I use the remote or the switch on the set. Also,...
try unplugging the tv overnight, then plugging it in when you want to watch it.
i guess there is some safety switch on the processor inside the tv itself that kicks itself on...stupid.
that is the only "band-aid" i have found that works
Apr 10, 2009 | RCA D52W19 52" Rear Projection Television
Timer light will not go off and I cannot turn on TV
ybhughes,
Are you asking about the wd62525? If so that's a v26 chassis and equipped with a self diagnostic test by flashing a series of two digit sequence after depressing the power button. After depressing the power button count the number of flashes - then you'll see a slight pause - then another series of flashes. (for example: four flashes, pause and four more flashes is an error code 44). The unit repeats this coding at least three times so be as accurate as possible...
Bill
Sep 26, 2008 | Televison & Video
Power light flashing????
Count your flashes and call the RCA hotline and they will be able to tell you what the number of flashes says about your tv. My lamp needs replaced and I was told 3 to 5 flashes meant the lamp was out.
Jul 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
