Question about Dishwashers
DAVEY TORRIUM PUMP PROBLEMS PUMP IS RANDOMLY NOT INITIALIZING WHEN TAP TURNED ON. WORKS FINE 85% OF THE TIME AND THEN SUDDENLY STOPS ACTIVATING. 2 SEPERATE NEW PUMPS, 2 SEPERATE SETUPS, SEPERATE POWER SUPPLYS, GOOD WATER SUPPLY (although inlet outlet lines only 10mm) - YET SAME PROBLEM ? REMOTE LOCATION, EXXON LNG, HIGHLANDS PAPUA NEW GUINEA. NEED HELP, EXXON LOSING PATIENCE !!! REGARDS< MARK O"BRIEN.
Rotu
  • 175 Answers
SOURCE: Dishwasher will not start
Check the drain pan area under the dishwasher, if it full of water it will trip a float switch and run the drain pump until the water evaporates or is removed by a shop vac.
Posted on Oct 03, 2006
JohnnyBeans
  • 223 Answers
SOURCE: water pump Saeco Via Venezia
Espresso Machine pump
http://216.244.99.185/ulka_pump_41w.asp
Posted on Nov 23, 2007
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: 42 plasma panasonic
DUDEEE this exact same problem happened to me!!!! what happened was it was workin fine then it started turning on and off, then now it goes through these weird phases where i cant turn it off using remote or the power button. every button on the side of the tv and the remote doesnt work. so i have to unplug it to turn it off, what a messedup problem!!! im taking my LG 32LB9D to the tv shop tomorrow i hope to get it assest and possibly fix, ill tell u how to solve the problem if my tv is fixed. :)
Posted on Nov 02, 2008
Can you adjust the pressure setting on a Davey Torrium T45 pump to reduce the power of water when taps are turned on?
No. The pressure can only be adjusted at the expansion tank and pressure switch. Keep in mind that your tank pressure needs to be 2 lbs lower than your cut-in pressure. The pressure in your tank can be bled off at the schrader valve(tire valve) at the top of the tank. You MUST adjust both the tank AND the press switch.
Feb 25, 2017 | Plumbing
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
Davey presssure pump when switched on b4 tap is opened the pump does run stop run stop run stop between each cycle small squirt of water escapes from pressure tank at the clamped junction
fix the leak as the pump build pressure switches off , the leak looses pressure pump switches on and so on
fix the leak and the pump will build pressure and switch off until the tap is used
Nov 19, 2016 | Plumbing
Davey Water Pump XP350T with Torrium flow control won't run. We turn power on and it buzzes, then cuts out with a red fault light. Any ideas?
replace the failed start/run capacitor/s on the motor
town water although brown is filtered so unless a pipe has broken the problem will be the capacitor
May 30, 2016 | Washing Machines
Davey HP45-05 with Rainbank will not turn off?
Hi Sam,
Combined Electrical in Fyshwick ACT here. Has your problem been resolved?
We have found that a leaking cistern which can only be a few litres a minute can cause this problem.
Aug 14, 2012 | Plumbing
Have purchased a Tellman 9kg top loader machine but the water fills very slowly. We are not in town so do not have mains pressure. We live on a farm which tends to be low pressure. Do they have a flow...
I would not remove any of the filters etc from the system. Your best solution is to fit a pump into your supply line.<br />Somethimg like this would work: <a href="http://www.freshwatersystems.com/p-3613-davey-bt14-45-booster-system-with-torrium-45-psi-14-gpm.aspx">http://www.freshwatersystems.com/p-3613-davey-bt14-45-booster-system-with-torrium-45-psi-14-gpm.aspx</a><br />
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
No water supply to house
i have a hs50-05t with a torrium controller it only works when you hold the prime button in
Nov 21, 2009 | Plumbing
I have a 1985 Chevy C/30 pick-up with a 7.4L 454. Truck has been running fine and about a week ago I was driving down the freeway and the motor backfired and and lost power and eventually died. I stopped...
85 with TBI only needs 13lbs of fuel pressure. verify that the fuel filter is clean. there is no easy way to ck fuel pressure, special adapters are needed, I dont have info here at home but there should be a relay for the pump, on the firewall and the oil pressure switch also powers the pump. did you replace the pump trying to fix this problem or did you just mention it to help troubleshoot the problem? verify that the fuel pump wiring has a good ground, should have been a eyelet that bolted to the frame..when you initially turn the key on, you should hera the fuel pump power up for 2 seconds, then go off, after the engine starts, the power for the pump goes through the oil pressure switch.
Sep 19, 2009 | 1985 Chevrolet C3500
Wont record anything to MiniDV tape and A/D randomly working
Sorry about delayed reply as I just saw it.
Its known problem of ccd imager in Canon ZR85 camcorder and ccd imager needs to be replaced.
Canon will repair your camcorder free of cost as per announced scheme for ccd imager issue.
Click Canon CCD Advisory for details, how to get free repair.
Regarding can't see picture or time code in playback, it is problem of dirty / clogged video heads. Use good quality video head cleaning cassette to clean heads and hope camera will show playback picture.
Good luck.
Nov 19, 2008 | Canon ZR85 Mini DV Digital Camcorder
Stalling, relatively radnomly
check your fuel filter if not that it might be a pump starting to go out
Jun 14, 2008 | 1985 Chrysler New Yorker
Dishwashers Logo
198 people viewed this question
Top Dishwashers Experts
