Question about Maytag 24 in. MDB9750AW Dishwasher
Maytag quiet series legacy 300 control panel is not working so you can't start the dishwasher one day its fine the next day will not operate. Machine is approximately 2 years old purchased new used maybe twice a week
Their is power to the dishwasher but the control panel does not light up and the machine will not start or run
Posted on Jun 30, 2011
I have a maytag dishwasher model # mdbtt70awb quiet series 300 when you push any of the wash cycle buttons nothing works. the only button that lights up is heated dry so there is at least power there....
I had the same issue try hitting delay 1hr and start the 1hr was solid not flashing and an hr later it's running just fine. Think I need a new control panel but for now this is working.
Sep 04, 2010 | Maytag Dishwashers
I have a maytag quiet series 200 type 777-0 when i push the start/cancle it will not start?
We had the same issue with our Maytag quiet series 200 dishwasher. The Start/cancel button would not work all the time. We ended up removing the front panel from the machine and on the backside of the panel there is a plastic ultra thin ribbon cable that runs from the computer box to the push button control panel. We wiggled the ribbon cable and the start button began to work, but only if the ribbon cable was held in a certain position. So we super glued the cable in that position and it's been working consistently now.
Upon closer inspection the ribbon cable appeared to have 3 or 4 very tiny dark spots on the wires.
That would indicate to me that somehow moisture slowly eroded the tiny wires and bending the cable made the connections touch again, but for how long it will work like this is anyone's guess.
Also, it appears that the ribbon cable is permanently attached to the push button control panel. So you can't replace the ribbon cable itself without buying the hole front panel.
Aug 19, 2010 | Maytag Dishwashers
The latch is sticking on my dishwasher. How can I
replace the door latch and the handle check to see if the console loops that hold the latch are broken if so replace the console
Jun 02, 2010 | Maytag 24 in. MDB9750AW Dishwasher
1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Nov 07, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Maytag Quiet Series dishwasher won't start
Sounds like you have a bad Control Board
http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
Oct 12, 2009 | Dishwashers
Maytag Quiet Series 300 Dishwasher not working (Model MDB5601AWS)
in such cases it is always the control panel(touch panel) that needs to be replaced.it is very simple 2 chg and u could save lot of money.to chge cntrl panel ,open the door and remove all the screws around the white plastic part of door.then pull apart the inner part from outside part.the cntrol panel is held to outer panel with 4 screws.b4 that remove 2 screws holding the control board to panel.do not forget 2 unplug the unit from power b4 doing anything.
Aug 21, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Jun 01, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Mar 12, 2009 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. I can manually hit the start button twice and it will go...
Hi jeffwirch,
I'm Harvey the Master Plumber.
Your problem is: You have a maytag quiet series 300. When it is done with any of the cycles in leaves about 1-2 inches of water in the bottom of the dishwasher. You can manually hit the start button twice and it will go through a 2 minute cycle and pump out the water. You have cleaned the filter inside the dishwasher where it drains and have checked the hose to the disposal and it pumps out fine. It just doen't pump itself at the end of the cycle.
It sounds like a bad control board. It's in the top of the door panel. I don't recomend this repair to the average homeowner. You might consider the Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 13, 2008 | Maytag Dishwashers
Maytag 24 in. MDB9750AW Dishwasher Logo
1,399 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
