Question about Pentax ZX-M 35mm SLR Camera
I load film into my Pentax ZX-M, it immediately rewinds film? Bought another roll of film, same thing?! It's been in mothballs for a few years, but have replaced batteries, Tom
  • 571 Answers
SOURCE: my pentax zx-m rewinds new film as soon as i shut
When loading film, make sure to draw the film all the way to the receiving spool. If you don't pull the film far enough the camera thinks it's empty and rewinds the film.
Posted on Aug 18, 2009
Gryfox
  • 216 Answers
SOURCE: Unexpected Rewinding
Could you be putting too much film onto the wind spool? Take the end of the film leader no farther than the RED/ORANGE marker at the spool. Too much film will cause it to bind and start rewinding.
Posted on Nov 19, 2006
poolseman
  • 206 Answers
SOURCE: Pentax zx-50 Shutter Problems?
I really think this is the classic zx - 50 shutter motor problem : small motor on the side of the mirror box is not cocking the shutter . This is very repairable but unfortunately it requires fair amount stripping down of the camera to get to the fault and so you will have to take it in for repairs.
Posted on Sep 03, 2007
Ostewart2102
  • 41 Answers
SOURCE: Mirror locked up
Older cameras like this are notorious for locking up after not being used for quite some time. Though, it is an easy fix, it does require some steady hands and a good memory of where everything was after you're taken it out or apart. The best solution for this is, once you've taken it apart and have access to the mirror, is to have a q-tip with a little vasoline on the tip, apply a thin (very thin) layer along all springs and joints surround the mirror and around the edges of the mirror opening, while avoiding getting any vasoline on the mirror itself. I've worked with cameras all my life and have worked at camera shops, and what I've explained here is exactly what a camera repair place would do. But, if you don't feel comfortable with small parts and tiny screws, a camera shop will gladly fix it for you, and not at a bad price.
So, Good luck! Hope this helps. I hope you're out taking photos soon!
Olivia~*
Posted on Dec 01, 2008
cpt100
  • 154 Answers
SOURCE: film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
Posted on Apr 01, 2009
I have a pentax zx-60 that is showing an error message o_ _ _ _ with an E on top of that. I'm not sure what it means or how to fix it. I tried reloading the film and it doesn't seem to advance.
I think the 'o____' is intended as a pictorial representation of a roll of 35mm film, the 'E' signifying an error in loading it. Not used this particular Pentax model myself, but some of them have a slot in the take-up spool where the 'tongue' of the film should be inserted - is that the case with yours ?
Nov 27, 2015 | Pentax Photography
I am a student. My pentax zx-7 camera had been
there are a number of things that can cause this, but the most common cause is the dirty phase switch. It is located under the metal plate on the bottom of the camera and requires careful disassembly so as not to tear flexes that go over the plate
Oct 02, 2014 | Photography
Hello, I have not been using my Pentax zX5n for a while. Recently I decided to use it again and was surprised to discover that after loading a new batteries that it would not start. Actually after loading...
Have the old batteries leaked in the battery compartment ? Also, when you removed the previous film, did you set the camera into rewind mode ? If not, you have probably damaged the winding motor beyond economical repair.
May 08, 2017 | Pentax ZX-5 35mm SLR Camera
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
Camera shoots all the film then rewinds.
Repair would be at least $139 from Blue Moon Camera. I would buy another MZ-50 (ZX-50 is the same) off eBay or you could buy a ZX-30 from Blue Moon Camera for $75 with 1 year warranty. They are professional.
http://www.bluemooncamera.com/services.php
Jan 10, 2010 | Pentax MZ-50 35mm SLR Camera
My pentax zx-m rewinds new film as soon as i shut the door
Jul 08, 2009 | Pentax Photography
My film won't load
Jammed Advance Motor Assembly.
Feb 27, 2009 | Pentax ZX-60 35mm SLR Camera
Sep 03, 2007 | Pentax ZX-50 35mm SLR Camera
Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Pentax ZX-M 35mm SLR Camera Logo
189 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
