Question about Refrigerators
I have Whirlpool frig. When it goes into defrost water drip inside the frig and collects at the bottom. The water appears to be coming into the frig through a channell in the center back of the freezer which drops down into the refrig. At the top of the channel is the freezer fan. The frig is over 6 years. I am not sure of the model or the size. Thank you Patrick
    Sergeant:
    Champion:
  • 257 Answers
Hi Patrick, Looks like you have a drain hole that is plugged up with ice, there is a easy way to fix it, I will refer you to this video that shows you how to clear the drain. Take care Ryan http://www.youtube.com/watch?v=_ycWz_U_GDU
Posted on May 29, 2011
Water collecting under bottom draws inside frig
That water is very likely dripping from the freezer because the drain for the defrost is blocked,so instead of the water draining its dripping through the vents down under the crispers. This tip i wrote will help ya to clear that drain to keep the water from dripping through the vents.
http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
GENE
Sep 14, 2011 | Magic Chef CTF1826AR Top Freezer...
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
Water is dripping inside refridgerator coming from inside back center. Why? Sometimes it drips, sometimes it runs and sometimes it's fine.
Is water connected to this unit for the ice maker? If not than this would be the water that comes off the refrigeration coils as the unit defrosts. The water should be collected by a shallow plastic collector, routed to a drain tube, and empties to a pan under the frig where the water will evaporate quickly. Check drain collector for damage and drain hose for blockage.
Mar 31, 2010 | Whirlpool Refrigerators
Funky smell coming from bottom of frig when running
Is it a musty smell or that of something / (rodent) decomposing? If you only smell it when it is running then look for BLACK gunk that will probably appear almost like a paste. Even things like cat or dog hair will collect in damp areas. There should be a white plastic drip pan under your unit. Look for the freezer white plastic drain hose on the rear bottom of your unit on the freezer side and follow that hose to the drip pan. It catches water every time the unit defrosts which is 3 - 4 times a day depending on which defrost timer your unit has.
Usually there is a build up in the drip pan that gets mucky and then stinks like mold. It will of course need cleaned.
Also look at the fan area for the coils. Sometimes there are unwanterd home critters that attempt to get through the running fan blades and end dead up inside the cooling coil metal radiator area.
Feb 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
We have a refrigerator model ET18NKXFW03 that drips water from the ceiling of the frig. We put a pan to collect the water but several times a week a stream of water leaks as well. It seems to happen more...
You will need to remove the food from the freezer and remove the ice maker if so equipped . Remove the 2 screws from the bottom freezer panel ( you will probably see a layer of ice here ) , and the 2 screws holding the inside rear freezer panel . Using a hair dryer , start in the center , below the coils , defrosting , until you see a drain hole . You want to defrost this hole ( hot water helps ) until water starts to flow down . Use a small hose inserted into the drain hole and blow thru it , to remove any unseen debris , built up inside the drain line . Reassemble the freezer .
Oct 11, 2009 | Whirlpool Refrigerators
Water starting to pool (two tablespoons) under front of frig under door, is there a pan in the bottom of this unit?
Most fridg's have a water pan below. Need to drain occationally, especially after defrost cycle.
Apr 30, 2009 | Refrigerators
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
STANDING WATER ON TOP SHELF
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 12, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water collects on the bottom of the freezer i own a frigidaire s/s frs26zrg, water also comes out onto the floor on the left side. Doesn't look like its coming from inside of the frig saw it once as...
UNPLUG REFRIG. Empty freezer. Wipe interior dry. Check defrost hole at back of freezer & clean out as much as you can. Pull out refrig. Take off back cardboard cover. Lie on floor and look in. Bottom right under the defrost hole there is a black rubber hose that empties into a drip tray. Black mold grows inside and plugs it up. Get a thin aquarium brush and push it up the tube to clear it. Put the tube back into the tray to drain. Put everything back. Plug it in. Fixed.
Aug 04, 2008 | Refrigerators
Refrigerators Logo
134 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
