Question about KitchenAid K45SS Classic Stand Mixer
I don't have a problem yet, but my Mother's mixer is from the 1970s when they first came out. It still runs and works, but should I grease/oil it? I am mechanically inclined but will let sleeping dogs lie if that is what is best.
    Problem Solver:
  • 13 Answers
My aunt has one of these but rarely uses it and was storing it off its base and the grease started breaking down and leaking out. if your moms is not leaking and it is used frequently it may be o.k. but you can download a parts breakdown from appliance parts online, this will show how the case comes apart so you can add or change grease.
Posted on Aug 28, 2011
I don't know what converter to get to have my american mixer work in Spain
You will need a transformer to step the Spanish 230 volts down to your 110 volts.
Nov 24, 2012 | KitchenAid 32685 Mixer
My stand mixer's motor runs but the blades don't turn to mix the food
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
The Worm Gear (12) teeth was stripped and needs to be replaced.
The whole Worm Gear Assembly can be purchased on eBay for under
$15.00
Aug 04, 2011 | KitchenAid K45SS Classic Stand Mixer
Hi, I have a Kitchenaid stand up mixer custom edition 500 watt model #Kd2661xmc that sounds fine when I don't have anything in it, but sounds like its crying when I put just a single cake mix in it. ...
Get A Copy of the Repair Parts List for your model at Kitchenaid.com.
Remove the Gearcase Motor Housing (1) & the Transmission Housing (7)
Remove the 2 screws (23) holding down the Motor (2) and lift off way from
the Worm Gear (17). Test run the motor by itself at different speeds.
If it runs fine then it's time to inspect all the gears in the Transmission
Housing(7). Remove all the brown Grease covering the gears.
Pay attention in particular to the teeth of the Worm Follower Gear (19).
(the Bevel Gear (21) sits on top of this gear)
They should not be worn out or chipped. If they are then this is the source
of the noises you're hearing (the Worm Gear is grinding away the teeth of
the Worm Follower Gear). Once the Follower is replaced, your mixer will
be just as new again.
Please Note that this replacement is not an easy task. You need the right
tools and don't use a hard object like a steel screwdriver to pry out the
Planetary plate (15) from the beater shaft. Before re-assembly, use only
fresh new Food Grade Grease from Kitchenaid (the old grease may contain
metal filings from the worn out gear that will damage your new one)
Jul 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
What are black screws on the side of the mixer
Those are the two Motor carbon Brushes. Without them, the motor
would not run at all. Sooner or later, they will become so worn out
that the mixer will stop running. And when it does, don't be alarmed.
You simply purchase new ones for it. To see what they look like,
Go on Ebay & search for Kitchenaid Motor Brush*. They are keyed so
there is only one proper way to insert them into the motor housing.
If either or both brushes do not make contact with the motor coils,
the motor will not run.
Jul 03, 2011 | KitchenAid KSM150PS Artisan Series Stand...
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a Sunbeam Mixmaster from mthe 1970s,
If this mixer sits on a stand, first remove it from the stand. Turn it upside down and shine a flashlight into the right side socket to look for obstructions. When you say you swivel the head, do you mean you rotate the handle? This is how to eject the beaters after use. It may be that the ejector on the right side is stuck. If so, you will need someone with mechanical skills to disassemble & repair.
May 23, 2017 | Sunbeam 2366 MixMaster Series Hand/Stand...
Kitchenaid mixer stopped
Hi Myrna. You may have overloaded the mixer. Don't try to use it, as you may do further damage. If you're hearing the motor turn, then it's OK. There is internal damage in the transmission area. Call Kitchenaid to find the nearest "authorised" repair place. Kitchenaid no longer has a parts catalog for the KSM 90, so parts may be hard to find. Call the "authorised place and ask if they have parts for your unit. Ask them if they can get parts for your model. If they say no to either question, call other small appliance repair places locally and ask the same questions. There may be spare parts around. The fact that Kitchenaid no longer has a parts catalog means that they consider it obsolete.
If you find that It cannot be repaired. I suggest you look at other brands to replace it, as Kitchenaid is now owned by Whirlpool Corp. and the quality of the Kitchenaid line is not what it once was when they were built by Hobart.
Goto www.consumeraffairs.com and review the different mixer's pros and cons. Good luck! ricardok45
Apr 03, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Speed control not work - constantly on high
The resistor will have failed. The A701 replacement is a 450 ohm 15W or 20W wirewound resistor. The capaicitor also can fail if the resistor has gone. It is a mains capacitor 0.1 microfarad. The modern mains capacitors are better to use than the old electrolytic type that were originally in the mixer.
Jan 01, 2008 | Kenwood KM800 Major Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
