Question about Haier Refrigerators
I have a Thetford Refrigerator in my 2008 Swift Alpine Sprite Caravan. The Serial Number is 623209-02/03. I put the power on this morning and Fault 12 showed on the Control Panel. Fault 12 says to contact your dealer or a Thetford Service Centre. I have no idea what the problem is as it was OK at Easter when I last used the caravan. I live in Gisborne, New Zealand and we have no caravan dealers here. Have you any advice as to who I could get to look at it. I am going away for Queens Birthday Weekend and would like to get it sorted before Thursday.. The N300 Model looks similar to mine. It is a three way but only connected up for gas & Electric. The numbers below are on the Instruction manual but I don't know what model mine is. Thanks Delys
SOURCE: need a new power cord....misplaced mine...
i did the same thing. replacement at radio shack.
Posted on Mar 29, 2009
erpaalai
  • 999 Answers
SOURCE: Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Posted on Jul 07, 2009
  • 4793 Answers
SOURCE: I have a 1997 caravan
chances are the power inverter has gone,(it takes 12 volts upto 240)
easy to check,use a lightbulb and the two wires to check power output.BE CAREFULL NOT TO TOUCH THE WIRES.
Posted on Sep 10, 2010
rockmeister
  • 2047 Answers
SOURCE: I described this previously, and
Hello Gary, this is just a suggestion as i suffered a similar fate sometime back on a honda. Usually when the code card which comes with the car cannot be found and therefore the sound unit does not work most of the codes which get calculated and given to you end up not working. And trying to get more codes will only end up costing you more money. What i eventually had to do was take my car in and get the sound set traded in for another one. The only problem i had then was getting a set which would fit in perfectly although on the long run i got a better sound set than the factory fitted unit because the new replacement had more functions. I have not had a problem with the new set ever since. Try getting a replacement as this will save you further stress.
Hope this has been helpful?
Posted on Apr 14, 2011
  • 43 Answers
SOURCE: My side shelf (which you store milk in) is broken.
Typicaly it is found on a sticker on the back! In your case I suggest taking the broken shelf to a local appliance dealer and they will be able to match it with a replacment for you.
Posted on May 07, 2011
Thetford caravan fridge N614F won't work on 12v red light showing on/off switch.
2 possibilities.
bad 12v fuse on refrigerator od bad power supply board
Mar 03, 2018 | Thetford Refrigerators
Manual for 1999 sprite caravan
Will this site work?
https://www.manualslib.com/manual/915126/Swift-Caravan.html
Jan 14, 2018 | RVs
Will a fridge still work if fault code 13 is displayed?
13 error code means heater element in freezer drain bad replace have to take apart whole freezer
Aug 12, 2014 | Thetford Refrigerators
BROKEN DOOR SHELF NEED REPLACEMENT
you can go to sears .com click on parts, put in your model number and get your part also you can try repair clinic .com,let me know if you find it,thanks-mike
Apr 12, 2009 | Refrigerators
Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
Jan 04, 2009 | Thetford Porta Potti
Refrigerators Logo
360 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
